北京豫维科技有限公司联系人:水先生电话:189118499232016, Vol.39 No.I 乳业科学与技术※分析检测 北京豫维科技有限公司联系人:水先生电话:18911849923※分析检测2016, Vol.39 No.1Journal of Dairy Science and Technology12 高效液相色谱法测定乳粉中异构化乳糖的含量 刘丽君,李素琴,赵 贞*,岳虹,李翠枝,邵建波 (内蒙古伊利实业集团股份有限公司,内蒙古呼和浩特 010110) 摘 要:建立乳粉中异构化乳糖高效液相色谱的测定方法。采用盐酸沉淀蛋白,氨基色谱柱分离,流动相为80%乙腈溶液, 示差检测器检测。每100g乳粉中异构化乳糖添加量为0.3~2.0g时,回收率97.4%~103.0%。定量检出限为0.3 g/100 g。该方法操作简便,检测准确,可用于乳粉中异构化乳糖的检测。 关键词:高效液相色谱法;异构化乳糖;乳粉 High Performance Liquid Chromatography Determination of Lactulose in Milk Powder LIU Lijun, LI Suqin, ZHAO Zhen*, YUE Hong, LI Cuizhi, SHAO Jianbo (Inner Mongolia Yili Industrial Group Co. Ltd., Hohhot 010110, China) Abstract: A method for the determination of lactulose in milk powder by high performance liquid chromatography (HPLC)was developed. Lactulose was extracted with water. The analysis was performed on a NH, column using 80% acetonitrile inwater as the mobile phase. The recovery of lactulose spiked into milk powder in the range of 0.3-2.0 g/100 g was 97.4%-103.0%. The limit of detection was 0.3 g/100 g. The results indicated that this method is accurate, simple and suitable for theanalysis of lactulose in milk powder. Key words: high performance liquid chromatography (HPLC); lactulose; milk powder 中图分类号: TS252.7 文献标志码: A 文章编号:1671-5187(2016)01-0011-03 DOI:10.15922/j.cnki.jdst. 2016.01.004 引文格式: 文丽君,李素琴,赵贞,等.高效液相色谱法测定乳粉中异构化乳糖的含量[J].乳业科学与技术, 2016,39(1):11-13.DOI:10.15922/j.cnki.jdst. 2016.01.004. http://rykj.cbpt.cnki.net LIU Lijun, LI Suqin, ZHAO Zhen, et al. High performance liquid chromatography determination of lactulose in milk powder]Journal of Dairy Science and Technology, 2016, 39(1): 11-13. DOI:10.15922/j.cnki.jdst. 2016.01.004. http://rykj.cbpt.cnki.net 异构化乳糖,又称乳酮糖和乳果糖",研究表明,异构化乳糖具有促进双歧歧菌增殖12~,改善肠道菌群7,防止便秘,增强机体免疫8-11,促进人体对钙、镁的吸收等作用21,因此异构化乳糖可广泛用于保健食品中,可添加到乳饮料、碳酸饮料、果汁饮料、糖果、乳粉等食品中作膳食疗效食品,也可单独作医疗用品3.15. 目前,测定异构化乳糖的方法包括分光光度法116-17、液相-质谱法8]、离子色谱法119.211、薄层色谱法I22-23]、液相色谱法(24-261等。分光光度法前处理复杂结果易受干扰,检测需要多种酶试剂费用高,对人员要求较高;液相-质谱法和离子色谱法定量准确,但是仪器价格昂贵或普及率低,不便于日常监测;薄层色谱法灵敏度低,只能作半定量分析,不能准确定量;以上方法均不便在实际检测中应用。本实验建立液相色谱检测异构化乳糖的方法 ( 收稿日期:2015-09-11 ) 具有准确、快速、成本低等特点,是目前检测异构化乳糖的理想的方法。 1 材料与方法 1.1 材料与试剂 婴幼儿配方乳粉 内蒙古伊利集团。 