全自动液液萃取——VERSA1100
检测样品 畜禽肉及副产品
检测项目 脂质
关联设备 共4种 下载方案
方案详情
液-液萃取(LLE)法是油脂组学研究中常用的质谱样品制备方法。VERSA 1100自动液–液萃取工作站已配置为使用氯仿:甲醇(Bligh and Dyer或Folch)方法从生物样品中提取脂质,以减少人为误差并提高效率。
100000000Peak area from manual extraction500000001500000002000 200000000 180000000 160000000 v=0.9429x1400000001200000001000000008000000060000000400000002000000000 全自动液液萃取——VERSA1100Liquid-liquid extraction (LLE) method is commonly used for mass spectrometry sample preparation in lipidomics research. The VERSA 1100 Automated Liquid-Liquid Extraction Workstation has been configured to extract lipids from biological samples using the chloroform:methanol (Bligh and Dyer or Folch) method to reduce human error and increase efficiency.Below are the data generated from extracting lipids from chicken liver samples. In brief, samples are extracted in 15x85mm glass tubes in 24 sample/batch. This automated procedure includes adding solvents, mixing, phase separation, drying, reconstitution, adding internal standard and sample transfer. Compared to manual chloroform:methanol lipid extraction experiment, the automated extraction efficiency was found to be 94.3% and the coefficient of variation (CV) for the extraction of top 200 lipids from chicken liver using VERSA 1100 was 2-fold lower than that obtained with manual extraction. The VERSA 1100 Automated Lipid Extraction workstation is also compatible with non-chlorinated solvent systems such as MTBE and BUME methods.
关闭
  • 1/1
产品配置单
加拿大欧罗拉生物科技有限公司为您提供《全自动液液萃取——VERSA1100》,该方案主要用于畜禽肉及副产品中脂质检测,参考标准《暂无》,《全自动液液萃取——VERSA1100》用到的仪器有液液萃取工作站 加拿大欧罗拉VERSA 110 LLE、欧罗拉化学液液萃取自动化液体处理工作站、欧罗拉液液萃取工作站 VERSA 1100 LLE、实验室液液萃取移液工作站 欧罗拉LLE。
我要纠错
推荐专场
相关方案
