2019 Vol.38 No.4Serial No.326China Brewing·70·Research Report 2019年第38卷第4期总第326期中 国 酿造·71·研究报告 不同处理工艺对猕猴桃果酒品质的影响 葛东颖',李华佳,杨成聪l,张润杰,朱永清2,郭 壮* (1.湖北文理学院食品科学技术学院鄂西北传统发酵食品研究所,湖北襄阳 441053;2.四川省农业科学院农产品加工研究所,四川成都610066) 摘 要:分别采用清汁、去皮和带皮的工艺酿造猕猴桃果酒,并对不同处理工艺酿造果酒的品质进行评价。结果表明,经电子舌检测发现,带皮发酵猕猴桃果酒的鲜味和咸味显著偏高(P<0.05),而酸味和苦味则呈现出相反的趋势(P≤0.05)。经高效液相色谱 (HPLC检测发现,带皮发酵猕猴桃果酒中奎尼酸、柠檬酸、苹果酸和乳酸含量显著偏低(P<0.05)。经电子鼻检测发现,传感器W1C和W5C对带皮发酵猕猴桃果酒的响应值显著偏高(P<0.05),而传感器W5S呈现出相反的趋势 (P<0.05)。经色度仪检测发现,带皮发酵的猕猴桃果酒其亮度(L*值)显著高于清汁发酵(P≤0.05),而红绿度(a*值)显著高于去皮发酵(P≤0.05)。通过主成分分析(PCA)、聚类分析(CA) 和多变量方差分析(MANOVA) 发现,带皮发酵的猕猴桃果酒品质更优。 关键词:猕猴桃果酒;不同处理工艺;电子鼻;电子舌;色度仪;品质评价 中图分类号:TS261 文章编号:0254-5071(2019) 04-0070-05 doi:10.11882/j.issn.0254-5071.2019.04.014 引文格式:葛东颖,李华佳,杨成聪,等.不同处理工艺对猕猴桃果酒品质的影响[].中国酿造,2019,38(4):70-74. Effect of different treatment processes on the quality of kiwifruit wine GE Dongying', LI Huajia, YANG Chengcong', ZHANGRunjie', ZHU Yongqing', GUO Zhuangl* (1.Northwest Hubei Research Institute of Traditional Fermented Food, College of Food Science and Technology,Hubei University of Arts and Science, Xiangyang 441053, China; 2.Institute of Agro-products Processing,Sichuan Academy of Agricultural Sciences, Chengdu 610066, China) Abstract:The kiwifruit wines were brewed by three kinds of processes (clear juice, without peel and with peel), respectively, and the quality of the winesbrewed by different treatment processes were evaluated. The testing ofelectronic tongue indicated that the umami and salty of kiwifruit wine ferment-ed with peel were significantly higher (P<0.05), while the sourness and bitterness showed the opposite tendency (P<0.05). The testing of HPLC indi-cated that the quinic acid, citric acid, malic acid and lactic acid contents in the kiwifruit wine fermented with peel were significantly lower (P<0.05).The testing ofelectronic nose indicated that the response value of sensor W1C and W5C on the kiwifruit wine fermented with peel were