煤灰中汞元素检测方案(测汞仪)
检测样品
煤炭
检测项目
汞元素
关联设备
共1种
The US EPA has recently announced that it will begin to regulate em
ission of mercury from coal-fired plants, the largest source of hum
an-made mercury pollution, generating approximately 43 tons of merc
ury each year. Mercury is released not only in stack gasses, but i
n plant waste and the coal cleaning process. The EPA will propose f
inal regulations on coal-fired power plants by December 15, 2003.
Mercury in coal has been traditionally measured by CVAAS (Cold Vapo
r Atomic Absorption Spectrophotometry), which is a time and labor c
onsuming method that relies on complicated wet chemistry sample pre
paration.
The DMA-80 Direct Mercury Analyzer from Milestone eliminates the sa
mple
preparation step, allowing you to completely process your coal samp
le in about 10 minutes, instead of the hours needed for traditiona
l methods. This rapid testing (which is as accurate, if not more s
o, that CVAAS) gives you the answers you need without consuming val
uable time and effort.
Other benefits include:
Process both liquid and solid samples – no matter the matrix you w
ill get an accurate total mercury reading. Process coal, coal ash,
sludge, etc…
The built-in 40-position autosampler allows unattended operation fo
r a large number of samples
The DMA-80 is portable enough to be stationed where you need it mos
t.
Sample the coal deliveries as they come in and the plant waste befo
re it goes out.
No chemicals are used in the process so no additional toxic wastes
are generated.
Completely compatible with US EPA Method 7473 and ASTM Method D672
2-01
北京莱伯泰科仪器股份有限公司为您提供《煤灰中汞元素检测方案(测汞仪)》,该方案主要用于煤炭中汞元素检测,参考标准《暂无》,《煤灰中汞元素检测方案(测汞仪)》用到的仪器有莱伯泰科 DMA-80直接测汞仪。
我要纠错