乙腈(色谱纯) 德国CNW科技公司;盐酸(优级纯) 天津市化学试剂三厂;异构化乳糖标准品美国Sigma公司。 1.2 仪器与设备 1260型液相色谱仪(带示差检测器) 美国Agilent公司; AB265-S型分析天平 瑞士Mettler-Doledo(上海)公司; GE013型超声清洗器 昆山超声仪器有限公司。 ( 作者简介:刘 丽 君(1972一),女,高级工程师,本科,研究方向为乳制品品质安全监控。 E-mail: liulijun@yili.com ) ( *通信作者:赵贞(1983一),女,工程师,硕士,研究方向为乳 品 检测:E-mail: jtzhaozhen@vili.com ) ( 万方数据 网址: Www. y uweichina. com 邮 箱wa ter1102@163. com ) 1.3 方法 1.3.1 色谱条件 色谱普:氨基柱(250 mm×4.6 mm, 3 um); 流速::1mL/min;进样量:20uL;柱温:40℃;流动相为乙腈:水=80:20(V/V)。 1.3.2 标准溶液配制 异构化乳糖储备液(10mg/mL):分别称取0.5g(精确至0.0001g)异构化乳糖标准品于50mL容量瓶中,用水溶解定容,4℃冰箱中保存。 异构化乳糖标准工作液:分别吸取异构化乳糖标准储备液0.3、0.5、1、2、5mL,用水定容到10 mL 容量瓶中。该标准系列质量浓度分别为0.3、0.5、1、2、5 mg/mL。临用前配制。 1.3.3 样品处理 称取5g样品, 加入15 mL 45~50℃水充分溶解、摇匀,超声10 min, 用4 mol/L盐酸溶液调pH值至4.60,将溶液定量转移到50 mL容量瓶中,并用水定容至刻度,摇匀后再超声10 min。混匀后经滤纸过滤,滤液再经0.45 p.m微孔滤膜过滤,供液相色谱分析。 1.3.4 乳糖含量计算 式中:x为样品中异构化乳糖含量/(g/100g);p为试样待测液夜异异化乳糖的质量浓度/(mg/mL);V为定容体积/mL;m为称样质量/g。 2 结果与分析 2.1 标准曲线、线性范围和检出限 将异构化乳糖标准工作液在上述色谱条件下测定,以标准溶液的质量浓度为横坐标(x),峰面积为纵坐标(y),绘制标准曲线,异构化乳糖的线性方程y=135 366.6x+1 449.8(0.999)。线性范围为0.3~2.0g/100g。按照信噪比 (RSN)=10计算得出3种异构化乳糖的定量检出限为0.3 g/100 g。 异构化乳糖标准品和样品色谱图见图1~2。 图1 异构化乳糖标准品HPLC色谱图 Fig.1 HPLC chromatogram of standard solution of lactulose 图2 乳粉样品HPLC色谱图 Fig.2 HPLC chromatogram of milk powder 由图1可知,异构化乳糖保留时间分别为13.820 min;由图2可知,乳粉样品中异构化乳糖保留时间分别为13.787 min。 2.2 方法的回收率和精密度 在空白乳粉样品中分别添加不同量的异构化乳糖,进行回收率实验,平行测定6次,结果见表2. 表2 空白样品添加回收率结果 Table 2 Recoveries of lactulose spiked into blank sample 添加量/(g/100g) 0.3 1 2 平均回收率/% 103.0 97.4 101.0 表3 乳粉样品精密度结果 Table 3Precision for replicate determinations of milk powder 项目 精密度/(g/100g) 相对标准偏差/% 异构化乳糖 0.416、0.428、0.416、0.425、0.424、0.422 1.17 由表2可知,每100g牛乳中异构化乳糖添加量为0.3、1、2g时,异构化乳糖平均回收率为97.4%~103.0%,由表3可知,对添加300 mg/100 g异构化乳糖的样品分别进行6次重复性实验,相对标准偏差分别为1.17%。 2.3 样品前处理优化 由于方法采用示差检测器,具有参比的特殊性,所以样品不宜选用重金属盐类或甲醇作为沉淀剂,这类沉淀剂导致样品峰型差,检测灵敏度低;选择水溶解样品,盐酸调pH值沉淀蛋白,样品出峰稳定、峰型好、灵敏度高。 2.4 色谱条件的选择 选择粒径5p.m的氨基柱,调节流动相乙腈和水的比例,但出峰时间早,异构化乳糖和乳糖分不开,出峰时间晚可以分开但是峰型展宽,灵敏度降低,为了保证灵敏度和较短检测时间选择柱效高的3u.m粒径的氨基柱,在短时间内可以实现分离,检出限也达到要求。 选择70%乙腈溶液作为流动相,样品中异构化乳糖和乳糖的分离度不好,无法检测;调整为乙腈为90%时,异构化乳糖和乳糖可以分离,但出峰时间拖后至30 min以后,峰型展宽,也不利于准确定量;选择80%乙腈可使样品中异构化乳糖和乳糖分离度达到要求,而且 在20 min内出峰,峰型较好,可准确定量检测。最终选用80%乙腈溶液为流动相。 