Laser induced fluorescence measurements of the thickness of fuel films on the combustionchamber surface of a gasoline SI engine by M.C. Jermy, T. Noel and W.G. Doherty DAMSE, School of Engineering Cranfield University Cranfield Beds MK43 0AL United Kingdom http://www.cranfield.ac.uk/soe/departments/optical.htm E-Mail: m.jermy@cranfield.ac.uk ABSTRACT Up to 90% of the unburnt hydrocarbon emissions (UHCs) from modern 4-stroke gasoline engines occur during coldstarting. Slow vapourisation particularly from films of fuel in the intake port, and on the manifold and cylinder walls leadsregions of rich mixture and incomplete combustion. To reduce UHCs it is useful to know where, and how thick, these wallfilms are during the intake and compression strokes. In the present work the fuel film is imaged and its depth measured with a laser induced fluorescence technique. Thetechnique uses a with a pulsed laser, diffuse illumination and a camera and images the film on the metal combustionchamber surface, in an inexpensive rig closely approximating the flow in an port injected gasoline engine under coldstart. The temporal resolution of~100ns and spatial resolution of~0.5mm are sufficient to reveal the detailed dynamics ofthe film formation and transport. The technique functions well in the imperfect optical environment of a piston engine cylinder. In contrast to previousstudies the film depth is measured, quantitatively, on the metal combustion chamber surface with correct roughness andfilm transport properties, rather than on a smooth glass wall. The uncertainty in depth is ±16um but may be reduced to±5um. With open valve injection a 30±16um thick film forms on the exhaust side cylinder wall. Such films lead to highunburnt hydrocarbon (UHC) emissions. The technique has high temporal (100ns) and spatial (0.5mm) resolution and maybe applied to acceleration transients, lubricating oil films, GDI and Diesel engines. 1.INTRODUCTION Up to 90% of the unburnt hydrocarbon emissions (UHCs) from modern 4-stroke gasoline engines occur during coldstarting (Heywood 1988, Cheng et al. 1993, Stanglmaier et al. 1999). Films of fuel in the cylinder vaporise slowly when theengine is cold and unburnt fuel can persist until swept out during the exhaust stroke. To reduce UHCs it is useful toknow where, and how thick, these wall films are during the intake and compression strokes. Of the many methods which have been used to measure wall film thickness, laser induced fluorescence (LIF) has beenone of the most successful in i.c. engines. The film is illuminated with a laser and a fluorescent compound in the fuelemits red-shifted light with an intensity which depends on the film depth. LIF offers a signal that is robust in the dirtyoptical environment inside a piston engine. It has been applied to the fuel films formed in intake manifolds and cylindersof spark ignition (SI) engines in several optical configurations: using fibre optics to carry the signal and/or exciting light(Felton et al. 1995, Johnen and Haug 1995, Hentschel et al., 1997), to measure a fuel film on a transparent surface by totalinternal reflection (Heavens and Gingell 1991, Evers and Jackson 1995, Coste and Evers 1997, Kull et al. 1997) or withouttotal internal reflection (Le Coz et al. 1994, Cho and Min 2003, Senda et al. 1999), by illumination and detection through awindow to measure the fuel film on the metal splitter separating the two branches in a Siamesed port (Almkvist et al.1995), and to visualise fuel on the inner metal surfaces of the cylinder, though without quantitative measurement of thethickness (Witze and Green 1996, 1997). In the present work the technique is implemented with a pulsed laser, diffuse illumination and a camera, in an inexpensiverig closely approximating the flow in an SI engine under cold start. In contrast to previous studies the film depth ismeasured, quantitatively, on the metal combustion chamber surface, rather than on a smooth glass surface. 2.EXPERIMENTAL METHOD and PROCEDURES 2.1 Test rig The test rig (Fig. 1) approximated the intake and cylinder flow of a six cylinder 4-valve port-fuel-injected 2.5 litre engine attcold start and idle. It had similar optical access to a typical single cylinder optical research engine. A bellmouth tcmeasure the air mass flow was followed by a 25litre plenum to reduce the flow oscillation in the bellmouth. This wasfollowed by a throttle and a section of production intake manifold in which the fuel injector was mounted. This fed theintake port of a 4-valve cylinder head. The intake valves were operated by a camshaft driven by an electric motor. Theexhaust valves were kept permanently shut. The combustion chamber surface was anodised. A fused silica cylinder ofthe correct diameter took the place of the