SkyScan 1272 High Resolution Desktop Micro-CT System ·High-resolution, pixel size 0.35 micron, up to 14400x14400 cross section format; · Image height 3000 pixels, scan whole sample in single, not multiple rotations; ·Sample width up to 75mm, sample height up to 70mm,micro-positioning stage;·Robotic auto-sample-changer for 16 samples, batch scanning, ·Compact desktop footprint; ·20-100kV maintenance-free x-ray source, · motorized changer of energy filters with 6 positions; ·Compression-tension, cooling-heating special stages, ·Fast GPU-accelereated reconstruction: ·Comprehensive analysis software for bone morphometry/ densitometry, ·3D visualization software, with surface/ volume rendering and export to mobile devices; ·Bone biologist application support and training. SkyScan 1176 High Resolution in vivo Micro-CT System ·High resolution, pixel size9 microns, up to 8000x8000pixels cross section format:· Image height 2400 pixels,21mm; 20cm scannable length,·Scan whole bone site in single, In-vivo whole-body scan of mouse, 35 um voxel, with i.v.ExiTron nano12000 contract agentproviding blood vessel visu-alization. not multiple scans (knee, long bone, head, thorax...);·Wide field of view without truncation allows accurate densitometry, ·Full physiological monitoring(video, breathing, ECG) integral, not add-on; ·Large shielded space for scanning distal limb of rabbit,small dog,primate; ·Movement correction in in-vivo bone scans;·Breathing, cardiac and dual synchronization, prospective and retrospective, ·Co-registration software and compatible animal beds formultimodal imaging with optical, PET and SPECTinstruments. Bruker microCT Kartuizersweg 3B In-vivo scan of a mouse hindlimb (knee) at 9 pm voxel: avolume rendering and a longitudinal section through the femurand tibia from a single scan, allowing trabecular and cortical3D/2D morphometry at unrivalled resolution. B-2550 Kontich, BelgiumTel: +32 (0)3 8775705Fax: +32 (0)3 877 5769 info@bruker-microCT.com www.bruker-microCT.com microtomography Innovation with Integrity 在CT图像定量分析的过程中,相信大家都遇到过这样的情况:很难找到一个合适的阈值来分割我们要分析的对象。尤其是对于样品中的细微结构而言,由于没有足够高的分辨率来表征,造成其灰度要低于正常值,局部衬度降低。这就对我们的阈值选取、个体分割造成了非常大的困难,尤其是动辄几百兆,几个G的三维CT数据。所以在进行阈值分割之前,各种滤波工具就被我们拿来强化对象,弱化背景噪音,以期能够得到一个更准确的结果。本期,小编给大家介绍布鲁克CT图像定量分析软件CTAn最新版中增加的一些特性。1—各向异性扩散滤波新版中增加的一些特性,其中之一就是强大高效的滤波工具“AnisotropicDiffusion,各向异性扩散”。”各项异性”,顾名思义,就是在进行平滑处理时各个方向并不相同,仅就垂直于边界的区域进行平滑处理,保持边界不会变的模糊。“扩散”意味着强度没有整体增加或减少,即没有强度信号的产生或破坏:对密度测量有利。各向异性扩散滤波器在降噪和边缘保持之间提供了极佳的平衡。2—分水岭算法在CTAn的形态学操作插件中,用户现在可以为分水岭算法定义容差,并采用H-minima变换以≤该容差值的动态强度抑制区域最小值,将“黏连”在一起的对象区分开。接下来利用 Individualobject analysis插件,可以将采用不同颜色编码的图像保存到剪贴板,根据所选的特征,每个个体会被赋予一个灰度值。欧拉数和连通性参数以前仅在3D综合分析中可用,现在它们也可用于单独个体的3D对象分析。此外,软件调整了欧拉数的算法,解决负连接的问题。3—局部取向分析CTAn提供了一个新的插件来执行局部取向分析,以一定半径内的灰度梯度的计算为基础,可进行2D或3D的分析。图像A为CFRP材料的纤维取向分析。图像B为人体椎骨切片,垂直的小梁以红色显示,而水平支撑小梁以蓝色显示,节点和斜结构显示绿色。4—种子生长函数CTAn中添加了种子生长函数。从ROI-shrink-wrap插件可以选择Fill-out模式。该函数通过二值化区域内部的一个种子来生长感兴趣区域(VOI)。它从内部填充而不是从外部收缩来创建VOI,在许多应用中非常有用的,例如,在进行胚胎细胞的分割(图像C)时不误选具有相似密度的其他软组织。关于这些最新的功能,布鲁克近期为我们的显微CT用户专门准备一个网络研讨会,由资深应用科学家Evi Bongaers博士为大家介绍,欢迎大家参加。
关闭产品配置单
束蕴仪器(上海)有限公司为您提供《材料中三维检测方案(工业CT)》,该方案主要用于其他中三维检测,参考标准《暂无》,《材料中三维检测方案(工业CT)》用到的仪器有工业CT 复合材料CT检测系统 skyscan。
