检测样品 其他
检测项目 3D3C速度矢量场,速度场,体视速度场,层析速度场
金牌会员 752 篇解决方案
13th Int Symp on Applications of Laser Techniques to Fluid MechanicsLisbon, Portugal, 26-29 June, 2006 Investigation of 3-D Coherent Structures in the Turbulent Cylinder Wake usingTomo-PIV Fulvio Scarano, Gerrit E. Elsinga , Elisabetta Bocci, Bas W. van Oudheusden AbstractThe wake of a circular cylinder at Re =2700 is investigated by means of Tomographic PIV(Tomo-PIV), a recently developed three-dimensional velocimetry technique. The paper presents theprinciples of Tomo-PIV and discusses in details the implementation of the technique to the experimentalconditions. With a measurement volume of approximately 40x40x10 mmtwo configurations are chosen inorder to describe both the 2D wake features and the span wise organization of secondary rollers dominatingthe 3D flow organization. The present data allow to directly evaluate the measurement error imposing massconservation inside the volume (viz. solenoidal velocity field). The visualization of the wake instantaneousstructure is obtained by means of vorticity vector magnitude iso-surfaces, or decomposing the vorticity in thespan wise and stream-wise(normal)/bi-normal component, which return the separate contribution of theKarman rollers and the interconnecting structures between them respectively. The properties of thesecondary rollers are given in terms of span wise wavelength, peak vorticity, vorticity stretching and theirsize and shape. A value of the span wise wavelength A/D=1.2 is recurring and the rollers organization intopairs is found to be similar to the instability Mode B occurring in lower Reynolds number wakes investigatedwith previous studies. 1. Introduction The transition from the two-dimensional vortex shedding regime behind circular cylinders to three-dimensional flow governed by the Reynolds number has been investigated extensively especially atReynolds numbers in the order of 10+ 10'. The earliest 3D transition is associated to the inceptionof vortex loops in the main rollers around Re = 190, which distort the primary rollers with aspanwise wavelength a between 3 and 4 diameters (Mode A, Williamson and Roshko, 1990).Increasing the Reynolds number to about 250, a transition from Mode A (vortex loops) to Mode B(stream-wise vortex pairs, Williamson, 1996) was observed. These two modes were identified asthe two dominant modes for the three-dimensional organisation of coherent structures in the 3Dcylinder wake regime. In particular Mode B is characterised by a shorter span wise wavelength(A/D=1 between counter-rotating stream-wise rollers). The application of PIV allowed to performquantitative analysis of the secondary vortices. Brede et al. (1996) obtained A/D =4.5 for Mode Aand confirmed 1/D=1.0 for Mode B. At Reynolds numbers exceeding 10 the interaction betweenthe streamwise and the Karmán rollers has been investigated by Muchmore and Ahmed (1993) whovisualised mushroom shaped structures interconnecting the span wise rollers by means of planarlaser fluorescence. A reecceenntt PPIIVV survey along orthogonal planes performed in the rangeRe=2,000-10,000 by Huang et al. (2006) showed a more chaotic wake structure, ascribed to thetransition occurring within the separated shear layers. The full three-dimensional wake structure cannowadays be simulated with DNS as performed by Thompson et al., 1994 however experimentaldata is lacking for a comparison of the full three-dimensional wake structure and even the latestplanar velocimetry surveys do not render the instantaneous 3D organisation of the wake. From theabove experimental studies, a number of issues are not yet elucidated. In particular at higherReynolds numbers, the secondary vortices model is based on planar cross sections and theinstantaneous three dimensional organisation of the flow field has not been sufficiently understood. Moreover the quantitative characterisation of the secondary vortices dynamics requires the vorticitystretching term to be evaluated, which has not been investigated experimental means due to thetechnical limitation of the planar PIV technique. The present study approaches the analysis of theinstantaneous three-dimensional organisation of the coherent flow structures present in the vortexwake applying the recently developed 3D velocimetry technique Tomographic PIV (Tomo-PIV,Elsinga et al., 2005). The experiments are performed in the air flow behind the circular cylinder atRe =2700 characterizing quantitatively the three-component velocity vector field over a volumecontaining the cylinder wake. The evaluation of the 3D velocity gradient tensor enables thetopological evaluation of iso-vorticity loci and vorticity stretching field. 