星形聚苯乙烯中黏度检测方案(液相色谱仪)
检测样品
聚乙烯(PE)
检测项目
黏度
关联设备
共1种
下载方案
There has been increasing interest in the synthesis of star-branched polymers due to their unusual flow and viscosity properties compared to linear analogs. Starbranched polymers are constructed with several ‘arms’ radiating from a central core, either by preparing the individual arms and attaching them to a central molecule - the ‘arms first’ approach - or by growing the polymer arms from a central core - the ‘core first’ approach. Many commercial polymers can be constructed with a star-branched morphology relatively easily, but their characterization is still a challenge to the analytical chemist. Gel permeation chromatography (GPC) employing a concentration detector (typically a refractive index detector) combined with a viscometer can be used to measure not only the molecular weight of the materials but also to investigate the star-branched structure. The 390-MDS is ideal for this type of application since it was specifically designed to extract additional information from polymers by GPC. A series of PS star-branched polymers was analyzed, which had been synthesized by a ‘core first’ approach giving theoretical 5-, 14- and 21-arm structures.
安捷伦科技(中国)有限公司为您提供《星形聚苯乙烯中黏度检测方案(液相色谱仪)》,该方案主要用于聚乙烯(PE)中黏度检测,参考标准《暂无》,《星形聚苯乙烯中黏度检测方案(液相色谱仪)》用到的仪器有Agilent 1260 Infinity II 液相色谱系统。
我要纠错
