食品科技FOOD SCIENCE AND TECHNOLOGY·食品安全与检测2015年第40卷第02期 TPA质构分析茎瘤芥脱水过程中质地变化 孙钟雷,彭怡梅,张长平,许艺,潘宁,华次 (长江师范学院生命科学与技术学院,重庆408100) 摘要:应用质地多面分析(TPA)方法,以新鲜茎瘤芥为试材,研究其在风脱水和盐脱水过程中的质地变化。结果表明::茎瘤芥的硬度与脆性、凝聚性与弹性、咀嚼性之间相关性良好,回复性与其他质地参数相关性都较差;在风脱水和盐脱水中各项质地参数之间的相关性表现一致;脆性、凝聚性、弹性、咀嚼性能作为评判茎瘤芥质地的代表性参数。在风脱水期间茎瘤芥质地的代表性参数变化较为稳定,质地特性易于控制,而盐脱水的质地参数变化较大;经过风脱水后除了脆性外,其他质地参数值均低于盐脱水的。试验也表明TPA测试能够较好地反映茎瘤芥各项质地参数的变化规律,适用于茎瘤芥质地品质的客观评价。 关键词:茎瘤芥;质地;脱水;质地多面分析 中图分类号:TS201.7 文献标志码:A 文章编号:1005-9989(2015)02-0348-04 DOI:10.13684/j.cnki.spkj.2015.02.071 Changes in texture properties of tumorous stem mustard duringdehydration by texture profile analysis SUN Zhong-lei, PENG Yi-mei, ZHANG Chang-ping, XU Yi, PAN Ning, HUA Liu-ci(College of Life Science and Technology, Yangtze Normal University, Chongqing 408100) Abstract: Changes in texture properties of tumorous stem mustard were investigated by texture profileanalysis (TPA) during the wind dehydration and salt dehydration. The results showed that the hardnessof tumorous stem mustard with the crispness and the cohesiveness with elasticity, chewiness hadgood correlations, while the resilience had poor correlations with the others. The correlation of everytexture parameters was coincident during the wind dehydration and salt dehydration. The crispness,cohesiveness, elasticity, chewiness were as the typical parameters to evaluate texture properties oftumorous stem mustard. Changes of the typical parameters were stable and susceptible to control duringthe wind dehydration, while the typical parameters exhibited big changes during the salt dehydration. Thevalues of the typical parameters after the wind dehydration were less than them after the salt dehydrationexcluding the value of crispness. In conclusion, TPA test can reflect the changes in texture parameters oftumorous stem mustard and is