significantlyhigher (P<0.05), while the sensor W5S showed the opposite tendency (P<0.05). The testing of colorimeter indicated that the brightness (L* valueof kiwifruit wine fermented with peel was significantly higher than the kiwifruit wine fermented with clear juice (P<0.05), and the red and green de-gree (a* value) was significantly lower than the kiwifruit wine fermented without peel (P<0.05). Through principal component analysis (PCA), clus-ter analysis (CA), and multivariate analysis of variance (MANOVA), the quality of kiwifruit wine fermented with peel was better. Key words:kiwifruit wine; different treatment technology; electronic tongue; electronic nose; colorimeter; quality evaluation 作为一种呼吸跃变型水果,猕猴桃采摘后存在保藏困难、易腐败变质和营养成分易流失等问题",因此,对猕猴桃进行深加工显得尤为重要。近年来,以猕猴桃为原料开发了果酒、果醋和果果“等系列产品,不仅充分利用了猕猴桃的营养价值,而且提高了猕猴桃的利用率,助推了猕猴桃全产业链的发展。目前制备猕猴桃果酒的工艺常包括清汁发酵、去皮发酵和带皮发酵3种形式。猕猴桃果皮中各类香气含量较高,同时富含氨基酸、钾和钙等物质,且具有较强的抗氧化性图,因而将其应用于猕猴桃果酒加工具有较强的可行性。有研究指出,带皮发酵可提高酒体 ( 收稿日期:2018-11-16 修回日期:2019-02-15 ) 的香气和抗氧化能力,同时亦可改变酒体外观并增强酒体结构110。陈红梅等研究发现,带皮发酵工艺可一定程度提高野生猕猴桃酒的品质。 GB/T15038—2006《葡萄酒、果酒通用分析方法》约束了从外观、滋味和香气等三个维度对果酒进行感官检查与评价的方法,然而感官鉴评法具有对评价人员要求高和评价指标体系研究不够深入等不足"。近年来色度仪[12-13]电子舌[14-15]气相色谱-质谱联用 (gas chromatograph massspectroscopy,GC-MS) 仪[16-17、电子鼻[18-19]和高效液相色谱(high performance liquid chromatography,HPLC 仪20-21等检 ( 基金项目:成都市产业集群协同创新项目(2015-cp030031-nc) ) ( 作者简介:葛东颖(1999-),女,本科生,研究方向为食品生物技术。 ) ( *通讯作者郭 壮(1984-),男,副教授,博士,研究方为为食品生物技术。 ) 测技术在酒类品质评价方面有了广泛的应用,实现了食品色泽、滋味和气味指标的数字化评价,因而将上述检测技术引入猕猴桃果酒品质评价中具有积极的意义。采用GC-MS技术,陈红梅等研究发现,带皮发酵猕猴桃果酒中酯类、萜烯类和酮类物质质量浓度相对较高。然而目前关于不同处理工艺猕猴桃果酒滋味和色泽品质评价的报道尚少。 本研究采用电子子、电子鼻、HPLC仪和色度仪对不同处理工艺酿造猕猴桃果酒的品质进行了数字化评价,并结合多元统计学分析方法探讨了不同处理工艺对猕猴桃果酒品质的影响,以期为后续猕猴桃果酒的生产和品质评价提供参考。 1材料与方法 1.1材料与试剂 徐香猕猴桃:市售;苹果酸、奎宁酸、柠檬酸、乳酸(均为优级纯)、乙腈(色谱纯):国药集团化学试剂有限公司;磷酸二氢钾、磷酸(均为分析纯):西陇科学股份有限公司;果胶酶(5万U/g、偏重亚硫酸钾(均为食品级):烟台帝伯仕自酿机有限公司;RW葡萄酒·果酒专用酵母:安琪酵母股份有限公司;阳离子溶液、阴离子溶液、预处理溶液、参比溶液和内部溶液:日本Insent公司。 