Measure Release Agenton a PolymerReinforced with Carbon Fiber The Agilent 4100 ExoScan Handheld FTIR Introduction Release agents are applied as a liquid that forms a thin film coating to aid removalof carbon-fiber-reinforced polymer (CFRP) parts from a mold or peel ply. This process,however,, .leads to inevitable contact transfer, causing release agent to remain on thepart or repair. Before painting or bonding of the CFRP component to other structures,proper post-treatmentto remove vaporizable components of the release agentisrequired.. Improper or inadequate post-treatment leads directly to reduction of bondstrength of joined parts or topcoat paint adhesion. The complexity of CFRP systemsrequires the use of new nondestructive analysis technologies such as FTIR spectroscopy.for the analysis of the surface matrix of the material. The primary objective of thisapplication note is to demonstrate that FTIR spectroscopy can nondestructively measurethe level of release agent on a carbon fiber epoxy system before bonding. The analysisusesanAgilent4100ExoScan FTIR.Thishandheld. spectrometer enablesS1in-situinspection during manufacturing, in-service, or repair environments,or ex-situ ina laboratory. The analysis is accomplished in less than 1 minute and does not requireany sample pretreatment. This work was part of a joint project commissioned by theEuropean Union entitled ENCOMB (extended nondestructive testing of composite bonds)[11. · Agilent Technologies
关闭产品配置单
安捷伦科技(中国)有限公司为您提供《碳纤维增强聚合物中脱模剂检测方案(红外光谱仪)》,该方案主要用于合成纤维中脱模剂检测,参考标准《暂无》,《碳纤维增强聚合物中脱模剂检测方案(红外光谱仪)》用到的仪器有Agilent 4300 手持式 FTIR 光谱仪。
