ISSN1004-1257CN 12-1133/R ·767·职业与健康2014年3月第30卷第6期Occup and Health, Mar. 2014, Vol.30, No. 6 中华预!1防医学会系列杂志 2014年3月第30卷第6期 Mar.2014 Vol.30 No.6 祝费《职业与健康》杂志创刊三十周年(1985-2014 计源 DABI收 ISSN1004-1257 土壤中4种阳离子的 IC-2010 离子色谱测定法 Determination of 4 cations in soil by IC-2010 ion-chromatography system 刘双英,张科,马云飞,马琢琪 LIU Shuang-ying, ZHANG Ke, MA Yun-fei, MA Zhuo-qi 吉林省水利水电勘测设计研究院,长春市130012 摘要:目的 建立新型高通量离子色谱仪快速测定土壤中钠、镁、钙和钾4种离子含量的方法。方法 采用 TSKgelSuperIC-CR阳离子分析柱及淋洗液2.20 mmol/L 甲基磺酸﹢1.00 mmol/L 18 冠醚6,测试中采用抑制电导检测器:结果 钠,镁、钙和钾4种元素在18 min 内可完全分离,4种离子的质量浓度均在一定的范围内呈线性关系,各离子的检出限分别为7.1,9.5,10.0,8.3ug/L,方法的加标回收率在95.4%~103%之间,测定值的相对标准偏差(n=5)在0.49%~4.72%之间。结论 此方法测试结果准确、可靠,适合不同土壤样品的批量分析。 关键词:离子色谱法;土壤;4种阳离子 中国图书资料分类号:R115 文献标识码:A 文章编号:1004-1257(2014)06-0767-04 Determination of 4 cations in soil by IC-2010 ion-chromatography system LIU Shuang-ying, ZHANG Ke, MA Yun-fei, MA Zhuo-qi Jilin Inxestigation and Design Institute of Water Resource and Hydropower, Changchun, 130012,China Abstract; [ Objective] To establish a method for rapid determination of four cations in soil, including sodium, magnesium, calciumand potassium, by the novel high-throughput ion chromatography(IC). [Methods] TSKgel SuperIC-CR column, and the eluant of2.20 mmol/L methanesulfonic acid and 1.0 mmol/L 18-Crown-6 were used for separation of the four cations. The inhibitory con-ductivity detector was adopted in the determination. [Results] The four cations were separated within 18 minutes, and the linearitywas found in the definite concentration ranges for the four ions. The detection limit of Na*, K*, Ca*, Mg* was 7. 1 pg/L,9.5g/L, 10.0 pg/L and 8.3 ug/L, respectively. The recoveries were between 95.4% and 103%, while the relative standard devia-tions (n=5) ranged from 0.49% to 4.72%. [Conclusion] The results are accurate and reliable, and the method is suitable forthe batch analysis of different soil samples. Key words:Ion chromatography; Soil; Four cations 土壤是人类生存的基本资源,是农业发展的重要基础。近年来,由于土壤被人为或者自然污染物严重污染,因此,土壤质量的好坏,直接关系到人类生存质量的好坏。土壤中可溶性盐分离子 Na*、Mg、caK*是国家常规检测项目,通常所用的原子吸收法、原子发射光谱法2,1次只能测定1个离子的浓度,且线性范围较窄,基体干扰较为严重;分光光度法,过程复杂繁琐,干扰因素多,误差大,耗时长,试剂消耗量较大,并且不能同时测定这4种有效组分,而采用离子色谱法可以同时测定这4种离子,具有灵敏度高、稳定性好、分析速度快等特点,不仅已广泛应用于环境检测,例如,油田水4、海水[5-61饮用水7-8]等。