1.2仪器与设备 SA 402B电子舌(配备2个参比电极和5个味觉传感器):日本Insent公司;LC-20ADXR高效液相色谱仪(配备有SPD-M20A二极管阵列紫外-可见光检测器)、InertSustainSwiftCis色谱柱(250 mmx4.6 mm,5 um):日本岛津公司;PEN3电子鼻(配备10个金属氧化传感器):德国Airsense公司;Ultra Scan PRO色度仪:美国Hunter Lab公司。 1.3实验方法 1.3.1猕猴桃果酒的制作 参照参考文献[5]的方法制作猕猴桃果酒并进行适当修改。工艺流程及主要步骤如下所示: 破碎压榨(酶解)→猕猴桃汁(清汁发酵) 徐香猕猴桃→→去皮压榨(酶解)→猕猴桃浆(去皮发酵)带皮压榨(酶解)→猕猴桃全浆果(带皮发酵) 接种酵母→启动发酵→前发酵→后发酵→终止发酵→离心→贮藏 清汁发酵组:将猕猴桃破碎后加入果胶酶进行酶解,10 000 r/min离心5 min,取上清液备用。 去皮发酵组:将猕猴桃样品去皮后,果肉破碎入罐添加果胶酶进行酶解。 带皮发酵组:将猕猴桃破碎后入罐添加果胶酶进行酶解。 不同处理工艺组均添加0.06%的果胶酶酶解12 h提高出汁率和0.10mg/L偏重亚硫酸钾防止氧化;搅拌均匀后使用蔗糖调节糖度为22°Bx;按照0.2%猕猴桃鲜果的比例接种酵母菌;前发酵为22℃发酵7d;后发酵为18℃发酵20 d;10000 r/min离心5 min,取上清液,备用。每个处理工艺组做5个平行。 1.3.2基于电子舌猕猴桃果酒滋味品质评价 样品处理:准确量取40mL猕猴桃果酒与80 mL超纯水混合均匀,静置15 min后抽滤,滤液10000 r/min离心10 min,取上清液待用。 电子舌测试条件:参照郭壮等”的方法并进行适当的优化,每组样品平行测定4次。 数据处理:删除第1次测试实验值,取第2、3和4次实验值作为原始数据,并使用电子舌自带工作站对电子舌的响应值进行分析。 1.3.3基于高效液相色谱猕猴桃果酒中有机酸测定 样品处理:准确吸取2mL猕猴桃果酒和0.20 mL的0.10 mol/L磷酸溶液于10 mL容量瓶中,用流动相定容,混合均匀后过0.22 um一次性针头式过滤器,滤液待用。 色谱条件:参照杨成聪等的方法并进行适当的优化。流动相为0.01 mol/L磷酸二氢钾溶液,pH值为2.90,柱温为30℃,流速为1.00 mL/min,检测波长为215 nm,进样量为20pL,平行测定3次。 数据处理:使用高效液相色谱自带的工作站对测定的猕猴桃果酒中有机酸信号值进行分析,采用保留时间对猕猴桃果酒中4种有机酸进行定性分析,使用外标法对猕猴桃果酒4种有机酸进行定量分析。 1.3.4基于电子鼻技术猕猴桃果酒风味品质评价 样品处理:准确吸取15 mL猕猴桃果酒样品于电子鼻样品瓶中,55℃保温10 min后室温平衡10 min,即可插入电子鼻探头进行顶空进样测试。 电子鼻测试条件:参照张淼等24对芝麻酱品质评价中的测试条件,并进行适当优化。 数据处理:金属氧化电极测定在45s后达到稳定,本研究选取49 s、50s和51s时的平均值为测试数据,平行测定3次。 1.3.5基于色度仪猕猴桃果酒色泽品质评价 将猕猴桃果酒样品倒入50 mmx10 mm的比色皿中,使用透射模式对猕猴桃果酒的各色度指标进行测定,读数以CIE1976色度空间值L*值(暗音亮:0→100)、a*值(绿-→红+)、b*值(蓝-→黄+)表示,平行测定3次2。 1.3.6统计学分析 采用主成分分析 (principalcomponent analysis,PCA) 法、聚类分析 (cluster analysis,CA) 和多变量方差分析 (multi-variate analysis ofvariance,MANOVA) 法对不同处理工艺猕猴桃果酒的风味品质进行评价,采用冗余分析 (redundancyanalysis,RDA) 和Kruskal-Wallis检验对不同处理工艺猕猴桃果酒品质差异的关键性指标进行甄别。采用Cannoco 4.5软件进行RDA,其他分析均采用MATLAB 2016b,采用Origin 2017绘图。 2结果与分析 2.1不同处理工艺对猕猴桃果酒滋味品质的影响 首先使用电子舌技术对不同处理工艺猕猴桃果酒的 滋味品质进行评价,其结果如图1所示。 图1不同酿造工艺猕猴桃果酒各滋味指标相对强度的雷达图 Fig. 1 Radar chart of relative intensity of each taste indexes ofkiwifruit wines fermented by different brewing processes 由图1可知,不同处理工艺猕猴桃果酒在咸味、苦味、酸味和鲜味滋味指标上的差异较大,其极差值分别为3.10、2.45、1.88和1.48,而在后味B(苦味的回味)、涩味、后味A(涩味的回味)和丰度(鲜味的回味)上的差异较小且极差值均<1。