色 谱Chinese Joumal of Chram atogrophyVol 27 No 2201~ 2052009年3月M arch 2009 色 谱第27卷·202· 超高效液相色谱法测定水果和饮料中残留的氟嘧菌酯和嘧螨酯 雒丽丽. 薄海波”, 毕 阳. 吴永隆 (1.甘肃农业大学食品科学与工程学院,甘肃兰州7300702青海省出入境检验检疫局,青海西宁810000) 摘要:建立了多种水果和饮料中氟嘧菌酯和嘧螨酯残留的超高效液相色谱测定方法。样品用乙酸乙酯-环己烷(体积比为1:1)超声波萃取,凝胶渗透色谱法净化,超高效液相色谱-二极管阵列检测器检测,外标法定量。采用 BEHC色谱柱(50mm×2. 1mm, 1.71m),流动相为水-乙腈(体积比为3:7),流速为 0. 3mL /m in主温为40℃,紫外检测波长为 251 m。实验结果表明:氟嘧菌酯和嘧螨酯在0.05~2mg/L范围内线性关系良好(r>0.999),在不同的基质中添加3个浓度水平(0.01,0.05,0.1mg/kg)的氟嘧菌酯和嘧螨酯,两者的回收率均在82.60%~101. 1P6之间,相对标准偏差为5.4%~15.3%;检出限不大于6lg/kg定量限不大于 201g/kg 关键词:超高效液相色谱;凝胶渗透色谱;氟嘧菌酯;嘧螨酯;农药残留;水果;饮料 中图分类号:O658 文献标识码: A 文章编号:1000-8713(2009)02-0201-05 栏目类别:研究论文 D eterm ination of fluoxastrobin and fluacrypyrim residues infruits and beverages by ultra perfommance liquid chromatography LUO L ili, BO Haibo, BI Yang, WU Yong bng (1. College of Food S cien ce and En gin eer in g, G an su Agricu lturalUn iversity, Lan zhou 730070, Ch ina;2. Q in gha i En try and Exit h spection an d Quarantin eBureau, Xin ing 810000, China) Abstract A method was developed for the deteim ination of fluoxastrobin and fluacrypyrimres idues in fruits and beverages by ultra perfomance liquid chromatography w ith pho to-diodearray (UPLC-PDA) detection The sample was extracted w ith ethylacetate-cycbhexane (1: 1,v/v) by ultrasonic cleaned up by gel pemmeation chromatography (GPC),and then deter-m ined by UPLC-PDAThe quantification was perfom ed by extemal standardA BEH Ci cofunm (50 mm×2. 1 mm,1.7m) was used,and water-acetonitrile (3:7,v/v) was used asmobile phase at a flw rate of0. 3mL /m inThe column temperature was set at 40 ℃, and ultravio let absorption w aveleng th w as set at 251 mm. The calibration curves were linear betweenthe peak area and the concentration in the range of 0. 05-2mg/L for fluoxastrobin and fluacrypyrmtthe corre lation coefficients were greater than 0.999The average recoveries spiked infruit and beverage m atrices at the three concentration levels of 0. 01 0.050.1mg/kg rangedfrom 82. 