Measurement of Banana (3D Fluorescence Spectra) |NTRODUCTION The fluorescence of banana peel was analyzed. When the surface of the peel was irradiated by ultraviolet ray at 300-400 nm, a blue fluorescence having a peak at 430 nm was observed. There has been a report that when a bananaripens, even more intense fluorescence is observed around the sugar spots and thus, the fluorescence can be usedas an index of the ripeness. When the excitation and fluorescence wavelengths are unknown, the 3D spectrum iseffective. F-7000 fluorophotometer, with the fastest scan speed for the instrument class, allows the high-throughput KEY WORDS Bio/Medical Science/Food/Pharmaceutical, Food, Food Chemistry,Banana, 3D Fluorescence Spectrum, 3D, FL, F-7000 Fluorophotometer (FL) Sheet No.FL090014-01A SAMPLE ACCESSORY SAMPLE NAME: Banana peel Solid sample holder(P/N:650-0161) INSTRUMENT CONDITIONS INSTRUMENT : F-7000 RESPONSE : Auto FULLSCALE : 180 EX BANDPASS :5nm EM FILTER : 310 DIVISION NUMBER :1 EM BANDPASS :5nm PHOTOMULTIPLIER :R3788 SCAN SPEED : 60000 nm/min PHOTOMULTIPLIER VOL.: 400V Measurement of Banana (Excitation Spectrum) Fluorophotometer (FL) INTRODUCTION The fluoresce of banana peel was analyzed. When the surface of the peel was irradiated by ultraviolet ray at 300-400 nm, a blue fluorescence having a peak at 430 nm was observed. There has been a report that when a bananaripens, even more intense fluorescence is observed around the sugar sports and thus, the fluorescence can beused as an index of the ripeness. The excitation spectrum at the fluorescence wavelength of 430 nm was measuredbased on the information obtained from the 3D fluorescence spectrum. SAMPLE ACCESSORY SAMPLE NAME: Banana peel Solid sample holder(P/N:650-0161) INSTRUMENT CONDITIONS PEAKS (nm) INSTRUMENT : F-7000 RESPONSE : Auto EM WAVELENGTH : 430 nm EM FILTER : 310 EX BANDPASS : 5nm PHOTOMULTIPLIER : R3788 EM BANDPASS : 5nm PHOTOMULTIPLIER VOL.: 400V SCAN SPEED : 400 nm/min 1:340 Fluorophotometer (FL) Bio/Medical Science/Food/Pharmaceutical, Food, Food Chemistry, Banana, Excitation Spectrum, FL, F-7000 SheetNo.FL090014-02A KEY WORDS Bio/Medical Science/Food/Pharmaceutical, Food, Food Chemistry, Banana, Fluorescence Spectrum, FL, F-7000 Fluorophotometer (FL) INTRODUCTION The fluoresce of banana peel was analyzed. When the surface of the peel was irradiated by ultraviolet ray at 300 -400 nm, a blue fluorescence having a peak at 430 nm was observed. There has been a report that when abanana ripens, even more intense fluorescence is observed around the sugar sports and thus, the fluorescencecan be used as an index of the ripeness. The fluorescence spectrum at the excitation wavelength of 345 nm was measured based on the information obtained from the 3D fluorescence spectrum. SAMPLE ACCESSORY SAMPLE NAME:: Banana peel Solid sample holder(P/N:650-0161) INSTRUMENT CONDITIONS PEAKS (nm) INSTRUMENT : F-7000 RESPONSE : Auto EX WAVELENGTH : 345 nm EM FILTER :310 EX BANDPASS :5nm PHOTOMULTIPLIER : R3788 EM BANDPASS :5nm PHOTOMULTIPLIER VOL.: 400 V SCAN SPEED : 240 nm/min 1:434 Bio/Medical Science/Food/Pharmaceutical, Food, Food Chemistry, Banana, Fluorescence Spectrum, FL, F-7000 Sheet No.FL090014-03A Hitachi High-Technologies Corporation The fluorescence of banana peel was analyzed. When the surface of the peel was irradiated by ultraviolet ray at 300 -400 nm, a blue fluorescence having a peak at 430 nm was observed. There has been a report that when a banana ripens, even more intense fluorescence is observed around the sugar spots and thus, the fluorescence can be used as an index of the ripeness. When the excitation and fluorescence wavelengths are unknown, the 3D spectrum is effective. F-7000 fluorophotometer, with the fastest scan speed for the instrument class, allows the high-throughput analysis of 3D fluorescence spectra.
关闭还剩1页未读,是否继续阅读?
日立科学仪器(北京)有限公司为您提供《香蕉中糖检测方案(分子荧光光谱)》,该方案主要用于其他水果制品中营养成分检测,参考标准《暂无》,《香蕉中糖检测方案(分子荧光光谱)》用到的仪器有日立F-7000荧光分光光度计。