离子色谱法的分离机制是待测组分通过流动相(淋洗液)和固定相(离子交换树脂)之间的相互作用,根据各组分在分离柱中的不同滞留时间,达到分离目的,现已成为检测离子的一种常规化学分析方法。 ( 基金项目 :全 球 环境基金:吉 林西 部地区苏打盐碱湿地农牧用地 生 物多 样 性 保护 与 可 持续土地 管理 ( 项 目 号 : 46 3 2) ) ( 作者简 介:刘双英,女,高级工程师,主要从事土壤化学研究工作。 ) ( 通 讯作者:张科,E ma il: zhk666999@ 16 3. c om ) 材料与方法 1.l 仪器及试剂 IC-2010 新型高通量离子色谱仪(日本, TOSOH 公司),附 TSKgel SuperIC-CR 阳离子分析柱,TSKguardcolumn SuperIC-CR 保护柱,凝胶抑制方式;DS6 电导检测器, IC-2010工作站;GW/A系列超纯水系统(电阻率为18.20 MQ·cm,北京普析通用仪器有限责任公司);KQ5200B 超声波清洗器(昆山市超声仪器有限公司);SHZ-D(III)双表双抽循环水真空泵(郑州市亚荣仪器有限公司);AL204型电子天平(上海梅特勒-托利多仪器有限公司);5 ml 注射器,装样瓶,ODS 萃取柱和0.45 um 水性过滤头(上海密粒膜分离技术有限公司)。 甲基磺酸和18冠醚6均为分析纯; Naa、K*、Ca?Mg+阳离子标准储备液为 TOSOH 公司提供,浓度分别为2000、100、100、100 mg/L,分别取标准储备液5 ml 于100 ml 容量瓶中,用蒸馏水稀释至刻度,摇匀,配制成100、5、5、5 mg/L 的阳离子混合标准溶液。 1.2 色谱条件 阳离子分析条件:柱温35℃,电导池 温度40℃,抑制器电流80 mA ,进样体积30 p.l,柱流速 0.70 ml/min,淋洗液浓度 2.20 mmol/L 甲基磺酸+1.0 mmol/L 18 冠醚6.电导检测,外标法以峰面积定量。 1.3 样品制备准确角取40.0g(精确至0.1g)粉碎的土壤样品,用200 ml 蒸馏水溶解,摇匀后取其滤液适量经 ODS 萃取柱和0.45 um 水性过滤头过滤待离子色谱分析。 2 结果与讨论 2.1 取样量的选择 土壤中4种阳离子的含量不均,-般 Na*的含量较高,K*含量较低,有时可相差百倍至千倍。因此,为了达到好的检出效果,取样量很关键。取样量大,样品前处理困难,且由于待测样品中各种成分含量均高,会影响分离效果和降低柱效;取样量 小,待测组分含量过低,影响检测的准确性。经过多次试验,最终选择取样量为40.0 g。 2.2校准曲线,用浓度稀释法在3倍信噪比时测得Na Mg*Ca*K*4种阳离子的检出限,结果见表1取阳离子混合标准溶液,在离子色谱仪中自动进样稀释成一系列浓度的混标待测液(表1)进行测定,分别以阳离子质量浓度(mg/L)为横坐标,色谱峰面和(p人s/min)为纵坐标,绘制工作曲线,并计算线性回归方程。线性方程的相关系数均高于0.999,4种阳离子的线性回归方程分别见见1~4. 表14种阳离子的混合标准系列、线性方程、相关系数及检出限 离子 标准系列浓度(mg/L) 线性方程 1 2 3 4 5 相关系数 检出限 (ug/L) Na* 1.00 2.00 5.00 10.0 20.0 Y=2.951+32.074Y 0.999 9 7.100 0.05 0.10 0.25 0.50 1.00 Y=0.018+57.967 X 0.999 7 9.500 Ca' 0.05 0.10 0.25 0.50 1.00 Y=2.074+39.259 X 0.9999 10.000 K+ 0.05 0.10 0.25 0.50 1.00 ¥=-0.351+19.256X 0.999 8 8.300 图1NNa 的回归方程 图3 Ca *的回归方程 图2 Mg的回归方程 图4 K*的回归方程 按照1.2中的分析条件测定,图5为此条件下,Na*(100 mg/L)、Mg(5 mg/L)、Ca (5 mg/L)、K (5 mg/L)阳离子标准溶液色谱图,4种阳离子分离度良好,在18 min 内出峰完毕。 2.3 精密度测定 对处理好土壤样品进行5次重复测定,计算其相对标准偏差,实验结果见表2。从表2可知,Na Mg*、Ca+K*离子的相对标准偏差分别为0.49%4.72%4.14%2.51%。结果表明,4种离子测定结果的相对标准偏差值均小于5%,表明精密度良好,满足分析要求。 