60 to 101.11%w ith the relative standard deviations of 5.4%-15.3%..The lm its ofdetection (LOD) were not greater than 6 lg/kg and the lm its of quantification (LOQ) werenot greater than 20 lg/kg in fruit and beverage m atrices for fluoxastrobin and fluacrypyrim. K ey words ultra perfomance liquid chrom atography (UPLC); gel pemeation chromatography (GPC);fluoxastrob influacrypyrim; pesticide res idues1 fruittIbeverage 氟嘧菌酯( fluoxastrobin)和嘧螨酯(fluacry-pyrin)是德国拜耳作物科学公司研发的新型广谱内吸性茎叶处理用的甲氧基丙烯酸酯类农药。氟嘧菌酯主要用于防治禾谷类、马铃薯、蔬菜和咖啡等所有真菌纲病菌112,具有快速杀菌和持效期长的双重特性,且对作物具有很好的相容性23,其抑菌活 性高,对人类和环境的毒性相对较低,对非靶标生物安全4-6,因此于2006年在美国获准可用于防治花生、水果、蔬菜、草坪上多种病害的防治。嘧螨酯是在甲氧基丙烯酸酯类杀菌剂的基础上随机合成并经优化发现的,是第一个甲氧基丙烯酸酯类杀螨剂,主要用于防治果树中的多种螨类如苹果红蜘蛛、柑 ( *通讯联系人:薄海波,博士,高级工程师. E- ma il b ohb1212@ 163. com. ) ( 基金项目:国家认证认可监督管理委员会2007年检验检疫行业标准研制项目(Na 2007 B 865). ) 橘红蜘蛛等9。这两种农药自问世以来迅速进入各国的农药市场。美国110、世界贸易组织等均规定了多种农产品中氟嘧菌酯和嘧螨酯的残留限量,其值大多数在 10~ 500Hg/kg1011。目前我国对氟嘧菌酯和嘧螨酯的药效试验研究刚刚起步,对氟嘧菌酯和嘧螨酯残留分析的研究尚属空白。近年来,我国农产品出口屡遭国外绿色贸易壁垒,氟嘧菌酯和嘧螨酯作为一种新型的、应用广泛的甲氧基丙烯酸酯类农药,国外的残留限量随时有可能成为我国农产品出口的障碍,因此研究氟嘧菌酯和嘧螨酯的残留检测方法具有重要的现实意义。 目前,有关氟嘧菌酯和嘧螨酯残留检测的研究在国内尚未见报道,仅检索到国外的少量报道。Preu采用乙腈水提取、液液萃取去除脂溶性杂质、固相萃取 (SPE)去除不同类型物质,再进行凝胶渗透色谱 (GPC)净化,用高效液相色谱串联质谱法(HPLC-MS/MS)测定了谷物、水果等多种基质中氟嘧菌酯的残留。该方法净化效果良好,但实验步骤复杂,检测仪器设备昂贵,不利于在国内推广。凝胶渗透色谱是一种先进的样品净化方法,主要按照相对分子质量大小来完成净化,可以有效地去除基质提取液中色素等大分子干扰物质,近年来在食品样品的残留分析中有较广泛的应用[13-16]。超高效液相色谱(UPLC)是分离科学中的一个创新,能提供超高压(103.35MPa (15000 psi))的色谱泵、耐超高压的色谱系统以及小颗粒填料色谱柱和非常低的系统死体积,因而大幅度地提高了分析速度、灵敏度及色谱峰容量。本文利用 UPLC的强大优势,省略了文献[12]中复杂的液液萃取和固相萃取预净化步骤, GPC去除提取液中的色素等大分子干扰物质,实现了氟嘧菌酯和嘧螨酯与 GPC共流出物的良好分离。本方法简便快速,费用低廉。应用本文建立的方法测定了苹果、葡葡、梨,橙汁饮料、绿茶饮料、水蜜桃饮料等水果和饮料中氟嘧菌酯和嘧螨酯的残留量,实验结果的重现性好,检出限均可满足国外对水果和饮料中目标物的残留限量要求。 1实验部分 111仪器、试剂和样品 Acqu it超高效液相色谱仪(美国 W aters公司,配二二管阵列检测器(PDA), Empower 2.0色谱工作站)。凝胶渗透色谱仪(美国 W aters公司,配 En-viroge I色谱柱,馏分收集器)。 M illi-Q 型超纯水机,超声波振荡仪,低速台式离心机(5000 r/m in),0.22lm的微孔滤膜。 乙腈、乙酸乙酯、环己烷、二氯甲烷均为农残级 试剂,氯化钠为分析纯,水为超纯水。 氟嘧菌菌(分子式CiH16 CFN0,相对分子质量Mr)458.08 CAS No 361377-29-9)和嘧螨酯(分子式CH2 FN0,Mr= 426.14 CAS No 229977-93-9)标准品:纯度99.5%(德国Dr Ehrenstorfer公司)。 供试样品:苹果、葡萄、梨,橙汁饮料、绿茶饮料、水蜜桃饮料等均从超市购买。 