高纯度金属中定量分析检测方案(等离子体质谱)
检测样品
其他
检测项目
定量分析
关联设备
共1种
下载方案
Laser Ablation-ICP-MS (LA-ICP-MS) is used for the elemental analysis of solid samples and powders, including geological materials, ceramics, biological tissue and forensic samples. In this study, two calibration strategies (matrix matching and non-matrix matching) were used for the quantitative analysis of high purity metals. Since solid samples can be analyzed directly using LA-ICP-MS, minimal sample preparation is required compared to standard liquid sample introduction. This reduces the risk of analyte loss and eliminates the introduction of contaminants by avoiding the dissolution process. However, accurate quantitative analysis can be problematic for LA-ICP-MS analysis, due to lack of solid calibration standards. Preparing calibration standards for the analysis of solids is more difficult than for liquid sample analysis, and matrix-matched solid calibration standards that contain the analytes at suitable concentrations are rarely available. In a few cases, such as the metals industry, well-characterized, matrix-matched standards may already be available, since established analytical techniques such as Arc/Spark or Glow Discharge (GD) Optical Emission Spectroscopy (OES) utilize solid standards.
安捷伦科技(中国)有限公司为您提供《高纯度金属中定量分析检测方案(等离子体质谱)》,该方案主要用于其他中定量分析检测,参考标准《暂无》,《高纯度金属中定量分析检测方案(等离子体质谱)》用到的仪器有Agilent 7900 电感耦合等离子体质谱仪。
我要纠错
