流体,湍动,边界层,流动中3D3C速度场,体视速度场,速度矢量场,速度场检测方案(粒子图像测速)
检测样品
其他
检测项目
关联设备
共4种
下载方案
The spatial and temporal development of turbulent boundary layer flows is governed by the self-organization
of coherent structures like hairpin-like or arch vortices and spanwise alternating wall bounded low- and highspeed
streaks. For a detailed analysis of the topologies of the wall normal fluid exchange namely of the four
quadrants of the instantaneous Reynolds stresses Q1,…,Q4 a 4D- measurement technique is desired.
In this feasibility study the tomographic PIV technique (Elsinga et al. 2005) has been applied to time resolved
PIV recordings. Four high speed CMOS cameras are imaging tracer particles which were illuminated in a
volume inside a boundary layer flow at 4 kHz by using two high repetitive Nd:YAG pulse lasers. The
instantaneously acquired single particle images of these cameras have been used for a three dimensional
tomographic reconstruction of the light intensity distribution of the particle images in a volume of voxels
(volume elements) virtually representing the measurement volume. Each of two subsequently acquired and
reconstructed particle image distributions are cross-correlated in small interrogation volumes using iterative
multi-grid schemes with volume-deformation in order to determine a time series of instantaneous 3D-3C
velocity vector fields.
北京欧兰科技发展有限公司为您提供《流体,湍动,边界层,流动中3D3C速度场,体视速度场,速度矢量场,速度场检测方案(粒子图像测速)》,该方案主要用于其他中3D3C速度场,体视速度场,速度矢量场,速度场检测,参考标准《暂无》,《流体,湍动,边界层,流动中3D3C速度场,体视速度场,速度矢量场,速度场检测方案(粒子图像测速)》用到的仪器有体视层析粒子成像测速系统(Tomo-PIV)、自适应粒子成像测速场仪(PIV)、德国LaVision PIV/PLIF粒子成像测速场仪、时间分辨粒子成像测速系统(TR-PIV)。
我要纠错
