Hitachi High-Technologies Corporation Analysis of Sb in River Water (Electrothermal Method) ZA3000 INTRODUCTION : By using the twin injection function, newly installed to the ZA3000 series, antimony in river water was analyzed. By using the specially designed twin cuvette (Pyro D HR), a sample is injected into two different injection ports. As a result, the analysis can be performed without extending the drying time even when a large sample volume is injected. By a conventional instrument, it was difficult to detect 0.2 pg/L of antimony, 1/10 of the water quality standard concentration, without in-furnace concentration or other preparations. With the twin injection function, the detection without the concentration is possible, resulting in the improved measurement throughput. INSTRUMENT CONDITIONS MEASUREMENT PARAMETERS GA AUTOSAMPLER Element : Sb Instrument :ZA3000 Atomization :GA Wavelength : 217.6nm Lamp Current :10.0mA Slit Width : 0.4 nm Cuvette : Pyro D HR Meas. Mode : Working Curve Signal Mode : BKG CorrectedCurve Order :Linear Calculation : Peak Height Time Constant:: 0.1 sec Temp. Control::ON Sample Volume : 70 uLAddition : Speed:4 MATRIX MODIFIER Matrix Modifier : 1000 mg/L Pd+MgVolume: 10 uL Order : After TEMPERATURE PROGRAM NOTE Stage Initial/Final Heating/Keeping Gas Flow Rate Gas Temperature (C) (SeC) (mL/min) 1 Drying 50/110 40/0 200 Normal 2 Incineration 3 Atomization 2300/ 2300 110/300 20/0 200 Normal800/800 20/0 200 Normal0 /2 0 Normal 4 Cleaning 2800/2800 0/4 200 Normal Pyro D HR, the cuvette specially designed for twin injection, was usedfor the analysis. The sample was prepared by addingantimony to JSAC 0301 River Water Certified Reference Material to make a concentration of 0.2 pg/L. CONC(pg/L) Mean ABS SD RSD REF ABS 0.06- 2 STD 1 0.000 0.0032 0.0005 15.63% 0.2579 一 STD 2 0.500 0.0156 0.0008 5.13% 0.2785 一 STD 3 1.000 0.0294 0.0002 0.68% 0.2815一 1 STD 4 2.000 0.0522 0.0002 0.38% 0.2874 0.03 0.5 1 ND 0.0034 0.0006 17.65% 0.3406 2 0.197 0.0082 0.0001 1.22% 0.3463 0 R2:0.9992 0.00 ABS 0 1 2 KEY WORDS Atomic Absorption Photometer Environmental Analysis Related, Environmental Water, Clean Water, (AA) Environmental Chemistry, River Water, Antimony, Sb, Flameless, Graphite Furnace, AA, ZA3000, GA, Pyro D HR, Environment Sheet No. AA120006-00
关闭产品配置单
日立科学仪器(北京)有限公司为您提供《河水中重金属检测方案(原子吸收光谱)》,该方案主要用于环境水(除海水)中(类)金属及其化合物检测,参考标准《暂无》,《河水中重金属检测方案(原子吸收光谱)》用到的仪器有日立ZA4000系列原子吸收分光光度计。