12 色谱分析条件 色谱柱Acquity UPLCBEH Cs柱(50mm×2.1mm, 1.7 lm, 美国 Waters公司);流动相:水-乙腈(体积比为3:7);流速:0.3mL/m in 柱温:40℃;紫外最大吸收波长:251mm;进样量:5HL。 13 标准溶液的配制 精密称取标准品0.01g(精确到0.0001g),用乙酸乙酯溶解并定容于10mL容量瓶中,得1 g/L贮备液,于-18℃下冷冻保存(可使用3个月)。实验中根据需要用流动相将贮备液稀释为适当浓度的标准溶液。 1.4 试样的制备 取有代表性的样品500g将可食部分切碎,用高速捣碎机捣碎成浆状,装入干净样品瓶中,密封,于-18℃下冷冻保存。 将试样放至室温后,称取10g(果蔬类)或量取10mL(饮料类)试样,放入 50 mL具塞离心管中,加入3.0g氯化钠,加20mL乙酸乙酯环己烷(体积比为1:1),涡旋振荡1min 超声提取 5 m in 以3000r/min离心 3m in 取上清液。重复上述步骤1次,合并上清液,于40℃水浴中旋转蒸发至近干。加入4mL二氯甲烷溶解,供 GPC净化。 15 样品净化 凝胶柱:150mm×20 mm 柱串接300 mm×20mm 柱(Bio Beads S-X3);洗脱剂为二氯甲烷,进样量为2mL 流速 5mL/min收集时间为11~12.5min。收集液于40℃下用氮气吹至近干,用1mL的水乙腈(体积比为3:7)溶解,过0.22 lm 的微孔滤膜,供 UPLC-PDA分析。 2结果与讨论 21提取条件的选择 211提取溶剂的选择 参考文献[1217],对比了3种溶剂(乙腈-水、乙酸乙酯环己烷(体积比为1:1)、二氯甲烷-丙酮(体积比为7:3))对加标样品的提取效果。实验结果显示:用乙腈提取时,样品不易和水分层;用二氯甲烷丙酮提取时,杂质峰干扰较大;用乙酸乙酯-环己烷溶液的提取效果好,且可获得满意的回收率。 因此本文选取乙酸乙酯环己烷(体积比为1:1)作为提取溶剂。 212提取条件的优化 考察了用乙酸乙酯环己烷(体积比为1:1)在超声波振荡器上提取不同时间(25和10min各测试2个平行样)对氟嘧菌酯和嘧螨酯的回收率影响。结果表明:提取时间为2min时氟嘧菌酯和嘧螨酯的回收率偏低,而5min和10m in的回收率无明显差异,三者的回收率分别为 67.7%,92.4%和92.6。考察了提取次数对氟嘧菌酯和嘧螨酯回收率的影响。分别重复提取2次和3次,各测试2个平行样。两者的平均回收率分别为93.1%和93.26,没有明显的差异。故本方法选择提取两次。 22净化条件的优化 考察了用 Cl: SPE 柱的净化效果。经仪器检测,在氟嘧菌酯和嘧螨酯出峰时间内出现杂质干扰峰;再经GPC净化,可得到满意的净化结果;但净化步骤太多,且 SPE小柱一次性使用,费用较高。而水果、饮料中多含糖、维生素、色素等大分子物质,其相对分子质量和氟嘧菌酯和嘧螨酯的相差甚远,经GPC净化后,用 UPLC分析,可以将氟嘧菌酯和嘧螨酯与 GPC共流出物良好分离(见图1-c)。本文只用 GPC净化,基本上达到了文献[12]采用 SPE+GPC的净化效果。故本文省略了 SPE净化步骤,直接采用 GPC净化方法。 适合本文所用凝胶渗透色谱柱的洗脱剂有二氯甲烷、乙酸乙酯环己烷(体积比为1:1)。实验结果表明:以二氯甲烷作为净化洗脱剂时,氟嘧菌酯和嘧螨酯的流出峰形窄,馏分收集时间仅为 1.5m in 回收率高且净化效果好;以乙酸乙酯环己烷作洗脱剂时,洗脱效果与二氯甲烷相近,但柱压较高。故本文选取二氯甲烷作为净化的洗脱剂。另外,采用的洗脱剂流速不同对收集时间有影响:流速慢则收集时间长,而且杂质峰干扰较大。综合考虑柱压和收集时间等因素,确定洗脱剂的流速为 5 mL /m in 收集时间为11~12.5m in. 233色谱条件的选择 231分离条件的优化 考察了采用不同比例的水-乙腈作为流动相等度洗脱对氟嘧菌酯和嘧螨酯的峰形与杂质峰的分离度和分析时间等因素的影响。根据实验结果确定流动相为水-乙腈(体积比为3:7),流速 0.3mL /m in,柱温 40℃。 232 检测波长的选择 根据 PDA扫描光谱图,得到目标物的最大紫外吸收波长为191.6 nm 和251.2 nm. 考虑到191.6 nm为紫外末端吸收,基质干扰严重,故选择251.2nm 为检测波长。 24 标准曲线 配制质量浓度为 0.05 0.1,0.5 1, 2mg/L的系列标准溶液,按色谱条件测定。