cylinder bore. The lower end of the cylinder has a machined metal unicontaining a flat fused silica window at the base and above this four outlets connecting the cylinder to a centrifugal fan.This was used in place of the piston to draw air through the rig. View calibration plate by removing T and turning R through 45° Figure 1 Schematic ofthe rig A cold start engine operating condition was simulated. The cam speed was 650rpm (i.e. crank speed 1300rpm), the airmass flow was 2.8gs and the cylinder pressure 912Pa below ambient i.e. 101,288Pa absolute. The inlet valve openedapproximately 30° after top dead centre (ATDC) and closed approximately 276°ATDC. The injection duration was 7.3mswith end of injection at 120°ATDC i.e. open valve injection. All angles are crank angles i.e. there are 720° for onerevolution of the camshaft. In a real engine, fuel films would be largely evaporated or burnt by the flame every cycle. Since the rig used here doesnot ignite the fuel there is a risk of fuel persisting from previous cycles and giving an overestimate of the amount of fuelpresent in film form. For this reason fuel was injected only every tenth cycle. This was found to be sufficient for the airflow to clear the cylinder of fuel before the next injection. 2.2Optical layout A Spectra Physics Quanta Ray Nd:YAG laser with Type II SHG crystal produced 540mJ pulses of 532nm light. The beamwas expanded with a -50mm focal length spherical lens and directed through the base of the fused silica cylinder toilluminate the head (Fig. 1). A LaVision SprayMaster 3 CCD camera with IRO image intensifier, 50mm Nikon lens at f/2.8viewed the head through the fused silica cylinder, via a mirror. The intensifier gate was 200ns. A 2mm thick Schott RG610filter passed the fluorescence and blocked the reflected 532nm light. The fuel was a mixture of hydrocarbons with average molecular weight 80 plus ~0.1wt% disodium fluorescein. 2.3 Calibration A tray filled with fuel was illuminated and imaged with the same imaging equipment at the same distances as were usedto image the head. The tray depth varied across the base. The cylinder section was treated to achieve the same surfacefinish as the cylinder head. Intensity versus depth curves were extracted for two 10 pixel high horizontal strips. The intensity versus depthrelationship depends on the distance of the imaged region from the camera since the camera viewed both calibration trayand head obliquely, giving a perspective effect. The intensity versus depth curves are given in Fig. 2. Figure 2 Intensity versus depth relationship 2.4 Imaging of the head and data processing Images were taken every 40°. 10 data (i.e. air on, fuel on) and 10 background (air on, fuel off) images were taken at each ofthe same crank angles and averaged. To further reduce the effects of laser power fluctuation, the averaged image at each crank angle was multiplied by afactor. The factor was calculated to make the intensity in a chosen region of the image the same as the intensity in thisregion averaged over all crank angles. The region chosen was a strong reflection breaking through the filter from a spotnear the cylinder wall. Were the laser power constant the intensity at this point would not change with crank angle. The background subtracted images were corrected for the spatially non uniform illumination by dividing by a normalisedimage ofthe laser beam falling on a white card inserted underneath the head. The data images were then background subtracted. Sequences of processed images are shown in Fig. 3. The images are in false colour with hot colours indicating highintensities. Crank angles after top dead centre are marked in the top left corner. 3. DISCUSSION 3.1 Calibration The calibration curves shown in Fig. 2 have a nonzero intercept since the cylinder section is not completely submergedand a thin film of fuel is held by surface tension on the exposed part. Therefore there is an offset error on the depth axisof Fig.2, however only the slope and not the intercept of this plot is used. At depths greater than 200um the cylinder iscompletely submerged and any meniscus effects have decayed, and the curves are approximately linear. The absorptionof the beam by the fuel follows the Beer-Lambert law so the curves should be weakly exponential if measured with verylow noise. A linear fit to the section between 200 and 1000um is shown superimposed on each curve. The slope of thesefits is used below to estimate the depth of films imaged in the rig. The curve from pixel rows farther from the camera have a higher intensity. This is due to the perspective effect (a singlepixel covers a larger real area the farther it is from the camera) and the angle of view (the further from the camera the moreoblique the line of sight and