ThermoFisherSCIENTIFIC 韩春霞 赛默飞世尔科技(中国)有限公司 关键词:离子色子;脉冲安培检测; CarboPac PA20;门冬氨酸;木糖醇;葡萄糖 Key words: IC; PAD; CarboPac PA20; aspartate; xylitol; glucose 门冬氨酸钾镁注射液是一种电解质补充药,用于低钾血症,低钾及洋地黄中毒引起的心律失常,病毒性肝炎,肝硬化和肝性脑病的治疗。它是一种复方制剂,其组分为门冬氨酸钾和门冬氨酸钾镁,部分制剂的辅料中含有木糖醇或葡萄糖。本方法可同时测定门冬氨酸钾镁注射液中含有的门冬氨酸和糖类物质。 仪器: ICS3000系统 分析柱: CarboPac PA20, 6.0pm, 150×3mm(P/N: 060142); 保护柱: CarboPac PA20, 6.0um, 30×3mm(P/N: 060144); 表1氨基酸六电位波形 时间 (s) 电位(V) 积分 0.000 0.130 0.040 0.130 0.050 0.330 0.210 0.330 On 0.220 0.550 0.460 0.550 0.470 0.330 0.560 0.330 Off 0.570 -1.670 0.580 -1.670 0.590 0.930 0.600 0.130 淋洗液: 0-7min, 40mmol/L NaOH; 7.1~17min,80 mmol/L NaOH/250mmol/L NaOAc; 17.1-20min,200mmol/L NaOH; 20.1-25min, 40mmol/L NaOH 流速:0.45mL/min; 定量环:10pL; 检测方式: Au电极, AgCI参比模式,脉冲安培检测器,氨基酸六电位波形,见表1。 结论 门冬氨酸钾镁注射液含有的糖类一般为木糖醇或葡萄糖,可与与门冬氨酸分离。而安培检测器可进一步提高方法的选择性。经过分析柱选择和梯度条件优化,可使三种测定物实现较好分离,标准溶液谱图见图1。方法线性良好,灵敏度高,重现性好。 图1标准溶液分离谱图 www.thermoScientific.com C2013 Thermo Fisher Scientific Inc. All rights reserved. ISO is a trademark of the International StandardsOrganization. All other trademarks are the property of Thermo Fisher Scientific Inc. and its subsidiaries. Thisinformation is presented as an example of the capabilities of Thermo Fisher Scientific Inc. products. It is notintended to encourage use of these products in any manners that might infringe the intellectual property rightsof others. Specifications,terms and pricing are subject to change. Not all products are available in all countries.Please consult your local sales representative for details. CE ( Thermo Fisher S cientific, Austin , TX USA i s ISO 9 001:2008 Certified. )
关闭产品配置单
赛默飞色谱与质谱为您提供《定门冬氨酸钾镁注射液中门冬氨酸和糖的含量检测方案(离子色谱仪)》,该方案主要用于化药制剂中含量测定检测,参考标准《暂无》,《定门冬氨酸钾镁注射液中门冬氨酸和糖的含量检测方案(离子色谱仪)》用到的仪器有赛默飞戴安ICS-4000毛细管离子色谱系统。