suitable for the evaluation of tumorous stem mustard texture quality. Key words: tumorous stem mustard; texture; dehydration; texture profile analysis ( 收稿日期:20 1 4-1 0 - 0 8 ) ( 基金 项目 : 重 庆 市科委基础与前沿研究项目(CSTE201 3 J CVJA0098) ; 涪陵区科委科技项目(FL KJ, 2 01 3 ABB20 79) :榨菜 种植与深加工创新团队项目;三峡库区特色作物工程研究中心 项 目。 ) ( 作者简介:孙 钟雷(197 9一 ),男,博士,副教授,研究方向为食品智能检测与评价。 ) 茎瘤芥是加工榨菜的主要原材料,它是通过脱水、腌制、压榨等工艺制成榨菜的"。在脱水过程中茎瘤芥的质地变化会直接影响到榨菜的脆嫩口感,因此研究茎瘤芥在脱水过程中的质地变化有重要意义。此外,常用的茎瘤芥脱水方式主要有风脱水和盐脱水I2-5],分析这2种脱水方式对榨菜质地的影响也十分必要。 目前,分析果蔬质地特性的方法主要有感官评定法和质构仪器测定法。感官评定法主要依靠人们的口感判断,虽然是主要的分析方法,但是其主观性强、结果不稳定16-7]。近年来,质构仪器测定法使得果蔬质地评价的内容更为丰富,评价结果更为客观,克服了传统感官评定法的一些缺点。质地多面分析(Texture profile analysis, TPA)是最常用的质构仪器测定模式,它是利用力学测试来模拟人的2次咀嚼动作,在测试过程中获取探头对试样的压力以及其他相关质地参数[8-9)。国内外学者已经利用质地多面分析法对苹果[10-13]、桃子114-15]、番茄116-17]、萝卜118-19]、腌制菊芋I20]等果蔬的质地特性进行了深入研究,并且取得了良好的测试效果。但是,在茎瘤芥质地研究方面未见报道。 本研究拟采用质地多面分析法对风脱水、盐脱水过程中茎瘤芥的质地指标进行测试,试图找出对茎瘤芥质地评判的代表性参数,并且对比分析风脱水、盐脱水对榨菜质地的影响差异。 1 材料与方法 1.1 材料与仪器 茎瘤芥(涪式5号):新鲜、无病虫害、无机械损伤,涪陵新大兴农贸市场。 TMS-PRO食品物性分析仪:美国FTC公司; DHG-9245A恒温鼓风干燥箱:上海齐欣仪器公司。 1.2脱水方法 将茎瘤芥洗净、晾干后,进行去筋修整处理,然后切分成长50 mm、宽20 mm、厚20mm的长方体块,备用。将处理好的茎瘤芥块分别进行风脱水14-5l和盐脱水B-41。风脱水在电热恒温鼓风干燥箱中进行,温度设定为60℃、风力为2级、脱水时间为8h,每脱水1h取一次试样进行质地测试,共计9个测试点。盐脱水在腌菜坛中进行,首先将准备好的茎瘤芥块采用4%食盐腌制48h, 压榨后24h再使用9%食盐腌奄72h,每脱水24h取一 次试样进行质地测试,共计7个测试点。 1.3质地特性测试方法 将风脱水和盐脱水过程中取出的茎瘤芥试样使用打孔器和双切刀处理成直径为10 mm、厚度为8mm的规则试样,使用TMS-PRO食品物性分析仪在TPA模式下进行测试。测试条件为:使用TMS25.4圆柱形探头,对试样块压缩2次;测试前后与测试速度均为60 mm/min;压缩形变量70%、触发力0.2N、回程高度15 mm;同一种试样重复测试10次。由图1茎瘤芥TPA试验质地特征曲线得到表征茎瘤芥质地的参数:硬度、脆性、凝聚性、回复性、弹性、咀嚼性。 图1 茎瘤芥TPA试验质地特征曲线 1.4 数据处理方法 采用Excel2010软件对数据进行统计分析与制图,采用SPSS13.0软件对数据进行相关性分析等。 2结果与分析 2. 质地参数间的相关性分析 茎瘤芥在脱水过程中,TPA测试的各项质地参数相关性分析结果如表1所示。