赛默飞是科学服务领域的世界领导者 实验背景 客户名称:上海实朴 测试人:杨艳整理(客户处实验) 赛默飞世尔科技(中国)应用中心 我们的使命:携手客户,让世界更健康,更清洁,更安全 赛默飞为您提供最完整的超快速液相技术支持 实验目的 根据标准HJ 997-2018土壤和沉积物醛、酮类化合物的测定高效液相色谱法进行15中醛、酮类的方法开发,仪器为U3000液相色谱仪。 样品信息 土壤和沉积物样品用醋酸-醋酸钠溶液振荡提取,提取液中醛、酮类化合物在40℃和pH3条件下衍生1h,然后对衍生溶液进行液液萃取,目标溶液进行脱水浓缩,用乙腈复溶,待测。 仪器配置 U3000系列 泵:: LPG-3400SD 自动进样器:\WPS-3000 柱温箱:TCC-3000 UltiMateTM 3000 检测器::VWD-3100 变色龙色谱管理软件 Chromeleon CDS 7.2 分析条件 方法信息: 梯度程序 时间 A B 0 45 55 8 45 55 16 60 40 27 70 30 27.1 45 55 33 45 55 ooasta 线性:0.025ppm-2ppm Peak Peak Name Ret.Time Cal.Type Eval.Type Number Coeff.of C0 C1 No. min of Points Determination (Offset) (Slope) 1 Formaldehyde 6.311 Lin, WithOffset Area 6 0.99998 0.0002 0.4369 2 Acetaldehyde 9.388 Lin, WithOffset Area 6 0.99994 -0.0012 0.4608 3 Acetone 12.996 Lin, WithOffset Area 6 0.99964 0.0052 0.435 4 Acrolein 13.241 Lin, WithOffset Area 6 0.99921 -0.007 0.483 5 Propionaldehyde 14.421 Lin, WithOffset Area 6 0.99999 0.0007 0.4354 6 Crotonaldehyde 16.631 Lin, WithOffset Area 6 0.99994 -0.002 0.452 7 Butyraldehyde 18.046 Lin, WithOffset Area 6 0.99999 0.0007 0.4275 8 Benzaldehyde 19.553 Lin, WithOffset Area 6 0.99975 -0.0033 0.39 9 Isovaleraldehyde 21.158 Lin, WithOffset Area 6 0.99989 -0.0001 0.4213 10 Valeraldehyde 21.746 Lin, WithOffset Area 6 0.99994 0.0003 0.4092 11 o-Tolualdehyde 22.671 Lin, WithOffset Area 6 0.99976 -0.0034 0.3575 m-Tolualdehyde+p- 12 Tolualdehyde 23.075 Lin, WithOffset Area 6 0.99976 -0.0075 0.7148 13 Hexaldehyde 25.736 Lin, WithOffset Area 6 0.99994 0.0015 0.3793 14 2,5-Dimethylbenzaldehyde 26.298 Lin, WithOffset Area 6 0.99973 -0.0007 0.3261 Minimum 0.99921 精密度:: n=7 Peak Peak Name Ret.Time Area No. RSD(%) RSD(%) Formaldehyde 0.05% 0.43% Acetaldehyde 0.05% 0.81% Acetone 0.02% 0.67% Acrolein 0.02% 0.82% Propionaldehyde 0.01% 0.34% Crotonaldehyde 0.01% 0.38% Butyraldehyde 0.01% 0.26% Benzaldehyde 0.01% 0.86% Isovaleraldehyde 0.01% 0.91% Valeraldehyde 0.01% 0.22% o-Tolualdehyde 0.01% 0.43% m-Tolualdehyde+p-Tolualdehyde 0.02% 0.45% Hexaldehyde 0.01% 0.80% 2,5-Dimethylbenzaldehyde 0.02% 0.68% Maxmum 0.05% 0.91% 该方法在0.025~2ppm浓度范围内线性良好,线性相关系数均大于0.999。 The world leader in serving scienceProprietary & Confidential ThermoFisherSCIENTIFICProprietary & Confidential 该方法在0.025 ~2 ppm浓度范围内线性良好, 线性相关系数均大于0.999。
关闭还剩8页未读,是否继续阅读?
赛默飞色谱与质谱为您提供《土壤和沉积物中醛酮类检测方案(液相色谱仪)》,该方案主要用于土壤中有机污染物检测,参考标准《暂无》,《土壤和沉积物中醛酮类检测方案(液相色谱仪)》用到的仪器有赛默飞Vanquish Core液相色谱。