由此可见,不同处理工艺猕猴桃果酒滋味品质的差异主要体现在咸味、苦味、酸味和鲜味上,虽然在其他滋味指标上存在差异,但其差异不会对消费者对产品的喜 好程度产生影响126]。经Kruskal-Wallis检验发现,酸味、苦味、鲜味和咸味4个滋味指标在不同处理工艺猕猴桃果酒之间的差异显著(P<0.05),其中带皮发酵猕猴桃果酒的鲜味和咸味显著偏高(P<0.05),而酸味和苦味显著偏低(P<0.05)。本研究进一步使用高效液相色谱仪对猕猴桃果酒中4种有机酸的含量进行测定,结果如表1所示。 表1 猕猴桃果酒中4种有机酸的含量 Table 1 Contents of 4 kinds of organic acids in kiwifruit wine 有机酸 清汁发酒/ 去皮发酵/ 带皮发酵/ (mg'mL) (mg*mL) (mg'mL) 奎尼酸 9.75±0.07a 8.53±0.07b 7.88±0.03c 柠檬酸 8.11±0.08a 7.63±0.04b 7.21±0.02c 苹果酸 1.13±0.02a 0.85±0.01c 0.91±0.02b 乳酸 5.12±0.19b 6.00±0.05a 4.61±0.08c 注:同行字母不同,表示差异显著(P<0.05)。下同。 由表1可知,奎尼酸、柠檬酸、苹果酸和乳酸在不同处理工艺猕猴桃果酒中均有检出,通过Kruskal-Wallis检验发现,4种有机酸在不同处理工艺猕猴桃果酒中均差异显著(P<0.05),且带皮发酵猕猴桃果酒中4种有机酸含量显著偏低(P<0.05)。 2.2不同处理工艺对猕猴桃果酒气味品质的影响 本研究进一步使用电子鼻技术对猕猴桃果酒的风味品质进行评价,果酒中典型挥发性风味物质的相对强度如表2所示。 表2不同酿造工艺猕猴桃果酒各气味指标相对强度的差异性分析 Table 2 Difference analysis of relative intensity of each flavor indexes of kiwifruit wines fermented by different brewing processes 金属传感器 性能描述 清汁发酵 去皮发酵 带皮发酵 W1C 对芳香类物质灵敏 0.020±0.001b 0.021±0.001b 0.022±0.001a W5S 对氮氧化物灵敏 164.033±12.745a 132.838±3.467b 122.855±3.189c W3C 对芳香类物质灵敏 0.088±0.002a 0.087±0.003a 0.086±0.005a W6S 对氢气有选择性 3.226±0.214a 2.989±0.333a 3.048±0.209a W5C 对烷烃、芳香类物质灵敏 0.091±0.006b 0.094±0.004b 0.103±0.005a W1S 对甲烷灵敏 261.758±25.328a 277.927±9.853a 273.05±12.015a W1W 对有机硫化物、萜类物质灵敏 81.041±0.973a 77.971±2.090a 79.622±2.414a W2S 对乙醇灵敏 88.007±4.356a 83.765±7.966a 89.615±6.156a W2W 对有机硫化物灵敏 33.875±3.696a 35.671±0.951a 36.722±1.942a W3S 对烷烃灵敏 0.020±0.001a 0.021±0.001a 0.022±0.001a 由表2可知,传感器W1C和W5C对带皮发酵猕猴桃果酒的响应值显著偏高(P<0.05),而传感器W5S对其响应值显著偏低(P<0.05)。传感器W1C和W5C主要对食品中的芳香类物质灵敏,而传感器W5S主要对氮氧化物灵敏。值得一提的是,传感器W3C、W6S、W1S、W1W、W2S、W2W和W3S对不同处理工艺猕猴桃果酒的相应值差异不显著 (P>0.05)。由此可见,带皮发酵猕猴果酒的风味品质较清汁发酵和去皮发酵较佳。陈红梅等的研究结果与本研究相同,通过采用GC-MS技术对不同工艺处理野生猕猴桃酒风味品质 进行解析发现,带皮发酵的猕猴桃果酒香气物质总量显著偏高(P<0.05),且酒中的酯类、萜烯类和酮类物质质量浓度亦相对较高。 2.3不同处理工艺对猕猴桃果酒色泽品质的影响 不同处理工艺猕猴桃果酒的色泽测定结果如表3所示。