在脱水过程中 表1TPA试验所得茎瘤芥各项质地参数间的相关性(R) 参数 脱水 方式 硬度 脆性凝聚性回复性 弹性 咀嚼 性 硬度 风脱水 1 盐脱水 11 脆性 风脱肪 0.963** 1 盐脱水 0.888** 1 凝聚 风脱水 0.361 0.315 1 性 盐脱水 -0.590 -0.756 1 回复 风脱水- -0.075-0.073-0.075 1 性 盐脱水 0.348 0.124 -0.095 1 风脱水 0.3790.304 0.984**-0.158 1 弹性 盐脱水 -0.569 -0.5830.822*0.148 1 咀嚼 风脱水 0.357 0.2900.989**-0.167 0.997** 1 性 盐脱水 0.506-0.504 0.824*0.1090.988** 1 注:**表示在P<0.01极显著相关;*表示在P<0.05显著相关。 茎瘤芥的硬度与脆性呈极显著正相关性(P<0.01),即硬度越大,脆性越大,这符合果蔬的硬脆性特点;与凝聚性、回复性、弹性、咀嚼性相关性较低;对于脆性,除了与硬度相关性极显著以外,与其他质地参数相关性也较低,因此硬度与脆性2项参数都可以反映茎瘤芥的坚实度,在分析茎瘤芥质地时可任选其一。在评判榨菜质地时,经常使用“脆”来描述,因此在分析茎瘤芥质地特性时可选择脆性。凝聚性与弹性、咀嚼性存在较好的相关性(R=0.822~0.989),说明以上几项参数共同反映茎瘤芥的质地特性,因此它可以作为一项质地评价参数。在TPA测试结果中,回复性与其他参数的相关性都较低,而弹性与凝聚性、咀嚼性都具有很好的相关性,可能由于茎瘤芥在一次受压时没有能迅速恢复变形,而在2次压缩时形变恢复较好,弹性很好地反映了茎瘤芥质地特性,其可靠性优于回复性。咀嚼性是硬度、凝聚性、弹性的乘积,它与凝聚性、弹性呈现显著的相关性,却与硬度相关性较低,可能是由于茎瘤芥在脱水过程中,弹性形变恢复较好,抵抗咀嚼破坏的能力较强。对于2种脱水方式而言,茎瘤芥在风脱水和盐脱水中各项质地参数之间的相关性表现一致;在风脱水中茎瘤芥的硬度与脆性、凝聚性与弹性、咀嚼性之间相关系数均大于盐脱水中的。综上分析,在脱水过程中脆性、凝聚性、弹性、咀嚼性均能很好地反映茎瘤芥的质地变化,具有一定的代表性。 2.2脱水过程中质地参数的变化分析 2.2.1 脆性的变化 图2脱水过程中茎瘤芥脆性变化 由图2可知,在风脱水过程中,茎瘤芥的脆性先增大后减小,然后再增大、减小,最后呈增大趋势,整体波动不大,最大值为100.2N,最小值为63.3N,这说明热风脱水过程中茎瘤芥内部水分蒸发均匀,内部组织坚实度变化较小。在盐脱水过程中,茎瘤芥的脆性先减小再增大,最后呈减小趋势,在第一次腌制时脆性最小,为67.0N,在第2次腌制时脆性最大,为100.0N。盐脱水的茎瘤芥要经历腌制、压榨等过程,脆性变化相对于风脱水较大;盐脱水后的茎瘤芥的脆性略低于风脱水的。 2.2.2凝聚性的变化 图3脱水过程中茎瘤芥凝聚性变化 由图3可知,在风脱水过程中,茎瘤芥的凝聚性先快速减小,脱水1h后趋于稳定,保持在0.07,说明茎瘤芥通过风脱水后抵抗咀嚼破坏的结合力较稳定。在盐脱水过程中,茎瘤芥的凝聚性变化较大,而且不稳定,呈现先稍微增大再快速减小,最后增大的趋势,在压榨时凝聚性最低,仅为0.03。在风脱水期间茎瘤芥的凝聚性比盐脱水的稳定;风脱水后的茎瘤芥凝聚性低于盐脱水的。 2.2.3 弹性的变化 由图4可知,在风脱水过程中,茎瘤芥的弹性先快速减小,脱水1h后趋于稳定,保持在1.96,说明茎瘤芥通过风脱水形变的恢复较稳定。在盐脱水过程中,茎瘤芥的弹性变化较大,呈现先快速减小,再缓慢增大的趋势,最后为3.60。在风脱水期间茎瘤芥的弹性比盐脱水的稳定;风脱水后的茎瘤芥的弹性低于盐脱水的。 12 图4 脱水过程中茎瘤芥弹性变化 2.2.4 咀嚼性的变化 200r 图5脱水过程中茎瘤芥咀嚼性变化 由图5可知,在风脱水过程中,茎瘤芥的咀嚼性先快速减小,脱水1h后趋于稳定,保持在13.55N,说明茎瘤芥通过风脱水耐咀嚼的能力较为稳定。在盐脱水过程中,茎瘤芥的咀嚼性变化较大,呈现先快速减小,再缓慢增大的趋势,最后为56.10N,在压榨时最低,仅为5.30N。在风脱水期间茎瘤芥的咀嚼性比盐脱水的稳定;风脱水后的茎瘤芥咀嚼性低于盐脱水的。 3结论 本研究利用TPA质地剖面分析法测试了茎瘤芥在脱水过程中的各项质地参数,相关性分析表明硬度与脆性、凝聚性与弹性、咀嚼性之间相关 性良好,可以应用TPA试验分析测定茎瘤芥的质地特性。茎瘤芥在风脱水和盐脱水中各项质地参数之间的相关性表现一致,其中脆性、凝聚性、弹性、咀嚼性均能很好地反映茎瘤芥在脱水过程中的质地变化,具有一定的代表性。 