The semiquantitative results obtained for these 3 samples were close and often very close to the certified results. This high level of accuracy is due mainly to the high resolution of the ULTIMA 2 combined with the robust, radial view plasma. The high resolution eliminates spectral interferences and the robust, radial plasma provides few matrix effects, even in complex samples. Few matrix effects allow for rapid, easy method development.
关闭产品配置单
HORIBA(中国)为您提供《地质样品中元素检测方案(ICP-AES)》,该方案主要用于其他中元素检测,参考标准《暂无》,《地质样品中元素检测方案(ICP-AES)》用到的仪器有HORIBA Ultima Expert高性能ICP光谱仪。