由表3可知,带皮发酵的猕猴桃果酒其亮度(L*值)显著高于清汁发酵(P<0.05),而红绿度(a*值)显著高于去皮发酵(P≤0.05)。值得一提的是,不同处理工艺的猕猴桃果酒在黄蓝度(b*值)上并无显著性差异 (P>0.05)。 表3不同处理工艺猕猴桃果酒色泽品质的差异性分析 Table 3 Difference analysis of each color indexes of kiwifruit winesfermented by different treatment processes 指标 清汁发酵 去皮发酵 带皮发酵 L*值(亮度) 23.1±0.64b 26.56±0.62a 26.47±1.2a a*值(红绿度) -0.07±0.21a -0.23±0.1b 0.16±0.19a b*值(黄蓝度) 3.48±0.28a 3.30±0.17a 3.48±0.56a 2.4不同处理工艺猕猴桃果酒品质区分度的评价 以滋味和气味为评价指标,基于PCA不同处理工艺猕猴桃果酒品质的因子载荷图如图2所示。 图2基于PCA不同处理工艺猕猴桃果酒品质的因子载荷图 Fig.2 Factor loading plot of the quality of kiwifruit wines fermentedby different treatment processes based on PCA 由图2可知,第一主成分 (principal component,PC) 由咸味、鲜味、后味A(涩味的回味)、丰度(鲜味的回味)、苦味和酸味构成,占全部权重的36.48%;第二主成分(PC2) 由W1W (对有机硫化物敏感)、W5S(对氢氧化物灵敏)、W2S(对乙醇灵敏)和W3S(对烷烃类物质灵敏)4个指标构成,占全部权重的22.33%。由此可见,PC1主要由猕猴桃果酒的滋味指标构成,而PC2主要由猕猴桃果酒的气味指标构成。进一步分析发现,PC1中载荷量最高的正相关指标是W1W,其载荷量为0.52,即PC1的差异主要集中在有机硫化物上;PC2中载荷量最高的正相关指标是咸味,其载荷量为0.41,而载荷量最高的负相关指标为酸味,其载荷量为0.39,即PC2的差异主要集中在酸味和咸味上。基于PCA不同处理工艺猕猴桃果酒品质的因子得分图如图3所所。 由图3可知,不同处理工艺猕猴桃果酒样品在空间排布上呈现出明显的分离趋势,其中清汁发酵样品全部分布于第二象限,去皮发酵样品多数分布于第三象限,而带皮发酵样品则主要分布于第一和第四象限。由此可见,不同处理工艺猕猴桃果酒品质存在明显的差异。带皮发酵样品较其他处理工艺样品在空间上的排布偏右,结合因子载荷图可知,带皮发酵果酒的咸味、鲜味、后味A(涩味的回味)和丰度(鲜味的回味)较强,这与Kruskal-Wallis检验结果一致。本研究进一步采用马氏距离聚类对不同处理工艺猕猴桃果酒品质的差异性进行了分析,其结果如图4所示。 图3基于PCA不同处理工艺猕猴桃果酒品质的因子得分图 Fig. 3 Factor score plot of kiwifruit wines fermented by differenttreatment processes based on PCA 由图4可知,清汁发酵和去皮发酵两者之间存在显著差异(P≤0.05),且两者与带皮发酵存在极显著差异(P<0.001)。由此可见,不同处理工艺猕猴桃果酒的品质存在显著差异。 注:“*”代表差异显著(P<0.05);“***”代表差异极显著(P<0.001)。 图4 不同处理工艺猕猴桃果酒品质的聚类分析 Fig. 4 Cluster analysis of the quality of kiwifruit wines fermented bydifferent treatment processes 2.5导致不同处理工艺猕猴桃果酒品质存在差异关键性指标的甄别 本研究采用RDA对导致不同处理工艺猕猴桃果酒品质存在显著差异的关键性指标进行了甄别,其结果如图5所示。 图5 不同处理工艺酿造猕猴桃果酒的RDA双序图 Fig. 5 RDA biplot of kiwifruit wines fermented by different treatmentprocesses 由图5可知,酸味、苦味、鲜味、W5S(对氮氧化物灵敏)和W1C(对芳香类物质灵敏)5个指标与RDA排序图约束轴上样本具有良好的赋值相关,因而代表了与不同处理工艺猕猴桃果酒品质差异显著相关的关键指标。