当前位置: 石墨烯 > 方案详情
PTT-显微拉曼-石墨烯检测
检测样品 石墨烯
检测项目 拉曼光谱
关联设备 共1种 下载方案
方案详情
MRIX及MRID激光显微拉曼,可搭载不同波长激光(荧光光谱:375nm、405nm;拉曼光谱473nm、488nm、532nm、633nmnm、785nm、808nm、830nm等),每一波长激光模组都可进行单独更换,MRID可同时搭载两种不同的波长的激光进行光谱分析。 MRIX及MRID激光显微拉曼可升级性强,预留偏振模组位置,搭配偏振模组可进行偏振分析。搭配Olympus BX43底座(可根据客户需求进行更换),可搭配多种物镜使用,可搭配电动载台进行Mapping测试等;
Raman SpectroscopyReference:Vol.24, No. 24|28 Nov 2016|OPTICS EXPRESS 3857Contact us: E-mail: ad@protrustech.com; http://www.ProTrusTech.com; TEL: +886-6-2892081 MRI 532Sfor 2D MATERIALS Effects of graphene layers in IGZO/graphite-like +Ni/Sio,/Si waferspecimens on electrical and optical properties in tribotests Instrument: MRI 532S. --532 nm laser, mapping. -- For film structure identification. Purposes of graphite-like layer: 1. E日nhance fatigue and microcrack resistance.2 Improve the electrical properties. Specimen preparation: 1. Use Si wafer as substrate, and pre-grow 300nm-thick thermal Sio, film. 2. Deposit a 300nm thin polycrystalline Ni layer bythe co-sputtering of a Ni and carbon (Ni, C) layer. 3. Annealing: Elevated to 900 ℃. In the coolingprocess, C atoms were precipitated, and thegraphene layer was grown on the Ni film surface. Fig. Schematic of the solar cell. Image,Raman spectra and analysis: 1. The SEM image of the wafer specimen beforedepositing the IGZO film. 2. The peaks analysis: a) A slim and sharp peak occurs at 1583 cm-1,shows that the peak of graphene is close tothat of graphite. b)The intensity of G-band is higher than 2D-band, and thus the film is in the graphite-likematerials. Peaks at 1349 cm-1,1589 cm-1, and 2690 cm-1are identified as D-band, G-band, and 2D-band. Fig. The Raman spectra of the specimen. More information: Graphene vs Graphite: Graphene: 2D material, single layer. Graphite: 3D material, a crystalline allotrope of carbon. The number of layers increases: 1. The G-band shifts to lower wavenumber. 2. There is a linear increase in G-band intensity. 3. The 2D-band exhibits distinct band shapedifferences with the number of layers present. 4. The intensity ratio of the 2D to G-band decreases. Reference: https://www.azom.com/article.aspx?ArticlelD=6271     MRIX及MRID激光显微拉曼,可搭载不同波长激光(荧光光谱:375nm、405nm;拉曼光谱473nm、488nm、532nm、633nmnm、785nm、808nm、830nm等),每一波长激光模组都可进行单独更换,MRID可同时搭载两种不同的波长的激光进行光谱分析。    MRIX及MRID激光显微拉曼可升级性强,预留偏振模组位置,搭配偏振模组可进行偏振分析。搭配Olympus BX43底座(可根据客户需求进行更换),可搭配多种物镜使用,可搭配电动载台进行Mapping测试等;
关闭
  • 1/1
产品配置单
凯戈纳斯仪器商贸(上海)有限公司为您提供《PTT-显微拉曼-石墨烯检测》,该方案主要用于石墨烯中拉曼光谱检测,参考标准《暂无》,《PTT-显微拉曼-石墨烯检测》用到的仪器有MRIX Micro Raman便携激光显微拉曼。
我要纠错
推荐专场
相关方案