通过对风脱水和盐脱水过程中代表性质地参数的变化分析表明,风脱水期间的脆性、凝聚性、弹性、咀嚼性较为稳定,质地特性易于控制,而盐脱水的质地参数变化较大,其中盐脱水的压榨工艺对质地参数影响较大;经过风脱水后除了脆性外,其他质地参数均低于盐脱水的。 目前,市场上的榨菜大多是由茎瘤芥经过盐脱水制得的,很少采用传统的风脱水,但是消费者通常认为风脱水制得的榨菜口感、风味要好一些。通过本文研究,风脱水的茎瘤芥仅在脆性方面优于盐脱水的,其他质地参数并不高于盐脱水的,因此对风脱水和盐脱水工艺生产的榨菜的品质差异还需进一步综合分析评判。 ( 参考文献: ) ( [1 ] 中 华人民共和国国家质量监督检疫检验总局.G B/T1985 8一 20 0 5 ,地理标志产品 ( 涪陵榨 菜 )[ S ].北京: 中 国标 准出版社 , 2 005 ) ( 2] 曾凡坤,王 中 凤 , 吴 永 娴,等.传统涪陵榨菜工业化 生 产工艺 研 究[. 中国 食 品学 报,2 0 04 , 4 (1 ) :2 4 - 2 9 ) ( [31 李金 红 . 榨 菜盐脱水腌制生产工艺[J] .中 国 调 味品, 2 0 05, 3 0( 2 ) : 38 - 3 9 ) ( [4] 王燕,吴卫国,曹晖.低盐榨菜腌制前后物质消长变化规律的研 究[ J] .食 品 工 业 科 技,2000, 21( 3 ) : 26- 2 8 ) ( [51 贺云 川 ,董泽军,赖贞梅.榨菜原料加工中带 十和 去叶青菜头风脱水速 率 的对比研 究[J ]. 南方 农业 , 201 1,12 ( 5) : 40 - 42 ) ( [6] M OJET J , K OSTER E P . S e n s ory m e mory and fo od t ext u re [J] . F o o d Quality a nd P re f e r e n ce,2005,16(3 ) : 25 1- 2 66 ) ( [7] B OOTH D A , E A R L T, M O BI NI S. P e r c eptu a l chann e ls f o r the texture of a f o od[J ] . Appet i te,200 3 ,4 0 ( 1 ): 6 9-76 ) ( 李里 特 .食品物性 学[ M] . 北京:中 国 国业 出版 社,20 01 ) ( 吴洪华,姜 松 .食品质地及 其 T PA 测试 J. 食品研究与开发, 2 005, 2 6( 5) :128-1 3 1 ) ( [10] 李江阔,林洋,张鹏,等.采后 不 同时期1- MCP 处 理 对苹果果 实 质地 的 影响 [J ].食 品 科学 , 2013, 34(20):2 7 7-281 ) ( [11] 潘秀娟,屠康.质构仪质地多面 分 析(T PA) 方 法 对苹果采后质地变 化 的检 测 [ J ]. 农业 工程学报,200 5,21( 3 ) : 166- 170 ) ( 12] HARKER F R,M A IND O NALD J. M U R RAY S H, e t a l .S e n sor y i nterpr e t a tion o f i nstrumental m e asuremen t : t extur e o f app l e fr u it [ J]. Po stharv e s t Bi o l og y Te chn o l og y,2002, ) 中国南方适栽蓝莓品种果实氨基酸组成分析 严红光,杨 卫,鲜殊,丁之恩” (1.凯里学院环境与生命科学学院,凯里556001; 2.安徽农业大学茶与食品科技学院,合肥230036) 摘要:利用邻苯二甲醛柱前衍生反相高效液相色谱法分析6个中国南方主要栽培蓝莓品种果实的15种一级氨基酸组分。6个蓝莓品种的游离氨基酸含量差异较大,其中夏普兰含量最高,为(715.5±9.9) mg/100 g鲜果重,最少的是杰兔,含量为(332.5±7.5) mg/100 g鲜果重,6个品种间总游离氨基酸含量的变异系数为34.22%。利用SPSS17.0软件分析6个品种蓝莓果实氨基酸组分含量、总氨基酸含量和粗蛋白质含量之间的Spearman相关系数,结果表明丝氨酸、组氨酸和苏氨酸各自都与氨基酸总量及蛋白质含量达显著水平。