由图5亦可知,酸味和苦味位于去皮发酵和清汁发酵猕猴桃果酒一侧,W5S位于清汁发酵一侧,而W1C和鲜味则位于带皮发酵一侧,由此可见,带皮发酵的猕猴桃果酒中鲜味和芳香类挥发性风味物质的强度要大于其余两组,而酸味、苦味和氮氧化物挥发性风味物质呈现出相反的趋势,这进一步证明带皮发酵猕猴桃果酒品质要优于清汁和去皮发酵的猕猴桃果酒。 3结论 使用电子舌、HPLC仪、电子鼻和色度仪对清汁、去皮和带皮发酵猕猴桃果酒的品质进行了评价,结果发现带皮发酵猕猴桃果酒的鲜味和咸味显著偏高(P<0.05),而酸味和苦味显著偏低 (P<0.05),同时带皮发酵猕猴桃果酒中芳香类物质较多而氮氧化物较少;带皮发酵猕猴桃果酒明亮度(L*值)显著高于清汁发酵(P<0.05),而红绿度(a*值)显著高于去皮发酵 (P<0.05);带皮发酵猕猴桃果酒的品质与清汁和去皮发酵猕猴桃果酒的品质差异显著(P<0.001)。由此可见,带皮发酵的猕猴桃果酒品质更优。 ( 参考文献: ) ( [1]张美芳,何玲,张美丽,等.猕猴桃鲜果贮藏保鲜研究进展[].食品品 学,2014,35(11 ) : 3 43-347. ) ( [2] LEE H Y , SEO W T, J EO N G S H, et al. Phys i cochemical chara c teristics and volatile flavor compounds of produced mixture w i ne w i th kiwi andpermission f ruits using wild yeast, Saccharomyces cerevisiae Y28[]. Kor JMicrobiol, 2016,52(1):98-109. ) ( [3]WOO S M, KIM O M, CHOI I W, e t al. C o nd i tion of a c etic aci d fermen-tation and e ffect of oligosaccharide addition on k i wi vinegar [J]. Kor JFood P res, 2007,14(1):100-104. ) ( [4]孙海涛,邵信儒,姜瑞平,等.响应面试验优化超声渗糖制备野生软枣猕猴桃果脯工艺及其质构分析[J].食品科学,2015,36(20):49-55. ) ( [5]陈红梅,王沙沙,尹何南,等.不同工艺处理对野生猕猴桃酒品质的影响[].食品科学,2018,39(4):2 3 3-240. ) ( [6] GARCI A C V , QUEK S Y, STEVENSON RJ, et al. Characterisation ofbound volatile compounds of a low fla v our kiwifruit species: Actinidiaeriantha[J]. Food Chem, 2012,134(2):655-6 6 1. ) ( [7] KIM J G, BE P PU K , K A TAOKA I. Varietal differences i n phenolic c on-tent and astringency in skin and flesh of hardy kiwifruit r esources in J apan[J] . Sci Hortic-Amsterdam, 2009,1 2 0(4):551-554. ) ( [8] SELLI S, CABAROGLUT, CANBAS A, et al. Effect of skin contact on the aroma composition of the musts of Vitis v inifera L. cv. Muscat of Bornova and N arince grown i n Turkey[J]. Food Chem, 2 003,81(3): 341-347. ) ( [9]杜昌陈,余元善,肖更生,等.添加柚果皮对沙田柚蒸馏酒风味品质的影响[J].