Applications Speed100 rpmAmount600 g- Weighting the basic materials into the reactor vessel- Closing the cover- Staring the overhead stirrerTest procedure-Tempering of the reactor vessel-Extracting the sample after the end of the test- PC controlling and documentation Applications Applications - Extracting the sample after the end of the test - PC controlling and documentation Applications Applications Applications Speed 80 rpm Amount1,3 kg- Weighting the basic materials into the reactor vessel- Closing the cover- Staring the overhead stirrerTest procedure-Applying vacuum-Starting the homogenizing - Extracting the sample after the end of the test Applications Sample potting pulks Device LR-2.ST 系统含盖子 (8016500) Tool Duration 10 minResult high viscous, homogeneous sampleSpeed 50 - 150 rpmAmount 21 -Weighting the basic materials into the reactor vessel-Closing the coverTest procedure -Staring the overhead stirrer -Extracting the sample after the end of the test Applications Applications
关闭还剩4页未读,是否继续阅读?
艾卡(广州)仪器设备有限公司(IKA 中国)为您提供《IKA LR-2.ST 反应釜系统应用实例》,该方案主要用于护理类化妆品中感官指标检测,参考标准《暂无》,《IKA LR-2.ST 反应釜系统应用实例》用到的仪器有德国IKA/艾卡 LR 1000 实验室反应器套装。