3 结 论 实验建立的乳粉中异构化乳糖检测方法,定量限为0.3 g/100 g, 在0.3~2.0 g/100g范围内有良好的线性关系,相关系数大于0.999,平均回收率为97.4%~103.0%,方法精密度相对标准偏差值为1.17%。本方法准确性、回收率和精密度满足定性、定量检测要求,为乳粉中异构化乳糖的检测提供理想的检测方法。 ( 参考文献: ) ( [1] 王野,徐清江.浅谈异构化液糖制造[J].饮料工业,2003,3(3):32-34. DOI:10.3969/j.issn.1007-7871.2000.03.011. ) ( [2] 许本发.异构化乳糖促进肠道中双双杆菌增值作用的观察[J].中国 乳品工业, 1986,4(14):104-108. ) ( [3] SEKI N, SAITO H. La c tose as a source f o r lactulose and other functional l actose derivatives[J]. I nternational Dairy Journal, 2012,22(2): 110-115.DOI:10.1016/j.idairyj.2011.09.016. ) ( [4] ADEBOLA O O, CORCORAN O, MORGAN WA. Synbiotics: theimpact of p o tential p r ebiotics inulin, lactulose a n d la c tobionic acidon the survival a n d growth of l actobacilli pro b iotics[J]. Journal ofFunctional Foods, 2014, 10:75-84.DOI:10.1016/j.jff.2014.05.010. ) ( [5] TSUNESUKE T, YASUO N, TAKASHI K. Effect of yogurt andyogurt supplemented with Bifidobacterium and/or lactulose in healthypersons: a comparative study[J]. Bifidobacteria Microflora, 1991,10(2): 1 23-130.DOI:10.12938/bifidus1982.10.2 _ 1 2 3. ) ( [6] BOVEE-OUDENHOVEN IM J, BRUGGENCATE SJMT,LETTINK-WISSINK M L G, et a1. Dietary fructo-oligosaccharides and lactulose inhibit intestinal c olonisation but stimulate translocation of Salmonella in rats[J]. Gut, 2003,52(11): 1572-1578.DOI:10.1136/gut.52.11.1572. ) ( [7] OZER D, AKIN S, OZE R B. Effect of inulin and lactulose on survivalof Lactobacillus acidophilus and Bifidobacterium bifidum BB-02in Acidophilus-Bifldus yoghurt[J]. Food Science a nd TechnologyInternational,2005, 1 1(1): 19-24. DOI:10.1177/1082013205051275. ) ( [8] AWAD R A, HAGRASS A E, SALAMA W M, et al. Lactuloseproduction f rom m i lk p e rmeate and it s p e rformance in he a lthyfunctional frozen y oghurt[J]. World Journal of Dairy and FoodSciences. 2014, 9(1): 1-9. DOI:10.5829/idosi.wjdfs.2014.9.1.1127. ) ( [9] OLIVEIM RPRD S, FLORENCE A C R, PEMGO P, et a1. Use of l actulose a s prebiotic and i t s influence o n the growth, acidificationprofile and v iablecounts o f different probiotics in fermented skimmilk[J]. International Journal of Food Microbiology, 2011, 145(1):22-27.DOI:10.1016/j.ijfoodmicro.2010.11.011. ) ( [10] PHAM T T , SH A H N P. Effe c t of lactulose on biotransformation of isoflavone glycosides to aglycones in soymilk by lactobacilli[J]. J ournal of Food S cience, 2 008, 7 3(3):158-165.DOI:10.1111/j.1750-3841.2008.00687.x. ) ( [11] 侯欣,孙学忠.