the more fuel it passes through). The curves are noisy due principally to imperfect mixing of the dye in the fuel. This noise determines the depthresolution. However the noise on the intensity/depth function is expected to be lower than that in Fig. 2 for the reasonsgiven in the next paragraph. When the calibration curves were measured the laser intensity was actually 19.3mJ/pulse and the camera aperture f/8Then intensity/depth slope will be linear with power and aperture so the y-axis of Fig. 2 has been scaled by a factor of248 to account for the greater intensity and aperture used in the rig measurements giving a slops of ~59 counts/micronfor the rig measurements. The noise fluctuations in the original calibration curves are ±20 counts amplitude. The noiseamplitude in the rig measurements will differ for several reasons: it will increase by the square root of the laser power andaperture increases, i.e. to 20xv248=314. There is an additional uncertainty due to the dye deposits in the rig causingimperfect background subtraction. By inspection of the background images this is estimated to be ±900 counts. Addingthe uncertainties due to noise and background in quadrature gives an uncertainty level of ±953 counts or ±16um. Inaddition to the power and aperture changes, the fuel was better mixed for the rig measurements. This will decrease in thenoise by an unknown amount. The depth uncertainty can be further reduced by reducing the laser power fluctuation, by reducing the background,andby increasing the laser power to increase the slope of the intensity versus depth curve. If the background subtractionuncertainty alone can be reduced to ±50 counts, for example by using a more soluble dye, the depth uncertainty can bereduced to ±5um. 3.2 In-cylinder images The images are in Fig. 3. The most striking feature of the fuel behaviour begins at 145° when fuel emerges from the inletvalves and crosses the cylinder to the exhaust side. From white light imaging tests the fuel is known to be at least partlyairborne while crossing the chamber. Here it strikes the wall and forms a film on the cylinder wall. This film persists atleast until the next TDC (~50ms), but since it is not seen at the beginning of the sequence and injection occurs every.tenth cam cycle, it must dissipate in less than ten cycles (~1s). The film forms where the domed combustion chamber meets the cylinder bore, forming a sheltered ‘corner’. The airvelocity component parallel to the wall is likely to be weak here. Mixing of the fuel evaporating from this wall film into therest of the cylinder is likely to be poor, leading to rich burn here and high UHC and CO emissions. The authors of(Stanglmaier et al. 1999) deposited artificial gasoline films at various points in the cylinder of an SI engine running onvapourised propane, and found that deposits in this region,the exhaust-side cylinder wall, caused the greatest rise inUHC emissions. Figure 3 Sequence ofprocessed images showing one complete cam cycle. Crank angles after top dead centre aremarked in the top left corner. The intensity of the fluorescence indicates the film thickness is 30±16um here. The result agrees well with Cho and Min(2003) in which a maximum thickness of 45um was observed, albeit under different operating conditions. The images show regions of high intensity which change little through the cycle, e.g. around the edges of the inletvalves. At least part of the intensity here is caused by deposits of dye left by evaporating fuel. This leads to imperfectbackground subtraction. 4. CONCLUSIONS Laser induced fluorescence has been used to image and measure the depth of fuel films on the inner metal surfaces of arig that mimics a port fuel injected i.c. engine. In contrast to previous studies the film depth is measured, quantitatively,on the metal combustion chamber surface, with the correct surface roughness and film transport properties, rather thanon a smooth glass surface. The technique functions well in the imperfect optical environment of the rig. The depthuncertainty is ±16um but it seems possible to reduce this to ±5um. The most significant problems were caused by thebuild up of dye deposits. The results show that with open valve injection a film of 30±16um depth forms on the exhaust side cylinder wall. This islikely to result in high UHC emissions. The technique could be applied in the manifold or port of port injected engines to study spray targeting and filmbehaviour during transients such as acceleration, or to study the fuel films in the cylinder that contribute to unburnthydrocarbon, CO and soot emissions, and spark plug fouling. The technique could also be applied to fuel films ingasoline direct injection and Diesel engines, or to lubricant oil films. 