广 东 农业科学,2015,42(17):90-95. ) ( [10] AMOS R L. S ensory properties of fruit sk i ns[J]. Postharvest Biol Tec,2007,44(3): 3 07-311. ) ( [11] MARSANASCO M, MARQUEZ A L, WAGNER J R, et a l . Bioactive compounds as fu n ctional food ingredients: c h aracterization i n m odelsystem and sensory evaluation in chocolate m i lk[J]. J F o od En g , 201 5 ,166:55-63. ) ( [12] NASSUR R C M R, PEREIRA G E, GLORIA M B A, e t al. Rootstock influencing the quality and biogenic amines content on S y rah tropical wines[J]. Com Sci, 2017,8 ( 2):2 0 2-208. ) ( [13] BIMPILAS A, PANAGOPOULOU M,TSIMOGIANNIS D,et al. A n- thocyanin copigmentation an d color of wine: the effect of naturally ob- tained hydroxycinnamic acids as cofactors[]. Food Chem, 2016,19 7 (4): 39-46. ) ( [14] CETO X , G ONZALEZ-CALABUIG A, CAPDEVILA J, et al. Instru- mental measurement ofwine sensory d e scriptors u sing a voltammetric electronic tongu e [J ] . Sensor Actuat B-Chem, 2015, 207:1053-1059. ) ( [15] COSTA A M S, SOBRAL MM C, DELGADILLO I, et al. Astringency quantification i n wine: comparison o f the electronic tongue and F T -MIR spectroscopy[]. Sensor Actuat B-Chem, 2015, 2 0 7:1095-11 0 3. ) ( [16] ZIOLKOWSKA A, WASOWICZ E, JEL E N HH.Differentiation of wines according t o grape v a riety and ge o graphical ori g in bas e d on vola t iles profiling using SPME-MS and SPME-GC/MS methods[J]. Food C h em, 2016,213:714-720. ) ( [17] MAYR C M , CAPONE D L, PARDON K H, et al. Quantitative analysisby GC-MS/MS of 18 aroma co m pounds related to oxidative off-flavorin wines[J ] . J Agr Food C hem, 2015, 63(13 ) :33 9 4-3401. ) ( [18] RODRIGUEZ-MENDEZ M L, APE T REI C, GAY M, et al. Evaluationof oxygen exposure levels and polyphenolic content of red wines using an e lectronic panel formed by an electronic nose and an electronic tongue[J] . Food Chem, 2014,1 5 5(7):91-97. ) ( [19] MANUEL A, CABELLOS J M, TERESA A, et al. Quantification of w inemixtures with an electronic nose and a human panel[ J ]. Front Bioeng Biot, 2018, 6 : 14. ) ( [20] MANETTA A C, DI GIUSEPPE L, T OF A LO R, et al. Evaluation ofbiogenic amines in wine: determination by an improved HPLC - P D A method[J].Food Control, 2016, 62:351-356. ) ( [21]LE E S, Y O O M, S HIN D. The ident i fication and quantification of bio- genic amines in Korean turbid rice wine, Makgeolli by HPLC with massspectrometry detection[J]. LWT-Food Sci Tech, 2015, 62(1): 35 0 -356. ) ( [22]郭壮,汤尚文,王玉荣,等.