Www.coxem.com17 Overview SEM may be used to characterize the size, morphology and chemistry of paint, soil, and any other particlesassociated with construction materials. Solar Cell SEM can provide insights into the finestructure of solar cells, such as layer thicknessand surface topographies. These are usuallyon the micron scale so observing with opticalmicroscope is impossible. On identicalpositions, tilting the sample to 45 degrees cangive different information on the surface asshown below. Other Images SEM may be used to characterize the size, morphology and chemistry of paint, soil, and any other particles associated with construction materials.
关闭产品配置单
北京天耀科技有限公司为您提供《材料中新能源检测方案(扫描电镜)》,该方案主要用于其他中新能源检测,参考标准《暂无》,《材料中新能源检测方案(扫描电镜)》用到的仪器有库赛姆(COXEM)EM-30+ 台式扫描电镜。
