姜黄提取物 Turmerlc extract HPLC Conditions ba065 Column : CAPCELL PAK C MGII S5: 4.6 mm i.d.x 150 mm Mobile phase : Trifluoroacetic acid was added to a solution (H:0 / CH:CN= 55 /45) at 0.1 vol% Flw rate : 1.0 mL/min Temperature :40℃ Detection : UV 420 nm Inj. vol. :5pl Pretreatment : The standard compound was dissolved in the mobile phase at 20pg/mL. The content of the supplement was diluted with methanolso that the concentration of curcumin be 1 mg/mL, approximately,and sonicated for five minutes. After leaving it for a while theupper layer was filtered with a 0.2-um filter, diluted with methanolat 20 pg/mL, and introduced to HPLC ※1 pg/mL=1 ppm
关闭产品配置单
三耀精细化工品销售(北京)有限公司为您提供《姜黄提取物中主要成分分析检测方案(液相色谱柱)》,该方案主要用于蔬菜中营养成分检测,参考标准《暂无》,《姜黄提取物中主要成分分析检测方案(液相色谱柱)》用到的仪器有null。
