吡咯里西啶生物碱中精确质量 Q-TOF LC/MS 及全离子MS/MS检测方案(液质联用仪)
检测样品
其他
检测项目
关联设备
共0种
下载方案
Pyrrolizidine
alkaloids (PAs) and their N
oxides (PANOs) have serious hepatotoxic
effects in both humans and animals, necessitating a method capable of detecting,
characterizing, and quantifying them using a robust assay. While triple quadrupole
LC/MS systems are ideal
for targeted detection, targeted analysis requires
standards that are not always easily obtained. Only a fraction of known naturally
occurring PAs are available as standards. Triple quadrupole analyses are also not
useful for screening unknowns. High
res
olution mass spectrometers that provide
accurate
mass data enable characterization of unknown PAs/PANOs without the
need for specific standards.
This application note presents a workflow that uses accurate
mass Q
TOF LC/MS,
with All Ions MS/MS and databas
e/mass spectral library searching, for the
selective and sensitive characterization, screening, tentative identification, and
quantification of PAs and PANOs in botanicals and dietary supplements.
Twenty
five PA/PANO standards were characterized using
their high
resolution
accurate
mass MS/MS spectra. These data were used to create a personal com
pound database and library (PCDL) that was then used to screen for PAs/PANOs in
44 botanical and dietary supplement samples. Quantitation was performed using
Q
TOF LC/MS response. PAs/PANOs not specifically targeted were tentatively
identified using characteristic fragment ions and fragmentation patterns. The
PAs/PANOs characterized could potentially lead to the discovery of more unique
PAs in additional botan
s.
安捷伦科技(中国)有限公司为您提供《吡咯里西啶生物碱中精确质量 Q-TOF LC/MS 及全离子MS/MS检测方案(液质联用仪)》,该方案主要用于其他中精确质量 Q-TOF LC/MS 及全离子MS/MS检测,参考标准《暂无》,《吡咯里西啶生物碱中精确质量 Q-TOF LC/MS 及全离子MS/MS检测方案(液质联用仪)》用到的仪器有null。
我要纠错
