有机污染物中使用 Agilent Plexa 萃取柱筛选检测方案(液质联用仪)
检测样品
环境水(除海水)
检测项目
有机污染物
关联设备
共1种
下载方案
EPA Method 540 has been run using the Agilent Plexa SPE cartridge, Agilent Infinity 1290 HPLC System, and the Agilent 6460 Triple Quadrupole LC/MS. Using all 17 compounds that were in the Draft Method 540, recoveries were well within the range specified by the method, with the exception of one compound. Precision easily met the method requirements for all 17 compounds. All LCMRLs were either near or significantly below EPA required levels, and the method run time was less than half that quoted for Method 540.
安捷伦科技(中国)有限公司为您提供《有机污染物中使用 Agilent Plexa 萃取柱筛选检测方案(液质联用仪)》,该方案主要用于环境水(除海水)中有机污染物检测,参考标准《暂无》,《有机污染物中使用 Agilent Plexa 萃取柱筛选检测方案(液质联用仪)》用到的仪器有Agilent 1200 系列液相色谱-芯片/质谱系统。
我要纠错
