当前位置: 润滑油 > 方案详情
润滑油、添加剂等样品中总氮检测方案
检测样品 润滑油
检测项目 总氮
关联设备 共1种 下载方案
方案详情
multi EA 5000 集多个模块于一身,可用来检测固体,液体,粘稠性物体、液化气和气体中的硫,氮,碳,氯含量,由于它的革新技术,multi EA5000 仪器有广泛的应用领域,并且具有很强的适用性和灵活性,是各行业高效的检测工具。 采用德国耶拿公司的multi EA5000元素分析仪,选用水平模式可以准确测定此类样品中总氮的含量。
analytikjena analytikjena Short Application multi EASeries Determination of Nitrogen in Lubricating Oils, Additives and RelatedProducts Introduction Lubricating oils (motor oils) are used for the reduction of friction and noise emission and thereforea lessening of material wear in the gears. It consists of two main components, the synthetic ormineral base oil and a mixture of additives. Both components can contain small amounts ofnitrogenlcompounds.;.These are not desired anddcanniinfluence ttheelater performancecharacteristics of the product significantly. Some additives, which are added to the end product forimprovement of its performance characteristics, in contrast canncontain desired nitrogencompounds. These must also be determined and controlled. Sample Preparation and Analysis An analyzer of the multi EASeries was used with multi matrix sampler for the tests in thehorizontal operation mode. With the aid of the autosampler, samples can be dosed according totheir viscosity: either with a syringe (low viscosity or high viscosity following sample dilution), orwith a quartz boat (high viscosity without sample dilution, solids, etc.). The automatic boat drivefeeds the dosed samples into the combustion system in a fully automated process using flamesensor technology. The quantitative thermal decomposition was done in a two-phase process. Thenitrogen content of the samples was determined afterwards with the help of a chemoluminescencedetector. Method settings The method TN_hori_solid rather TN_hori_liquid of the standard method library was used foranalyzing. Prior to the actual determination of the nitrogen content, the system is calibrated using standardsolutions (pyridine in isooctane) in the range of 0 - 100 mg/kg. Results Sample cN [mg/kg] SD [mg/kg] RSD [%] Scio_1 5.2 0.1 2.7 Scio_2 15.7 0.4 2.3 Lube_1 58.2 1.0 1.7 Lube 2 83.3 0.7 0.8 Summarv The horizontal operation mode of the analyzers of the multi EA Series are outstandingly suited forthe precise determination of the contents of nitrogen in lubricants. Thereby allows the multi-matrix sampler an optimal adjustment of the sample introduction processto the requirements of each matrix to be analyzed. During parallel operation of a UV fluorescencedetector the sulfur content can be recorded simultaneously. Moreover, the application spectrumcan be expanded with additional accessory modules to include the parameters chlorine andcarbon. Duplication and distribution permitted with reference to source. C 2007 Analytik Jena AG Publisher: Analytik Jena AG 07745 Jena Phone +49 (0) 3641/77-70 Konrad-Zuse-StraBe 1 Fax +49 (0)3641/77-92 79 Publisher:Analytik Jena AG07745 JenaKonrad-Zuse-StraBe 1 Determination of Nitrogen in Lubricating Oils, Additives and Related ProductsReference Number: EA__N_e||GRO/
关闭
  • 1/3
  • 2/3
还剩1页未读,是否继续阅读?
继续免费阅读全文
产品配置单
耶拿分析仪器(北京)有限公司为您提供《润滑油、添加剂等样品中总氮检测方案 》,该方案主要用于润滑油中总氮检测,参考标准《暂无》,《润滑油、添加剂等样品中总氮检测方案 》用到的仪器有multi EA® 5000碳、氮、硫、氯 元素分析仪 。
我要纠错
推荐专场
相关方案
