These samples would normally present problems due to the dissolved solids and the presence of HF. The use of the argon humidifier, sheath gas and the large ID injector tube from HORIBA Scientific ensures smooth running of these samples. For HF samples the use of the inert tangential nebulizer and the inert Scott spray chamber is required. The results show excellent detection limits for the original sample. A typical dilution factor would have degraded these figures by a factor of 10 when calculated in the original material.
关闭产品配置单
HORIBA(中国)为您提供《地质样品中元素检测方案(ICP-AES)》,该方案主要用于其他中元素检测,参考标准《暂无》,《地质样品中元素检测方案(ICP-AES)》用到的仪器有HORIBA Ultima Expert高性能ICP光谱仪。
