离子源中传输时间,速度场,速度矢量场,速度检测方案(粒子图像测速)
检测样品
其他
检测项目
传输时间,速度场,速度矢量场,速度
关联设备
共1种
下载方案
At atmospheric pressure (AP)ions are subject to a high frequency of collisions with bulk gas particles and other species present.Due to the high number of collisions,even relatively slow chemical reactions may become relevant in an AP ion source.The length of the ion migration path is directly correlated with the absolute number of collisions, therefore it may serve as a figure of merit to estimate the relevance of individual chemical interactions. In addition the experimental investigation of ion transfer times allows the verification of complex numerical models, which consider transport due to electrical fields and viscous gas flow.
北京欧兰科技发展有限公司为您提供《离子源中传输时间,速度场,速度矢量场,速度检测方案(粒子图像测速)》,该方案主要用于其他中传输时间,速度场,速度矢量场,速度检测,参考标准《暂无》,《离子源中传输时间,速度场,速度矢量场,速度检测方案(粒子图像测速)》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪。
我要纠错
