APPLICATION NOTEF&F-S-007-2016/A1 CRUDE FAT DETERMINATION IN SESAME SEEDSRANDALL METHOD Crude Fat Determination in SesameSeeds according to the Randall method Reference: AOAC Official Method 2003.06 Tested with VELP Scientifica SER 158/6 Solvent AutoExtractor (Code S303A0380) Introduction Sesame seed is one of the oldest oilseed crops known, domesticated well over 3000 years ago. Numerous wild relativesoccur in Africa and a smaller number in India. It is widely naturalized in tropical regions around the world and iscultivated for its edible seeds. The world harvested 4.2 million metric tonnes of sesame seeds in 2013, with India andChina as the largest producers. Sesame seed is a common ingredient in various cuisines. It is used whole in cooking forits rich, nutty flavour. The sesame seed is very energetic food and contain a very high quantity of fat (around 50%). Fat Determination in Sesame Seeds Hot solvent extraction process with SER 158 Series can be summed up in 5 steps, for a fully unattended operation: During IMMERSION the sample is immersed in boiling solvent. Then the REMOVING step automatically lowers the levelof the solvent to below the extraction thimble. During WASHING the condensed solvent flows over the sample andthrough the thimble to complete the extraction process. The fourth step involves solvent RECOVERY. Approximately90% of the solvent used is collected in the internal recovery tank. The final step is the COOLING of the extraction cupscontaining the extracted matter. The cups are raised to prevent burning. The extraction cups containing the extract areplaced in a drying oven, cooled in a desiccator and weighed for the extract percentage calculation. Sample Sesame seed Fat range value: 55 g / 100 g Chemicals and Equipment Required ●Analytical balance, 3 decimals Viton seals (Code A00000297) ●Extraction thimbles (33x80 mm) (Code A00000295) ·NN-hexane solvent Glass extraction cups O 56x120mm (Code A00000290) Blade grinder Sample Preparation Fix the Extraction thimbles with the Extraction thimbles holders (Code A00000312). Homogenize through blade grinderaround 40 g of sesame seeds in an empty and clean beaker. Then, put 3 g of sample in the VELP extraction thimbleswith a spatula. Position the extraction thimbles in the extraction cups. Glass Extraction Cups Preparation Position the empty extraction cups in an drying oven (105°C) for 1 hour. Cool them in a desiccator until constant weight of the tare (Tare). The extraction cups containing the extraction thimblecan now be placed on the ultra-fast heating plate of SER 158. Extraction Procedure with SER 158 On the ControlPad select “Analysis", and create a new customer method“Determination of crude fat in sesame se ecsetting the following parameters: ●·Immersion Time: 60 minutes · Cooling Time: 20 minutes Removing Time: 10 minutes EExtraction cups: standard 0 56x120mm● Washing Time: 50 minutes Thimble: 33x80 mm ● Recovery Time 30 minutes .Solvent: n-hexane, 100 ml VELP Scientifica, Italy Tel: +39 039 628 811 Fax: +39 039 628 8120 www.velp.com Close the safety guard and add the solvent using the automatic solvent dispensing system SolventXpress TM to minimizeexposure to the solvent ensuring operator safety. Press START to begin the extraction process. At the end of analysis position the extraction cups containing the extractin a drying oven (1 hour at 105℃), cooled them in a desiccator to room temperature and record the accurate weight(Total). Typical Results on Sesame seeds Analysis results are calculated automatically and stored in the ControlPad when entering the weights into the software(manually or automatically through a balance). The extract percentage calculation is performed by using the followingformulas: Extract(g)=(Total-Tare) Extract (%)=Extract x 100/ (Sample) Where: Sample= sample weight (g) Tare= weight of the empty extraction cup (g) Total= weight of the extraction cup +extract (g) Tare (g) Sample (g) Total (g) Extract (g) Extract (%) 133,7082 3,0318 135,3969 1,6887 55,70% 137,898 3,0573 139,5957 1,6977 55,53% 138,1604 3,0827 139,8498 1,6894 54,80% 131,5559 3,0492 133,2427 1,6868 55,32% 131,7544 3,0505 133,4416 1,6872 55,31% 133,8145 3,0664 135,5026 1,6881 55,05% Average± SD% 55,28±0,32% RSD% ** 0,584% Fat Labeled Value: 55 g/ 100 g ** RSD%=(Standard Deviation x 100)/ Average Conclusion The results obtained are reliable and reproducible in accordance with the expected values, with a low relative standarddeviation (RSD<1%), that means high repeatability of the results. Therefore, SER 158 Solvent Extractor is ideal for the fat content determination in sesame seeds. Benefits of hot solvent extraction (Randall) by using 158 Automatic Solvent Extractor: - up to 5 times faster than Soxhlet (hot solvent vs. cold solvent) -low solvent consumption (high solvent recovery, approximately 90%)-limited cost per analysis -no exposure to solvent -worldwide official method -full traceability with automatic result calculation and on-board archive Copyright C VELP Scientifica. All rights reserved.No part of this publication may be reproduced or transmitted in any form or for any purpose without the express permission of VELP.VELP Scientifica, Italy Tel: + Fax:+ www.velp.com 利用SER158分析芝麻中的粗脂肪含量:芝麻是已知的最古老的油料作物之一,距今已有3000多年的历史。 非洲有许多野生亲缘种,印度有少量。 它在世界各地的热带地区被广泛归化,并因其可食用种子而被种植。 2013年,全世界收获了420万吨芝麻,印度和中国是最大的生产国。 芝麻是各种美食中的常见成分。 它具有丰富的坚果风味,可整体用于烹饪。 芝麻是非常有活力的食物,并且含有大量的脂肪(约50%)。具体分析请下载全文。
关闭还剩1页未读,是否继续阅读?
意大利VELP公司为您提供《芝麻中粗脂肪检测方案(抽提萃取)》,该方案主要用于生干坚果与籽类食品中粗脂肪检测,参考标准《暂无》,《芝麻中粗脂肪检测方案(抽提萃取)》用到的仪器有VELP SER 158 全自动脂肪测定仪(索式抽提仪)。
