The analysis of V and Ni in bitumen enabled identification of the origin of the raw product. The preparation by emulsion is simple and it permits to use a classical ICP configuration (nebulizer, spray chamber, pump tubing).
关闭产品配置单
HORIBA(中国)为您提供《有机金属样品中元素镍和钒检测方案(ICP-AES)》,该方案主要用于其他中元素镍和钒检测,参考标准《暂无》,《有机金属样品中元素镍和钒检测方案(ICP-AES)》用到的仪器有HORIBA Ultima Expert高性能ICP光谱仪。