目标物标准品的色谱图见图1-a以目标物的质量浓度X (mg/L)为横坐标,峰面积Y为纵坐标进行线性回归,得方程为Y=30100X-299相关系数 r= 0.999 5. t/min 图1 (a)氟嘧菌酯和嘧螨酯标准品、(b)苹果空白样品和(c)苹果空白样品添加限量水平的目标物标准品的色谱图 Fig1Chromatograms of (a) floxastrobin andfluacrypyristandards (b)an appleblank sample and (c) an apple blanksample spiked w ith the standards at theresidue lin it leve ls 1. fluox astrobin 22mfluaciypyrm. 25 回收率和精密度 采用标准添加法,在空白水果、饮料样品中添加3个浓度水平的氟嘧菌酯和嘧螨酯标准溶液,每个水平样品平行测定6次。苹果空白样品及其添加标准品的样品的色谱图见图 1-b c.实验结果(见表1)表明,方法的平均回收率为 82.60%~101.119, 相对标准偏差(RSD)为 5.4%~15.3. 分别以3倍信噪比(SN=3)和10倍信噪比(SN=10)确定本方法的最低检出限(LOD)和定量限(LOQ),结果(见表1)表明,不同基质中氟嘧 菌酯和嘧螨酯的 LOD值和 LOQ值略有差异, LOD均不大于 6Hg/kg LOQ值均不大于 20 Hg/kg 可以满足各国对水果和饮料中氟嘧菌酯和嘧螨酯的限量要求。 表1空白水果、饮料样品添加氟嘧菌酯和嘧螨酯的回收率、精密度、检出限(SN=3)和定量限(SN=10)(n=6) Table 1 Recoveries precisions limits of dete mm ination (LOD, SN=3) and li its of quan tification (LOQ, SN=10)offloxastrobin and fhacrypyrin in b lank sam p les of fru its and beverages n=6) 3结论 参考文献: 本文建立的超高效液相色谱-二极管阵列测定氟嘧菌酯和嘧螨酯残留的分析方法简便快速,用凝胶渗透色谱法净化效果好,干扰小。方法灵敏度高,可以满足国外对水果和饮料中氟嘧菌酯和嘧螨酯的残留检测要求。 ( [1 ] US Environm ent Protection Agency Pesticide f a ct sheet [2005-10]. http / / www. epa gov / opprd001/ fac tshee ts/fluoxastrob in pdf ) ( [2] Yin JJ MaHY G uanAY e t al P esticides (殷锦捷,马海 云, 关 爱莹,等.农药)2003,42(3): 40 ) ( [3] HauserHahn, P Baur Schm ittW. Pf l anzenschutzN chricht en Bayer 2004 57(3):437 ) ( [4] Reuven iM. Crop Prot 2001 20. 663 ) ( [5] McCartney C. M ereer P C , Cooke L R e t al Crop P rotec tion 2007 26 1272 ) ( [6] LiH P J iangsu Chem icalTechnology (李海屏.江苏化工), 2004 32(6):9 ) ( [7] Liu C L. Pesticides(刘长 令 .农药),20074 6 (4): 2 66 ) ( [8] Liu C L , GuanA Y, Liu Z L World Pesticides (刘长 令 ,关 爱莹, 刘 振龙.世界农药),200224(4): 44 ) ( [9] Huang S Q Z hang Z X, Xu H H e t al P e stic ides (黄素青, 张志祥,徐汗虹,等 . 农药),200544(2):81 ) ( 「101 US E nvironment Protection Agency. F ederal Register 2005 70(179) : 54640 ) ( [11] Worl T r ade Oiganization Comm ittee o n sanitary andphytosanitary measure notification ( G /SPS/N /USA/ 1119) [ 2005-09-30]. h ttp //www. u a e gov. ae/uaeagri cent/sps/ files /NUSA1119. d oc ) ( |121 Preu M. P flanzenschutz-N chrichten Bayer 2004,57(3): 355 ) ( [13] WuG, Bao X X, Wang H 亞 et al C h inese Journal of Chromatog rap h y(吴刚, 鲍 晓霞,王 华 雄等.