5.ACKNOWLEDGEMENTS We would like to thank Jaguar Cars for funding this work, and S Pierson, M Haste and XD Xie of Jaguar cars for manyuseful discussions. We would like to thank Brian Scully and the late Bob Wilson for technical and moral support. REFERENCES ( Almkvist G, Denbratt I , J osefsson G, Magnusson I“Measurement of fuel film thickness in the inlet port of an SI engineby laser induced fluorescence"SAE Technical Paper Series 952483 ) ( Cheng W , Harmrin D , H e ywood J, H o chgreb S, M i n KD and Nor r is M“ A n o verview of hydr o carbon emis s ions mechanisms in spark-ignition engines”, SAE Trans. 10 2 (1993) 1207-1230 ) Cho H, Min K, “Measurement of liquid fuel film distribution on the cylinder liner of a spark ignition engine using thelaser-induced fluorescence technique”, Meas. Sci. Tech.. 14 (2003) 975-982 Coste TL, Evers LW, “An optical sensor for measuring fuel film dynamics of a port-injected engine”, SAE TechnicalPaper Series 970869 Evers LW, Jackson KJ,“Liquid film thickness measurements by means of internally reflected light”, SAE Technical PaperSeries 950002 Felton PG, Kyritsis DC, Fulcher SK, “LIF visualization of liquid fuel in the intake manifold during cold start”, SAETechnical Paper Series 952464 Heavens OS, Gingell D,“Film thickness measurement by frustrated total reflection fluorescence”, Optics and lasertechnology 23 3 (1991) 175 Hentschel W, Grote A, Langer O,“Measurement of wall film thickness in the intake manifold of a standard production SIengine by a spectroscopic technique" SAE Technical Paper Series 972832 Heywood J,“Internal Combustion engine Fundamentals”(1988) New York: McGraw Hill Johnen T, Haug M, “Spray formation observation and fuel film development measurements in the intake of a sparkignition engine”, SAE Technical Paper Series 950511 Kull E, Wiltafsky G, Stolz W, Min KD and Holder E, “Two dimensional visualization of liquid layers on transparentwalls”,Opt. Lett.,22 9(1997)645-647 Le Coz JF, Catalano C, Baritaud T“Application of laser induced fluorescence for measuring the thickness of liquid filmson transparent walls”, Proc. 7" Int. Symp. On Applications of Laser Techniques to Fluid Dynamics, ed. Adrian RJ,Lisbon, Portugal, 1994, pp.29.3.1-29.3.8 Senda J, Ohnishi M, Takahashi T, Fujimoto H, Utsunomiya A and Wakatabe M“Measurement and modelling on wallwetted fuel film profile and mixture preparation in intake port of SI engine" SAE Technical Paper Series 1999-01-0798 Stanglmaier RH, Li J, Matthews RD,“The effect of in-cylinder wall wetting location on the HC emissions from SIengines”,SAE Technical Paper Series 1999-01-0502 Witze, PO, Green RM,“LIF visualization of liquid fuel in the cylinder of a spark ignition engine” Proc. 8" Int. Symp onApplications of Laser Techniques to Fluid Mechanics, Lisbon, Portugal, 1996 Witze PO, Green RM,“LIF and Flame emission imaging of liquid fuel films and pool fires in an SI engine during asimulated cold start", SAE Technical Paper Series 970866 Up to 90% of the unburnt hydrocarbon emissions (UHCs) from modern 4-stroke gasoline engines occur during coldstarting. Slow vapourisation particularly from films of fuel in the intake port, and on the manifold and cylinder walls leadsregions of rich mixture and incomplete combustion. To reduce UHCs it is useful to know where, and how thick, these wallfilms are during the intake and compression strokes.In the present work the fuel film is imaged and its depth measured with a laser induced fluorescence technique. Thetechnique uses a with a pulsed laser, diffuse illumination and a camera and images the film on the metal combustionchamber surface, in an inexpensive rig closely approximating the flow in an port injected gasoline engine under coldstart. The temporal resolution of ~100ns and spatial resolution of ~0.5mm are sufficient to reveal the detailed dynamics ofthe film formation and transport.The technique functions well in the imperfect optical environment of a piston engine cylinder. In contrast to previousstudies the film depth is measured, quantitatively, on the metal combustion chamber surface with correct roughness andfilm transport properties, rather than on a smooth glass wall. The uncertainty in depth is ±16mm but may be reduced to±5mm. With open valve injection a 30±16mm thick film forms on the exhaust side cylinder wall. Such films lead to highunburnt hydrocarbon (UHC) emissions. The technique has high temporal (100ns) and spatial (0.5mm) resolution and maybe applied to acceleration transients, lubricating oil films, GDI and Diesel engines.
关闭还剩6页未读,是否继续阅读?
北京欧兰科技发展有限公司为您提供《火花塞引燃汽油发动机中燃烧室表面燃料薄膜的厚度检测方案(尾气检测)》,该方案主要用于汽车电子电器中理化分析检测,参考标准《暂无》,《火花塞引燃汽油发动机中燃烧室表面燃料薄膜的厚度检测方案(尾气检测)》用到的仪器有汽车发动机多参量测试系统、德国LaVision PIV/PLIF粒子成像测速场仪、PLIF平面激光诱导荧光火焰燃烧检测系统、LaVision HighSpeedStar 高帧频相机、LaVision SprayMaster 喷雾成像测量系统。
