应用高效逆流色谱技术一次分离两类顺反异构体
检测样品
其他
检测项目
关联设备
共1种
下载方案
Four flavonoids, isoastilbin, astilbin, isoengelitin, and engelitin were isolated and purified simultaneously from Smilacis Glabrae Roxb. for the first time by high performance counter-current chromatography using a system consisting of n-hexane–n-butanol–water (1:2:3, v/v/v). A total of 392.6 mg of astilbin, 71.4 mg of isoastilbin, 47.4 mg of engelitin, and 10.3 mg of isoengelitin were purified from 1.89 g of the ethyl acetate extract of Smilacis Glabrae Roxb. in six runs, each at over 94.51% purity as determined by HPLC. The structures of the four compounds were identified by their retention time, the LC-ESI-MSn in the negative ion mode, and confirmed by 1H-NMR experiments. The characteristic LC-ESI-MS fragmentation patterns of the four compounds were discussed.
弗士达仪器为您提供《应用高效逆流色谱技术一次分离两类顺反异构体》,该方案主要用于其他中null检测,参考标准《暂无》,《应用高效逆流色谱技术一次分离两类顺反异构体》用到的仪器有高效/高速逆流色谱HPCCC/HSCCC/CCC/CPC。
我要纠错
