喷嘴中火焰浮起长度检测方案(尾气检测)
检测样品
汽车电子电器
检测项目
热性能
关联设备
共3种
This paper reports on the experimental investigation of the flame lift-off length for five different orifice
diameters (.0.100, .0.130, .0.160, .0.190, and .0.227 mm) of a diesel injector nozzle. The flame lift-off
was determined from the measurement of 308 nm OH chemiluminescence for different fuel injection pressures
using commercial diesel fuel and a Common Rail fuel injection equipment of passenger car size. The fuel
injection pressures were 450, 900, and 1350 bar. The experiments were conducted at air pressures of 30, 50, 70,
and 90 bar and at an air temperature of 750 K in a constant pressure spray chamber. It was observed that the
flame lift-off length increases with increased injection pressure and increased orifice diameter.
北京欧兰科技发展有限公司为您提供《喷嘴中火焰浮起长度检测方案(尾气检测)》,该方案主要用于汽车电子电器中热性能检测,参考标准《暂无》,《喷嘴中火焰浮起长度检测方案(尾气检测)》用到的仪器有汽车发动机多参量测试系统、PLIF平面激光诱导荧光火焰燃烧检测系统、德国LaVision PIV/PLIF粒子成像测速场仪。
我要纠错
