Innov-XSystems, Inc., 10 Gill Street, Suite Q, Woburn Mass., 01801Phone (781) 938-5005 FAX (781)938-0128 WWW.InnovX.com email: info@innovx.com 「M INNOV SYSTEMS Terra at Work Summary: Three USGS Chrysotile samples were diluted with pure quartz to determine the sensitivity and detection limit ofthis asbestos mineral using TERRA. The three samples contained 10%, 25% and 50% Chrysotile respectively. The sampleswere analyzed in TERRA for 400 seconds using standard limited sample preparation (<150um dry sample). Chrystotile 6.00 夕 5.00 Sensitivity 6.19cp5/% 4.00 BEC 0.38 % 3.00 v=6.1881x+2.3711 2.00 R²=0.9262_ Analysis time 400SPC0105 1.00 0.00 Detection limit 0.60% 0% 10% 20% 30% 40% 50% 60% Detection limit analysis using Chrysotile peak at 13.5 degrees two theta
关闭产品配置单
深圳市莱雷科技发展有限公司为您提供《温石棉中主要成分含量检测方案(X射线衍射仪)》,该方案主要用于其他中含量分析检测,参考标准《暂无》,《温石棉中主要成分含量检测方案(X射线衍射仪)》用到的仪器有null。