2. Experimental apparatus 2.1 Hardware arrangement Experiments are performed in the open-test section of a 40x40 cm’wind tunnel (Figure 1-left) at theAerodynamic Laboratories of TU Delft Aerospace Engineering. The free-stream velocity is 5 m/sand the cylinder diameter D is 8 mm(Rep=2700). Thee measurementvolume extendsapproximately over a region of 40(H)x40(L)x10(W) mm’with the shortest side (W) in the directionof the depth of field. Two measurement configurations are chosen, either with the height (Figure 1-right) or the width aligned along the cylinder axis respectively. The flow is seeded with 1umdroplets produced with a fog generator. The illumination is provided with a Spectra-PhysicsQuanta Ray Nd:YAG dual-head laser delivering 400 mJ energy/pulse. The light beam is shaped intoa 10 mm thick and 60 mm wide sheet using light sheet optics, determining the measurement volumedimension. A knife-edge slit filter is placed before the thick light sheet enters the measurementregion in order to cut off the low-energy fringes on the sides and obtain a top-hat like light intensitydistribution terminating sharply at the edges. The recording is performed with four cameras viewingthe illuminated region in stereoscopic formation along a solid angle of approximately 45x45degrees. Two LaVision Imager Intense CCD cameras (1376x1040 pixels, 12 bits), a PCO SensicamQE (1376x1040 pixels, 12 bits) and a PCO Sensicam (1280x1024 pixels, 12 bits) are equipped withNikon objectives of 50 and 60 mm focal length with a numerical aperture set at f#= 8.0. The focalplane of each imaging unit is aligned with the median plane of the laser sheet by means ofScheimpflug adapters able to tilt the objectives relative to the image plane along oblique axes. Theaverage imaging magnification is M =0.36 with a digital resolution of 18 pixels/mm. The digitalsynchronisation between laser, cameras and the image acquisition system is given by a LaVisionprogrammable timing unit (PTU) installed on a PC and controlled through DaVis7.3. Therecording rate is 1Hz and the time separation between subsequent exposures is set at 35 us. Onehundred Tomo-PIV recordings (quadruplets of image pairs in the present case) are acquired for eachexperiment. Figure 1 - Left: experimental arrangement. Wind tunnel exit, cylinder model and tomographic imagingsystem. Right: schematic of illumination and imaging. 2.2 Tomo-PIV principle A schematic description of the working principle of the technique follows hereafter, whereas adetailed discussion on the technique is given in (Elsinga et al. 2005). The tomographicreconstruction algorithm requires the knowledge of a mapping function between image space andthe three-dimensional object space similarly to the standard stereoscopic PIV. The mappingfunction is obtained with a calibration procedure translating a target along measurement volumedepth. The intensity distribution in the measurement volume is reconstructed using a variant of theMART (multiplicative algebraic reconstruction technique, Herman and Lent, 1976) algorithmadapted for PIV and developed in collaboration with LaVision GmbH. The MART method is an algebraic method to iteratively solve a set of linear equations modellingthe imaging system, in which the object is written as a series of basis functions. In the presentmodel the object is given by the intensity distribution of the light scattered by the particles withinthe measurement volume E(X,Y,Z), which is discretised over a 3D array of cubic voxel elements (a“voxel" is the three-dimensional equivalent of a pixel). The associated basis function w is of 3Dtop-hat type with uniform value inside the voxel and zero outside. The projection of E onto eachview from the different cameras returns the image intensity distribution I(x,y) discretised by thesensor pixels (k is the camera index). The algebraic system of equations linking E and I reads as: where Wrm is the weighting coefficient describing the contribution of the nh voxel intensityE(X,Y,Z) to the m" pixel intensity I(xm, ym) from the k"recording (viewing direction). N is thetotal number of voxels in the volume. Neglecting the fact that diffraction occurs in the imagingsystem, from geometrical optics the recorded pixel intensity can be seen as the result of the integralof object intensity along the corresponding line of sight. In that case the intensity field relative to areconstructed particle will resemble a 3D Gaussian-type blob, whose projection in all directions isthe diffraction spot. The value of the weighting coefficient Wm,n is obtained from the basis functionw as a function of the distance between the m" line of sight and the n" voxel. A multiplicationfactors may be used to obtain a weighting coefficient that accounts for uneven illumination (due tothe laser light distribution), differences in intensity detected from the different cameras (collectinglight in forward or backward scatter) or other optical dissimilarities. The expression of the iterativeupdate of the MART method reads as: \uWm, where u is a scalar coefficient intended as relaxation parameter. The magnitude of the update isdetermined by the ratio between the measured pixel intensity