@HALO and Fused-Core are registered trademarks of Advanced Materials Technology, Inc.广州:020-29183493上海(全国):021-3895-3588 北京:010-82176650西安:029-89297872 苏州:0512-68054587 HALO1Fused-Core@Particle Technology Application Note: 58-AM Isocratic Separation of Amphenicols on HALO RP-Amide Phase Halo RP-Amide色谱柱快速分离酰胺醇类化合物 PEAK IDENTITIES: 1. Thiamphenicol(甲砜霉素)2. Chloramphenicol(氯霉素) TEST CONDITIONS: STRUCTURES: Column: 4.6x50 mm, HALO RP-Amide Part Number: 92814-406 Mobile Phase: 55/45-A/BA=0.025 M Ammonium acetate buffer, pH=5.8B=AcetonitrileFlow Rate: 1.0 mL/min. CI HC HD CI ·NO2 Pressure: 92 BarTemperature:35 °CDetection: UV 240/280 nm, VWDInjection Volume: 0.5 pL OH HO Sample Solvent:Acetonitrile Response Time: 0.02 sec. Thiamphenicol Chloramphenicol Flow Cell: 2.5 pL semi-micro LC System: Shimadzu Prominence UFLC XR Extra column volume:~14 puL This separation shows a rapid HPLC method for the analysis of amphenicols using HALO RP-Amide phase. To improve the sensitivity of detection the first peak was monitored @ 240 nm and the second @ 280 nm. 上海通微分析技术有限公司Unimicro (Shanghai) Technologies Co., Ltd. www.advanced-materials-tech.com ( -0L 苏州环球色谱有限责任公司 GLOB A L CHROM A TOGRAPHY CO..LTD. )
关闭产品配置单
上海通微分析技术有限公司为您提供《甲砜霉素和氯霉素等抗生素中主要成分含量检测方案(液相色谱柱)》,该方案主要用于其他中主要成分含量检测,参考标准《暂无》,《甲砜霉素和氯霉素等抗生素中主要成分含量检测方案(液相色谱柱)》用到的仪器有null。
