MethodGuide: 40729C2008 Thermo Fisher Scientific Inc. All rights reserved. All trademarks are the property of Thermo Fisher Scientific Inc. and its subsidiaries. Specifications, terms and pricing are subject tochange. Not all products are available in all countries. Please consult your local sales representative for details.Part of Thermo Fisher Scientific Method Guide - As in Potable waters Principle: The sample is pre-reduced using a mixture of potassiumiodide and L-ascorbic acid. Arsenic is determined by HydrideGeneration Atomic Absorption Spectrometry (HGAAS)using the VP100 Continuous Flow Vapour System. Reagents: Hydrochloric acid (AnalaR grade, 50 %v/v)Sodium borohydride solution (AnalaR grade, 0.5 % m/vin 0.5 % m/v sodium hydroxide) Pre-reducing solution (AnalaR grade, 10 % m/v potassiumiodide + 10% m/v L-ascorbic acid) Arsenic master standard (1000 mg/L) Arsenic sub-stock standard solution (200 ug/L) Transfer 0.2 mL of arsenic master standard solution to a 1 Lvolumetric flask and add 10 mL of pre-reducing solution,then dilute to volume with deionised water. Working standards Transfer 0, 1.0, 2.5 and 5.0 mL of the arsenic sub-stockstandard solution into a series of 100 mL volumetricflasks. Add 10mL of deionised water and 10 mL ofhydrochloric acid to each flask and dilute to volume withdeionised water. The working standards will contain 0,2,5 and 10 ug/L of arsenic. Sample Preparation: Into a test tube, add 16.0 mL of drinking water sample,2.0 mL of concentrated hydrochloric acid and 2.0 mL ofthe pre-reducing solution and mix thoroughly. Allow themixture to stand for 1-2 hours at room temperature.The sample will then be ready for analysis. Tap watersamples were spiked with 0.25, 0.5, 1.0 and 2.0 ug/L ofAs and the spike recovery was calculated. The calibration is perfectly linear and the characteristicconcentration is 0.217 pg/L. The unspiked tap watersample=0.61±0.02 pg/L and the average spike recovery(see table 1.) for As was 103.2±2.6% Tap Water +0.25 ug/L As 0.27 ug/L Tap Water + 0.50 ug/L As 0.48 ug/L Tap Water+1.00ug/L As 1.03 ug/L Tap Water+2.00 ug/L As 2.13 ug/L The method of sample treatment described in this publication should be performed onlyby a competent chemist or technician trained in the use of safe techniques in analyticalchemistry. Users should acquaint themselves with particular hazards which may beincurred when toxic materials are being analysed and handled in the instruments, and theinstrument must be used in accordance with the operating and safety instructions givenin the Operators manual. The exact model of instrument on which this analysis was performed may differ from thatstated. A/though the contents have been checked and tested, this document is suppliedfor guidance on the strict understanding that neither Thermo Fisher Scientific, nor anyother person, firm, or company shall be responsible for the accuracy or reliability of thecontents thereof, nor shall they be liable for any loss or damage to property or any injuryto persons whatsoever arising out of the use or application of this method. The sample is pre-reduced using a mixture of potassiumiodide and L-ascorbic acid. Arsenic is determined by HydrideGeneration Atomic Absorption Spectrometry (HGAAS)using the VP100 Continuous Flow Vapour System.
关闭产品配置单
深圳市瑞盛科技有限公司为您提供《矿泉水中重金属检测检测方案(原子吸收光谱)》,该方案主要用于饮用水中(类)金属及其化合物检测,参考标准《暂无》,《矿泉水中重金属检测检测方案(原子吸收光谱)》用到的仪器有Thermo Fisher ICE-3500 原子吸收光谱仪。