I(xm,)m) and the projection of theobject at the current iteration. The weighting W function at the exponent ensures that only theelements in E(X,Y,Z) affecting the m" pixel are updated. Furthermore the MART scheme requiresthat I and E are both definite positive. The reconstruction performance of the MART a;gorithapplied to PIV recordings has been assessed by means of synthetic 3D particle field simulation(Elsinga et al. 2005). The simulation showed that the coefficient obtained correlating thereconstructed intensity field with the exact distribution is above 0.9 for a four views system with aseeding level of approximately 0.05 particles per pixel, which has been chosen as the workingconfiguration for the present experiments. The actual measurement volume of 40x40x10 mm’is discretised over 730x730x184 voxels at aspatial resolution of 18 voxels/mm (pixel-to-voxel ratio of 1). The reconstructed volume size is41x41x10 mm. The seeding density in the individual images is approximately 0.05 ppp, yielding5x10" recorded particle images, which are reconstructed in the volume. The DaVis 7.3 software isused for the tomographic reconstruction. Approximately 1 hour is required for the reconstruction ofone 3D object applying the MART algorithm with 5 iterations. Figure 2 - Left: cross sectionof the reconstructed light intensity distribution (left). Coordinates are in voxelunits, axes are not at scale. Right: reconstructed particle field distribution. Red and yellow indicate the firstand second exposure respectively. Blob size is proportional to the square-root of the particle intensity. An indicator of the quality of reconstruction in real experimental conditions is given by the ratio oflight intensity within the illuminated region (signal) and that obtained outside of the reconstructedvolume, which is representative of the reconstruction process noise. Figure 2-left shows a crosssection of the light intensity in the reconstructed volume. The reconstruction domain slightlyexceeds the illuminated one in order to avoid that spurious light intensity reconstructed at thedomain boundary affects the reconstruction in the illuminated region. The light intensity profilereturns a reconstruction signal-to-noise ratio of 3 in the present experiment. Figure 2-right shows aschematic 3D representation of the reconstructed intensity field by plotting spherical blobs in thethree-dimensional space where an intensity maximum is detected in the reconstructed scalar field.Yellow and red blobs correspond to the particles recorded at the first and second exposurerespectively. A visual inspection returns particle pairs in many cases, however also a significant number of unpaired particles is observed, which is ascribed to the limited reconstruction accuracyassociated to the high seedin一1g density of the present experiments. The displacement occurring between the reconstructed 3D intensity fields E(t) and E(t+At) isevaluated by means of spatial cross correlation analysis. The normalized cross-correlation functionR(4X,AY,AZ) reads as: The analysis is performed with an iterative technique based on the WIDIM algorithm (Scarano andRiethmuller, 2000) extended to three dimensional intensity fields, where the interrogation boxes aredisplaced/deformed on the basis of the result from the previous interrogation. The intensity field ofthe deformed volume at the k+Iiteration is obtained from the original intensity and the predictorvelocity field according to the expression: Where va=(uvwa) reprreepsreesrents the particle pattern deformation field obtained at the khinterrogation. The interrogation box size is progressively decreased from 121x121x61 to 41x41x21voxels in order to increase the dynamic range and decrease the number of spurious vectors. A 75%overlap factor is applied between neighboring boxes returning a vector spacing of 0.55 mm alongheight and length and 0.28 mm along the width respectively. The overall measurement grid counts64x64x30 vectors. Data validation based on a signal-to-noise ratio minimum threshold of 1.2, andon the normalized median test with maximum threshold of2, (Westerweel and Scarano, 2005)returns approximately 4% spurious vectors. The computation is performed with a custom madesoftware in MATLAB environment and takes approximately 12 hours (five iterations). However apreliminary analysis performed with DaVis 7.3 could be performed within 2 hours. The measurement precision is estimated observing the spatial distribution of velocity divergenceVV=0u/Ox+0v/0y+ow/Oz, whichcan be evaluated entirelyi ni nthree-dimensions. Intheincompressible flow regime the velocity field is solenoidal therefore VV is virtually zeroeverywhere, therefore the divergence RMS fluctuations
还剩9页未读,是否继续阅读?
北京欧兰科技发展有限公司为您提供《圆柱尾迹,湍流,三维相干结构中3D3C速度矢量场,速度场,体视速度场,层析速度场检测方案(粒子图像测速)》,该方案主要用于其他中3D3C速度矢量场,速度场,体视速度场,层析速度场检测,参考标准《暂无》,《圆柱尾迹,湍流,三维相干结构中3D3C速度矢量场,速度场,体视速度场,层析速度场检测方案(粒子图像测速)》用到的仪器有体视层析粒子成像测速系统(Tomo-PIV)。
