戴安公司技术注解 AN329 AN328 用加速溶剂萃取(ASE)技术土壤中的炸药(HMX, RDX, TNT, DNT) 样品基体::土壤 仪器: Dionex ASE200 Dionex DX500 HPLC (带有AD20, UV/Vis 检测器) GC(带有ECD) 溶剂(农药级): 甲醇,丙酮 ASE 操作条件: 系统压力: 10.3Mpa (1500psi) 温度: 100℃ 样品量: 2.5一30g 加热时间: 5min 静态时间: 5min 冲洗体积: 60% 溶剂: 丙酮和甲醇 吹扫时间: 1Mpa(150psi), N2,200秒 静态循环次数: 1次 全部萃取时间: 14min 溶剂用量: 每个样品17-50mL 样品制备: 样品经干燥、研磨和过筛,颗粒大小小于 1mm。2.5g湿的土壤样品与0.8g硅藻土混合后,放于萃取池内。 HPLC分析条件: (1) HMX, RDX, TNT, DNT 柱: SUPELCOSIL LC-18,25-cm×4.6mm, i.d.,5um 流动相:5%异丙醇(在甲醇:水=32:68中) 流速:2.0mL/min 检测器: UV,254nm 进样体积:25uL (2)代谢物 柱: Nucleosil 120-7-C-18,25cm×1.0mm.i.d.,7um 流动相: 甲醇/水,40%甲醇~56%甲醇(30min) 流速:0.8mL/min 检测器: UV,254nm 进样体积:20uL GC分析条件: 柱: DB-5,30m×0.25mm i.d.,0.25um 薄层 进样器:裂解温度(50:1)250℃, 1uL 检测器: ECD,300℃ 温度程序:40℃,保持2min; 以10℃/min 速率升至250℃,保持 5min 载气: He, 2cm/s Table 1 Recovery fron spiked soil at the 3 ing/kg level Sample HIAXmg/kg RDXmg/kg TNTmg/kg DNTmg/kg 1234AverageRecovery (%) RSD(%) 3.D72.992.992.842.9799.D3.2 3.062.892.862.742.8996.34.6 3.033.022.922.812.9598.33.5 3.143.D73.062.973.061022.3 Table 3 Results from soil B, HPLC analysis Compound Sonicationmg/kg ASEmg/kg 2.4-dinitrotolueneINT 1.3.5-trinitrobenzene 4-amino-2,6-dinitrotoluene 2-amino-4,6-dinitrotoluene Hexogene [RDX] D.02630.1D.2J3D.3J2D.434D.154 D.02345.6D.320D.674D.6JJD.609 Table 5 Results from soil D, HPLC analysis Compound Sonicationmg/kg ASEmg/kg 2.6-dnitrotoluene 2.4-dinitrotolueneTNT 1,3.5-tinitrobenzene 4-aminp-2.6-dinitrotoluene 2-aminp-4,6-dinitrotaluene Hexogene [RDX] n.d.D.16483.93.381.031.81D.436 n.d.D.16595.43.8J1.442.122.15 Table 7 Results from soil B, GC analysis Compound Sonicationmg/kg ASEmg/kg 2.4-di nitrotolueneTNT 1.3.5-trinitrobenzene 4-aminp-2.6-dinitrotoluene 2-amino-4.6-dinitrotaluene D.03630.7D.4343.413.51 D.1639.41.323162.96 Table 9 TNT fron wet, heavily contaminated soil Sample TNT Recovery, mgkg 1 234 AverageRSD (%) 3650 353032903200342D 6.1 分析结果: 表 2~6是用 ASE 和超声萃取两种方法分别得到的萃取液经 HPLC 测定后的结果。表7~8是用ASE 和索氏提取法分别得到的萃取液经 GC-ECD 测定后的结果。 Table 2 Results from soil A, HPLC analysis Compound Sonicationmg/kg ASEmg/kg 2.6-dinitrotoluene 2.4-dinirotolueneTNT 1,3.5-tinitrobenzene 4-aminp-2.6-dinitrotoluene 2-amino-4.6-dinitrotoluene Hexogene (RDX) n.d.D.1981032.355.346.0926.5 n.dD.2531283.459.309.3993.0 Table 4 Results from soil C, HPLC analysis Compound Sonication ASE mg/kg mg/kg 2.6-dinitotoluene n.d. n.d. 2.4-dinitrotoluene D.095 D.186 TNT 4.55 4.74 1.35-tinitrobenzene n.d. D.069 4-amino-2,6-dinitrotoluene 1.68 3.64 2-amino-4,6-dinitrotoluene 2.05 3.36 Hexogene [RDX] n.d. n.d. Table 6 Results from soil E, HPLC analysis Compound Sonicationmg/kg ASEmg/kg 2-nitrotoluene 3-nitrotoluene 4-nitrotoluene 2.6-dnitrotoluene 2.4-dnitrotolueneINT 1,3.5-tinitrobenzene 4-amino-2.6-dinitrotoluene 2-amino-4,6-dinitrotoluene Hexogene (RDX) 2.51D.136D.384D.295D.1J218.1D.8141.46D.89020.7 3.80D.312D.914D.588D.33526.81.623.231.9082.5 Table 8 Results from soil D, GC analysis Compound Sonicationmg/kg ASEmg/kg 2.6-dinitrotoluene 2.4-di nitrotolueneINT 1.3.5-tinitrobenzene 4-amino-2.6-dinitrotoluene 2-aminp-4.6-dinitrotoluene D.019D.21873.44.567.207.69 n.d.D.33374.49.7212.511.5
关闭产品配置单
赛默飞色谱与质谱为您提供《土壤中炸药检测方案(快速溶剂萃取)》,该方案主要用于土壤中其他检测,参考标准《暂无》,《土壤中炸药检测方案(快速溶剂萃取)》用到的仪器有赛默飞Dionex ASE 150快速溶剂萃取仪。