基于电子舌技术的襄阳市售米酒滋味品质评价[J.食品工业科技,2015,36(15):289-293. ) ( [23]杨成聪,沈馨,马雪伟,等.高效液相色谱法测定米酒中有机酸的含 量[J].食品研究与开发,2018,39 (10):116-123. ) ( [24]张淼,贾洪锋,刘国群,等.电子鼻在芝麻酱品质识别中的应用[] . 食 品科学,2017,38(8):313-317. ) ( [25]王玉荣,张俊英,潘婷,等.米米米酒和糯米米酒品质的评价[].食品 与发酵工业,2017,43(1):186-191. ) ( [26] KOBAYASHI Y , HABARA M, IKEZAZ K I H, et al. A d vanced t a stesensors b ased on artificial l ipids with global selectivity to basic t aste qualities and high correlation to sensory scores[J].Sensors, 2010,1 0 (4):3411-3443. ) (C)China Academic Journal Electronic Publishing House. All rights reserved. http://www.cnki.net 样品:自制猕猴桃果酒主要仪器:PEN3电子鼻(配备10 个金属氧化传感器),德国Airsense公司 SA402B电子舌,日本Insent公司检测指标:猕猴桃果酒的生产和品质评价实验过程:1、基于电子舌猕猴桃果酒滋味品质评价 样品处理:准确量取40 mL猕猴桃果酒与80 mL超纯水混合均匀,静置15min后抽滤,滤液10 000 r/min离心10min,取上清液待用。 电子舌测试条件:参照郭壮等[22]的方法并进行适当的优化,每组样品平行测定4次。数据处理:删除第1 次测试实验值,取第2、3和4次实验值作为原始数据,并使用电子舌自带工作站对电子舌的响应值进行分析。2、基于电子鼻技术猕猴桃果酒风味品质评价 样品处理:准确吸取15 mL猕猴桃果酒样品于电子鼻样品瓶中,55℃保温10 min后室温平衡10 min,即可插入电子鼻探头进行顶空进样测试。 电子鼻测试条件:参照张淼等[24]对芝麻酱品质评价中的测试条件,并进行适当优化。数据处理:金属氧化电极测定在45 s后达到稳定,本研究选取49 s、50 s和51 s时的平均值为测试数据,平行测定3次。实验结果:分别采用清汁、去皮和带皮的工艺酿造猕猴桃果酒,并对不同处理工艺酿造果酒的品质进行评价。结果表明,经电子舌检测发现,带皮发酵猕猴桃果酒的鲜味和咸味显著偏高(P<0.05),而酸味和苦味则呈现出相反的趋势(P<0.05)。经高效液相色谱(HPLC)检测发现,带皮发酵猕猴桃果酒中奎尼酸、柠檬酸、苹果酸和乳酸含量显著偏低(P<0.05)。经电子鼻检测发现,传感器W1C和W5C对带皮发酵猕猴桃果酒的响应值显著偏高(P<0.05),而传感器W5S呈现出相反的趋势(P<0.05)。经色度仪检测发现,带皮发酵的猕猴桃果酒其亮度(L*值)显著高于清汁发酵(P<0.05),而红绿度(a*值)显著高于去皮发酵(P<0.05)。通过主成分分析(PCA)、聚类分析(CA)和多变量方差分析(MANOVA)发现,带皮发酵的猕猴桃果酒品质更优。研究意义:本研究采用电子舌、电子鼻、HPLC仪和色度仪对不同处理工艺酿造猕猴桃果酒的品质进行了数字化评价,并结合多元统计学分析方法探讨了不同处理工艺对猕猴桃果酒品质的影响,以期为后续猕猴桃果酒的生产和品质评价提供参考。
关闭还剩3页未读,是否继续阅读?
北京盈盛恒泰科技有限责任公司为您提供《猕猴桃果酒中品质和风味检测方案(感官智能分析)》,该方案主要用于葡萄酒及果酒中营养成分检测,参考标准《暂无》,《猕猴桃果酒中品质和风味检测方案(感官智能分析)》用到的仪器有日本INSENT味觉分析系统(电子舌)。