图5 阳离子标准溶液色谱图 表2 精密度的测定 离子 峰面积(us/min) 相对标准偏差 1 2 3 4 5 x±s (%) Na 33.899 33.750 33.809 33.726 33.453 33.727±0.167 0.49 Mg 5.782 5.445 5.106 5.321 5.263 5.383±0.254 4.72 Ca2- 9.985 10.063 9.769 9.045 9.693 9.711±0.402 4.14 K* 3.055 3.005 3.099 2.904 2.969 3.006+0.076 2.5] 土壤样品的色谱图如图6所示。由图6可知,NaMg*、Ca²K*离子的色谱峰分别出现在 5.035、9.34811.803、16.340 min,峰宽较窄,基线平稳,对称性较好,与相邻峰彼此分开,干扰较小,说明所选用的实验条件对于测定土壤样品的离子来说准确可行。 时间 (miu) 图6 土壤样品的色谱图 2.4 加标回收率测定 按试验方法对土壤样品进行处理并测定,同时进行加标回收试验,结果见表3。方法的加标回收率在95.4%~103%之间,符合分析要求。 表3 回收试验结果(n=3) 离子 本底测定值 加标量 测定总量 回收率 (mg/L) (mg/L) (mg/L) (%) Na 105.934 50.00 155.902 99.9 75.00 178.889 97.3 100.00 204.867 98.9 Mg 10.225 5.00 14.994 95.4 10.00 19.895 96.7 15.00 24.595 95.8 Ca- 20.034 15.00 35.004 99.8 20.00 40.107 100.5 25.00 44.909 99.5 K 17.801 15.00 33.256 103.0 20.00 38.201 102.0 25.00 43.55] 103.0 3 结 论 采用离子色谱法测定土壤样品中Na、MgCa²和K74种离子,18 min 内分离完成,各项质量控制指标均满足测试要求,样品进样后自动完成稀释.避免了人为稀释所带来的误差,此方法快速、简便、准确性和灵敏度高,能满足土壤中无机离子测定的要求。 ( 参考文献 ) ( 1 孙丽萍 .I CP-OES 法和离子色谱法 测 定水中钙镁比对研究 J. 品工程,20 1 2(4 ) :55-57, ) ( 2 Fe rmandez-b o y ME, Cabrera F , M A DEJON E, et al. An al ysis ofcat-ions in drainage w a ter and soil solutio n by single-colum n io n chromatog-raphy[J] . J Chromal o gr A, 1998 , 823 : 279 - 2 8 3. ) ( 3] A n ton K . Bi a nca R. Be a S. Co m parison of d ifferent m e th o ds to d e ter- mine p olar c o mpounds in frying oils[Jj . Eur Food Res Technol,2001, 213:377-380. ) ( [ 4 ] El-said M , R amzi M , A b del-moghny T. An a lysis of oilfield waters by i on chromatography to determine t h e composition of scale deposition[J ] .Desalination, 200 9 ,249:74 8 - 7 56. ) ( 5 ] Gros N , Ca m oes M F , Ol i veira C,et a l . I o nic c o mposition o f s eawaters and d erive d s aline solutions d etermined by i on c h romatography and it s relation to othe r w ater qualit y paraneters J . J Chromatogr A , 2 0 08, 1210:92-98. ) ( [6] H ua W Z , Yang PJ, Ha se be K. e t a l . R api d and direc t deter m ination of ) (上接第766页) ( 2.5 精密度和检出限 测定结果检出限分别为7.92、 7.86、7.837.96、8.017.78 pg/kg(n= 6 )。相对标准偏差(RSD)为1.08%。平均回收率为77.9%,符合实 验要求的70%~110 % 。以基线噪声(S=3N)确定 方 法检出限,五氯酚的检出限为1.5 ug/kg。 ) 本实验所建立的方法操作简单,快速,精密度较高,回收率较好,所用仪器设备价格便宜,具有一定的实用性。 ( 参考文献 ) ( _ 1] H o HP, L e e RJ, Lee MR. Purge-assisted headspace solid-phase microex- traction combined w i th g a s c h romatogr a phy-mass spec t rome t ry for dete r -mination o f chlorophenols in aqueous s amplesPur g e assisted h eadspace solid-phase microextraction combined w i th g a s c h r omatography-mas s spectrometry for determination of c hlorophenols in aq ue ous samples[JJ . J Chromat ogra phy A, 2008,1213:245- 2 48. ) ( . 2 ]王诗生,王芳,蒋新.五氯酚在土壤生态系统中的环境行为研究进展[J]. 生 态学报,2010,7:1894- 19 02. ) 3] Group IW. IARC monographs on the evaluation of carcinogenic risks to ( iodide in seawat e r b y e l e c t rostatic i o n chromatography[J1. J C h romatogr A, 2 002 , 956: 1 03-107. ) ( 7C a va lli S, Pol e sello S. Valsevvhi S. Chl o ride int e rference in the de t er- mination o f bromate i n drinking water by r eagent free i on chromatograp h ywith mass s pectromelr y detection [J] . J Chromatog rA . 2 005, 1 085:42-46. ) ( [ 8] L iu Y J, M ou S F , H eberling S. D e termination of trace l evel bromate and perchlorate i n drinking water b y ion chromatography wi t h an evaporativepreconcentratio n technique[J ]. J Chromatogr A, 2002 , 956:85- 9 1 . ) ( [ 9 ]朴春月.离子色谱法测定水中4种阴离子子J].中国卫生工程学, 2013,12(1):71-72. ) ( 收稿日期:2013-08-28 修回日期:2013-11-25 责任编辑:张军 ) ( h umans, V o l. 5 3 : Oc c upational ex po sures in i ns e ct i cide app l ic ati on,and s ome pesticides[M]. L yon : I ARC P r ess, 1991. ) ( [4]齐尚忠.分光光度法测定水质中五氯 酚 的含量[J].山 西 化工,2007, 27(4 ) :40 - 41. ) ( _5]胡林林,李鱼,耿辉 , 等.紫外分光光度法测定水样中五氯酚[J ] . 吉 林大学学报:理学版,2007,45(2):320-323. ) ( [6]周建科,彭静,龙堃.盐分分相微萃取-液相色谱法测定水中痕量五氯酚[J]. 福 建分析测试,2010,19(1):37-40. ) ( [ 7]巢猛,刘建明,陈明. SPE-HPLC 法测定水中2.4,6-三氯酚和五氯酚[J]. 供水技术,2008,2(3):57-58. ) ( [ 8]陈祥国,王淑真,吕纪忠,等.微流体分流器用于鱼塘水中灭扫利和五氯酚 GC/MS 分析[J]. 中 国法医学杂志, 2 010,25(5):351-352. ) ( [9]陈祥国,姜兆林,王淑真,等. 气 相色谱法测定鱼塘水中2,4-二氯-6- 硝基苯酚和五氯酚含量!J}.理化 检 验:化学分册, 2012, 48 (5):587 - 5 89. ) ( [ 1 0 ]范苓、夏豪刚. 气 相色谱/质谱法测定水中五氯酚[J].环境监测管 理与技术,2001,13(1):33-34. ) ( _ 11]SC/T 3030- 2 006.水产品中五氯酚及其钠盐残留量的测定[S]. ) ( 收稿日期:2013-08-16 修回日期:2013-11-25 责任编辑:张军 ) ☆ ☆
关闭还剩3页未读,是否继续阅读?
东曹(上海)生物科技有限公司为您提供《土壤中(类)金属及其化合物检测方案 》,该方案主要用于土壤中(类)金属及其化合物检测,参考标准《暂无》,《土壤中(类)金属及其化合物检测方案 》用到的仪器有null。
