<< Titration result >> 07-11 Date 2017/09/12 17:08:15 Model MKC-710(MCU-710) Time 00:01:20 Serial No. 20270615 Operator Method name Sample Anolyte Reagent Name Anolyte Anolyte Life Value 15 mg Catholyte Reagent Name Catholyte Catholyte Life Value 15 mg Drift Stop Rel. 0.10ug/s Control gain 5.0 t(stir) t(wait) 15 s t(max) Option Off Cell type Oven temp. 2-Comp. --- Deg.C Pre-Treat Back purge Cell purge Sample purge Calc.No. 2 Sample name Methanol Sample ID 20170912 Size(Size) * 0.7526 g Size(Wt1) * 0.7526 g Size(Wt2)* 0.0000 g Blank (Blank) 0.0000ug Revision Coef.(FA) 1.00000 Dissolve Samp. ( Wt0) g Conc.of Solvent (A ) -.----- ppm Dissolve Solvent (B) g Samp.Volume (V1) mL Samp.Dens. (Dens ) g/mL Samp.Gas Volume (V2) Recalculation comment Samp.Gas Temp. (Temp.) --Deg.C [Result] Conc. 0.0251% Moisture 189.0ug Drift 0.06 ug/s Detection temp. ---· Deg.C [Titration Curvel ( 京都电子 工 业株式会 社- 可睦电子 (上海 )商贸有限公 司 ) << Titration result >> Model MKC-710(MCU-710) Time 00:01:20 Serial No. 20270615 Operator Method name Sample Anolyte Reagent Name Anolyte Anolyte Life Value 15 mg Catholyte Reagent Name Catholyte Catholyte Life Value 15 mg Drift Stop Rel. 0.10ug/s Control gain 5.0 t(stir) t(wait) 15 s t(max) Option Off Cell type Oven temp. 2-Comp. --- Deg.C Pre-Treat Back purge Cell purge Sample purge Calc.No. 2 Sample name Methanol Sample ID 20170912 Size(Size) * 0.7440 g Size(Wt1) * 0.7440g Size(Wt2) * 0.0000 g Blank (Blank) 0.0000ug Revision Coef.(FA) 1.00000 Dissolve Samp. ( Wt0) g Conc.of Solvent (A ) -.----- ppm Dissolve Solvent (B) g Samp.Volume(V1) mL Samp.Dens. (Dens ) g/mL Samp.Gas Volume (V2) Recalculation comment Samp.Gas Temp. (Temp.) --Deg.C [Result] Conc. 0.0253% Moisture 188.3ug Drift 0.06 ug/s Moisture 188.3 Drift 0.06 ug/s Detection temp. Deg.C [Titration Curvel ( 京都电子 工 业株式会 社- 可睦电子 (上海 )商贸有限公 司 ) << Titration result >> Model MKC-710(MCU-710) Time 00:01:11 Serial No. 20270615 Operator Method name Sample Anolyte Reagent Name Anolyte Anolyte Life Value 15 mg Catholyte Reagent Name Catholyte Catholyte Life Value 15 mg Drift Stop Rel. 0.10ug/s Control gain 5.0 t(stir) t(wait) 15 s t(max) Cell type 2-Comp. Option Off Oven temp. --- Deg.C Pre-Treat Back purge Cell purge Sample purge -s Calc.No. 2 Sample name Methanol Sample ID 20170912 Size(Size)* 0.7445 g Size(Wt1) * 0.7445g Size(Wt2)* 0.0000 g Blank (Blank) 0.0000ug Revision Coef.(FA) 1.00000 Dissolve Samp. ( Wt0) g Conc.of Solvent (A ) -.----- ppm Dissolve Solvent (B) g Samp.Volume(V1) mL Samp.Dens. (Dens ) g/mL Samp.Gas Volume (V2) Recalculation comment Samp.Gas Temp. (Temp.) --Deg.C 「Result] Conc. 0.0251 Moisture 186.9ug Drift 0.09 ug/sDetection temp. ---· Deg.C [Titration Curvel ( 京都电子 工 业株式会 社- 可睦电子 (上海 )商贸有限公 司 ) -Measurement results- Statistics Sample size (g) Moisture(ug) Conc.(%) MeanSDRSD 0.0252%0.0001%0.3968% 189.0188.3186.9 0.02510.0253 0.0251 海市徐汇区宜山路电话: 电邮:kemu-kem@com网址: http://www.kem-china. com 库仑电量法卡尔费休水分仪测定甲醇(Methanol)中水分含量 使用京都电子(KEM)-库仑电量法卡尔费休水分仪(MKC-710S),测定甲醇(Methanol)中水分含量的应用资料。
关闭还剩2页未读,是否继续阅读?
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《甲醇中水分含量检测方案(卡氏水分测定)》,该方案主要用于醇中水分含量检测,参考标准《暂无》,《甲醇中水分含量检测方案(卡氏水分测定)》用到的仪器有MKC-710S豪华型库仑法卡尔费休水分仪、库仑法卡尔费休试剂。