色谱) 2008, 2 6(5): 5 77 ) ( 「141 Hu B z S ong WH, Xi e L P et al Chinese Journal of Chrom atog raphy (胡贝贞,宋伟华,谢丽萍, 等 .色谱) 2008,26(5) : 608 ) ( 151 Yang Fang Lu SY, C hen XM, et a l Chine se Journal of Chrom atog raphy(杨方,卢声宇,陈祥明,等.色谱) 2008 , 26(4):499 ) ( [16] Yu S L Y a ng GB Fu M . Chi n ese Journal ofChrom atog ra phy (于胜良,杨桂朋,付 萌 .色谱),2007 25(4): 5 8 1 ) ( [17] BoH B , Bi Y, C h en L R Chinese Jo u mal of Analytical Chem istry ( 薄 海波,毕阳,陈立仁 . 分析化学),2 0 05 33(5): 695 ) 第九届亚太国际微分离分析学术会议(APCE2009)及第一届亚太国际芯片实验室学术会议(APLOC2009)征稿通知 2009.10.28-31上海 由中国科学院大连化学物理研究所主办的“第九届亚太国际微分离分析学术会议(APCE2009)”和“第一届亚太国际芯片实验室学术会议(APLOC2009)”将于2009年10月28-31日在上海召开。林炳承、秦建华教授任大会主席。本次会议将致力于推动各种微型分离分析技术的发展,同时也将对以微流控芯片或芯片实验室(Lab on a Chip)为代表的新型科学技术及其在学命科学领域的应用予以特别关注。会议将邀请一大批来自国内外的知名学者、专家参会并做邀请报告和大会报告,热忱欢迎大家跃投稿并到会交流。会议投稿、注册等相关事宜请登陆会议网站:http://www.biochem. dicp. ac. cn/apce2009/index.html。 本次会议主题涉及微纳生物化学分离分析和微流控芯片实验室的各个方面,主要内容包括微纳流控理论、微纳流体系统、微纳分析与合成系统、微纳材料及表面、微纳加工技术、微流控芯片集成技术、微流控芯片接口技术、微流控芯片控制、检测技术等及其在化学、生命科学中的应用等方面。 凡与上述主题相关且尚未公开发表的关于新理论、新方法、新技术和新应用等研究论文均在应征之列。应征稿件将提交大会学术委员会审定,接受论文将编入本届学术会议论文集。应征稿件请于2009年7月31日前发送到shiw@ dicp.ac. cn。 欢迎国内外分析仪器公司、厂商到会参展。 联系方式 通讯地址:大连市中山路457号,大连化学物理研究所 邮政编码:116023 联系人:时蔚 电话/传真:0411-84379059 E-mail: shiw@ dicp. ac. cn 网站: http: //www. biochem.dicp.ac. cn/apce2009/index. html APCE & APLOC 2009 筹备组 ◎ China Academic Journal Electronic Publishing House. All rights reserved. http://www.cnki.net 建立了多种水果和饮料中氟嘧菌酯和嘧螨酯残留的超高效液相色谱测定方法。样品用乙酸乙酯环己烷 (体积比为 11)超声波萃取, 凝胶渗透色谱法净化, 超高效液相色谱二极管阵列检测器检测, 外标法定量。采用 BEH C18色谱柱 ( 50 mm 2 1 mm, 1 7 m ), 流动相为水乙腈 (体积比为 37), 流速为 0 3 mL /m in, 柱温为 40 ! , 紫外检测波长为 251 nm。实验结果表明: 氟嘧菌酯和嘧螨酯在 0 05~ 2 mg /L范围内线性关系良好 (r > 0999), 在不同的基质中添加 3 个浓度水平 ( 0 01, 0 05, 0 1 m g/ kg)的氟嘧菌酯和嘧螨酯, 两者的回收率均在 8260% ~ 10111% 之间, 相对标准偏差为 5 4% ~ 153% ; 检出限不大于 6 g /kg, 定量限不大于 20 g /kg。
关闭还剩3页未读,是否继续阅读?
北京京科瑞达科技有限公司为您提供《水果和饮料中氟嘧菌酯和嘧螨酯检测方案(二手分析仪器)》,该方案主要用于果蔬汁类及其饮料中农药残留检测,参考标准《暂无》,《水果和饮料中氟嘧菌酯和嘧螨酯检测方案(二手分析仪器)》用到的仪器有二手waters2695沃特世高效液相色谱仪9成新。