乳果糖口服溶液改善脑卒中便秘67例分析[J].中国 误诊学杂志,2009,11(9):2713. ) ( [12] van den HEUVEL E G H M, MUIJS T, van DOKKUM W, et al.Lactulose stimulates calcium absorption in postmenopausal women[J].Journal of Boneand Mineral Research, 1999, 14(7):1 2 11-1214. DOI:10.1359/jbmr.1999.14.7.1211. ) ( [13] 王凤仙,刘博亚.异构化乳糖的生理功能及在食品工业中的 应用[J].中国食品添加剂,2015(5): 179 - 182. DOI:10.3969/ i .issn.1006-2513.2015.05.022. ) ( [14] 黄萌萌,王加启,卜登攀.牛奶乳果糖的研究进展[J].中国乳品工业, 2007,35(6):54-57. DOI:10.3969/j.issn.1001-2230.2007.06.014. ) ( [15] 张宗岩,侯万喜.异构化乳糖-新型婴儿食品添加剂[J].中国乳品工 业,1994,22(4):168-170. ) ( [16] 黄萌萌.乳中乳果糖测定方法的优化及其在乳品质量评定中的应 用[D].北京:中国农业科学院,2007. ) ( [17] 关荣发,蒋家欣,刘东红,等.液态乳中掺有复原乳的乳果糖检 测方法[J].中国食品学报,2008,8(6):161-164. DOI:10.3969/ i .issn.1009-7848.2008.06.028. ) ( [18] 胡强,徐红兵,李水军,等.液相色谱-串联质谱法测定尿中乳果糖、 甘露醇和乳糖含量[.中国现代医学杂志,2008,18(13):1810-1813. ) ( [19] 曾文芳,时巧翠,陈永欣,等.离子色谱电化学测定牛奶中的乳 糖和乳果糖[J].食品科 学 ,2006,27(5): 205-207. DOI:10.3321/ j.issn:1002-6630.2006.05.043. ) ( [20] 付晓伶,周荣耀,潘广文.离子色谱法测定大肠癌患者尿液中的甘 露醇和乳果糖[J].分析化学,2012,40(4):608-611. ) ( [21] 邵泓,陆明,潘广文,等.乳果糖口服液中乳果糖及有关物质的高效阴离子交换色谱法测定[J].中国医药工业杂志,2010, 41(6): 438-440.DOI:10.3969/j.issn.1001-8255.2010.06.011. ) ( [22] 刘芳,杨瑞金,张文斌,等.薄层色谱法快速分析乳果糖[J].食品 与发酵工业,2008, 3 4(1): 119- 1 23. DOI:10.13995/j.cnki.11-1802/ts.2008.01.029. ) ( [23] 朱桂兰,童群义.薄层色谱法分析低聚乳果糖[J].食品工业科技, 2004,25(1):131-132.DOI:10.13386/j.issn1002-0306.2004.01.044. ) ( [24] 任一平,陈青俊,黄百芬.高效液相色谱示差折光法测定食品中的 乳果糖[J].中国乳品工业, 1997,25(4):35-37. ) ( [25] 王凤仙,刘博亚.乳制品中异构化乳糖的色谱法检测研究进展[.乳业科 学与技术,2015,38(5): 33-36. DOI:10.15922/j.cnki.jdst.2015.05.008. ) ( [26] 姜金斗,周红,张丽宏,等. HPLC法蒸发光散射检测器测定UHT灭 菌奶中乳果糖方法的研究[J].中国乳品工业,2006,34(3):51-53. ) 数据'网址:www. yuweichina.com 邮箱watercom 建立乳粉中异构化乳糖高效液相色谱的测定方法。采用盐酸沉淀蛋白,氨基色谱柱分离,流动相为80%乙腈溶液,示差检测器检测。每100 g乳粉中异构化乳糖添加量为0.3~2.0 g时,回收率97.4%~103.0%。定量检出限为0.3 g/100 g。该方法操作简便,检测准确,可用于乳粉中异构化乳糖的检测。
关闭还剩1页未读,是否继续阅读?
北京豫维科技有限公司为您提供《乳粉中异构化乳糖的含量检测方案(液相色谱柱)》,该方案主要用于乳粉中营养成分检测,参考标准《暂无》,《乳粉中异构化乳糖的含量检测方案(液相色谱柱)》用到的仪器有SilcoCan 空气采样罐(硅烷化苏玛罐)27409。