研究结果有利于为蓝莓资源高效利用和深加工提供科学依据。 关键词:蓝莓;氨基酸;高效液相色谱;柱前衍生化;邻苯二甲醛 中图分类号: TS 255.1 文献标志码:A 文章编号:1005-9989(2015)02-0352-05 DOI:10.13684/j.cnki.spkj.2015.02.072 Amino acid composition analysis of blueberry cultivaries from southChina YAN Hong-guang, YANG Wei, XIAN Shu’, DING Zhi-en 收稿日期:2014-05-09 *通讯作者 基金项目:贵州省科技厅自然科学研究项目(黔科合J字[2013]2264号);黔东南州2013年度科技计划项目(州科通[2013]20号-4);凯里学院自然科学重点项目(Z1303);凯里学院博士科研启动项目(BS201322)。 作者简介:严红光(1981一),男,安徽巢湖人,博士,副教授,研究方向为经济济加工。 ( 2 4( 3): 225 - 239 ) ( [131 BILLY L , M EHINAG I C E , R O YER G . et a l . R e l a tionshi p be t ween t e x ture a nd pe c ti n c ompo s iti o n o f two apple c u ltiv ars d ur i ng st ora g e [J ]. P ostharvest B i o l og y and T e ch no l ogy ,2 008, 4 7( 3): 315 - 32 4 ) ( 114 1 袁成 龙 ,董晓颖,李培 环 ,等 .T PA质构分 析 硬肉桃果实采后质地变 化 [J. 食品 科学, 2 013, 34 (2 0 ) :27 3 - 2 76 ) ( 1151 姜松,陈 巧林. 水蜜桃在贮藏期 间的 质 地 变化规 律的 研究[ J] .食品 研 究与开发,2 0 0 6,27(5): 4 -5 ) ( 1161 裴娇艳.番茄果实采后品质特 性 变化 及 预测模型研究 ) ( [ D] .南京:南京农业大学 , 20 10 ) ( [1 7 ] 肖璐,郭风军,范新光,等 .RS M 法 分析压缩程度与压缩速率对樱桃番茄T PA质 构 特 性参 数 的影 响 [J ]. 食品科技, 2 014, 3 9( 4 ) : 257 - 263 ) ( [18] 张美霞,杨延杰 ,林 多.抽薹进程中萝卜 肉 质 根 主要质地 指标变化的研 究 [ J ].北 方园艺 ,2013 , 3 7(24):6 - 10 ) ( [191 姜松,冯峰, 赵 杰 文. 胡萝卜流变 特性 测试 的 差异 性 研究 [J] . 食 品 工业 科技,20 0 6 ,27(7) :5 5-58 ) ( [201 姜松,孟庆君,赵杰 文 .腌渍菊芋 的质 地分析与感官评价 研 究 [J ]. 食品科学,2007 ,28(12) : 7 8 -81 ) · · TPA质构分析茎瘤芥脱水过程中质地变化作者:孙钟雷,彭怡梅,张长平,许艺,潘宁,华畄次长江师范学院生命科学与技术学院 摘 要:应用质地多面分析(TPA)方法,以新鲜茎瘤芥为试材,研究其在风脱水和盐脱水过程中的质地变化。结果表明:茎瘤芥的硬度与脆性,凝聚性与弹性,咀嚼性之间相关性良好,回复性与其他质地参数相关性都较差;在风脱水和盐脱水中各项质地参数之间的相关性表现一致;脆性,凝聚性,弹性,咀嚼性能作为评判茎瘤芥质地的代表性参数。在风脱水期间茎瘤芥质地的代表性参数变化较为稳定,质地特性易于控制,而盐脱水的质地参数变化较大;经过风脱水后除了脆性外,其他质地参数值均低于盐脱水的。试验也表明TPA测试能够较好地反映茎瘤芥各项质地参数的变化规律,适用于茎瘤芥质地品质的客观评价。关键词:茎瘤芥 质地 脱水 质地多面分析
关闭还剩3页未读,是否继续阅读?
北京盈盛恒泰科技有限责任公司为您提供《茎瘤芥中质地变化检测方案(质构分析仪)》,该方案主要用于蔬菜中营养成分检测,参考标准《暂无》,《茎瘤芥中质地变化检测方案(质构分析仪)》用到的仪器有美国FTC-质构仪、FTC 质构仪TMS-Touch 。
