MILLER-NELSON INSTRUMENTS HCS-501 MNR ModelHCS-501 SeriesFlow-Temperature-HumidityControl System Features Applications Microprocessor Controlled Operation Audible Alarms & Shut-Downs to protectInstrument from Damage Updated Temp & RH Probe Easy to Install Digital Readout Direct Dial Controls ◆ 20-85% Relative Humidity at 25℃ 20-35℃, with cooling option 2-20, 5-50,10-100,20-200,50-500 L/minair flow ranges, Custom Flow Rangesavailable upon request. ◆Atmosphere Generation for Respirator Car-tridge & Filter Evaluation -Instrument & Detector Calibration -PPE Permeation Studies -Air Sampler Evaluation ◆Biosphere Studies -Small Animal Environmental Controls-Plant Growth Studies ◆ Environmental Chamber Design - Product Environmental Stability Studies- Micro Balance Environment ◆Aerosol Generation ◆Desiccant Capacity Measurements Layout of Components Inside Instrument (Top View) AIR WATER Miller-Nelson Instruments, a unit of Assay Technology Description The flow, temperature and relativehumidity are set to the desired levelusing direct reading dial potentiome-ters. Air flow is measured and con-trolled using a digital mass flow con-troller. A temperature-humidity sen-sor measures the actual conditions.The electronic signals from the sensorform a feedback loop to the controllercircuit board. This unit activates heat-ers in a water reservoir and the hu-midified air stream to attain and main-tain the temperature and humidity con-ditions. Control functions require nooperator intervention, except for peri-odic calibration. All parameters canbe observed visually on digital panelmeters or monitored with a strip chartrecorder. Cooling below room tem-perature can be achieved using thecooling option (Item CP-100). Specifications Relative Humidity Range 30-90%@ 20℃;20-85%@ 25℃;10-75%@30°℃ ● Temperature Range Ambient ±2℃—35C, without Cooling Option; 20-35℃ with Cooling Option Air Flow Ranges HCS-501-20, 2-20 L/min HCS-501-50, 5-50 L/min HCS-501-100, 10-100 L/min HCS-501-200,20-200 L/min HCS-501-500.50-500 L/min Custom Flows available, upon request ● Warm-up Time 5-15 minutes Dimensions 20”x 20”x 10” Weight 40-60 pounds . Power Requirements 120 VAC, 50-60 Hz ● Water Requirements Deionized, purified water, ASTM Type I, resistivity> 18 MOhm-cm,very low organics Compressed Air Supply Clean, dry compressed air delivered at a constant pressure of 65±5 psi Stealth Street, Livermore, CA ● ● www.assaytech.us
关闭产品配置单
北京希望世纪科技有限公司为您提供《HCS-501温度控制系统中应用检测方案 》,该方案主要用于其他中其他检测,参考标准《暂无》,《HCS-501温度控制系统中应用检测方案 》用到的仪器有HORIBA多参数水质分析仪U-50、HORIBA便携式多参数水质分析仪D-71、堀场 台式多参数水质分析仪/高精度PH计F-71。
