Capsaicin発行日:2013年8月発行人:株式会社資生堂70元17仁事業部 辣椒素 辣椒素是植物由来的有机化合物,作为辣椒的辣味成分而知名。除了辣椒素之外,辣椒中还含有二氢辣椒素等辣椒素类物质。使用 CAPCELL CORE C18 S2.7 (2.1 mm i.d.x 100mm), 在通常流速(200 uL/min)的两倍流速下,辣椒素得到了良好的保留和分离,并且色谱峰形好(压力:装置和柱压总和为29.8 MPa). Capsaicin, a plant-based compound, is known as a pungent component in red pepper.Besides the compound, reddppepper also contains other capsaicinoids,, suchasdihydrocapsaicin. Shown below is a chromatogram of the two compounds obtained withCAPCELL CORE C18 S2.7 (2.1mm i.d. x 100 mm). The flow rate, 400 uL/min,corresponds to twice that of conventional methods. Good peak shapes, retention, and aresolution between the compounds were obtained (pressure: 29.8 MPa, across the columnand the instrument). 2 【HPLC Conditions】 Column:CAPCELL CORE C18 S2.7 ;2.1 mm i.d. x 100 mmMobile phase:H2O/CH3OH=45/55Flow rate:400 pL/minTemperature: 40℃Detection: UV 280 nmInj. vol.:1pLSample dissolved in:CH3OH※ 1ug/mL=1 ppm
关闭产品配置单
三耀精细化工品销售(北京)有限公司为您提供《辣椒素中CORE柱快速分析检测方案(液相色谱柱)》,该方案主要用于蔬菜中营养成分检测,参考标准《暂无》,《辣椒素中CORE柱快速分析检测方案(液相色谱柱)》用到的仪器有null。
