食品科技贮运保鲜一Vol.36,No.13,2015 食品工科技一贮远保鲜Science and Technology of Food Industry 不同温度对货架期樱桃挥发性物质变化的影响 罗 枫1,鲁晓翔1*,张 朋²,陈绍慧2,李江阔 (1.天津商业大学生物技术与食品科学学院,天津市食品生物技术重点实验室,天津300134;2.国家农产品保鲜工程技术研究中心,天津市农产品采后生理与贮藏保鲜重点实验室,天津300384) 摘 要:以“沙蜜豆”樱桃为试材,利用电子鼻检测系统和顶空固相微萃取-气相色谱质谱联用仪2种检测技术,对冷藏20d 后不同货架温度(13、20℃)不同时间(1、4、6d)樱桃芳香性物质变化进行分析。研究结果表明,应用主成分分析法、线性判别分析法、负荷加载分析法三种方法进行综合分析,电子鼻技术可以较好的区分不同货架温度下的樱桃。经 SPME-GC-MS 技术检测,得到樱桃果实中含量较高的成分是醇类和醛类,其中5种主要芳香性物质分别是苯甲醇、(E)-2-己烯醇、己醛、苯甲醛、(E)-2-己烯醛。发现13℃下1、4d时(E)-2-己烯醛含量趋于平稳状态,约在42%左右,6d时抑制受到缓和,(E)-2-己烯醛含量增至52%。20℃下1、4d时(E)-2-己烯醛已处于最高含量状态,约为53%左右,6d时其含量降至43%。这可能是由于低温环境下抑制了了桃中的(E)-2-己烯醛芳香性物质的生成。 关键词:电子鼻,顶空固相微萃取,气相质谱联用,货架期,樱桃 Study on aroma compounds of cherryunder different temperature during shelf life LUO Feng’,LU Xiao-xiang',ZHANG Peng’, CHEN Shao-hui’, LIJiang-kuo’ (1.Tianjin Key Laboratory of Food Biotechnology, College of Biotechnology and Food Science,Tianjin University of Commerce,Tianjin 300134, China; 2.Tianjin Key Laboratory of Postharvest Physiology and Storage of Agricultural Products, National Engineering andTechnology Research Center for Preservation of Agricultural Products, Tianjin 300384, China) Abstract: Summit cherry were studied as materials.Electronic nose and SPME-GC-MS were applied to detect thechanges of volatiles in Summit cherry which were stored under cold storage for 20d and then placed at differenttemperature(13,20℃) of shelf life in 1d,4d,6d.The results showed that: principal component analysis(PCA), lineardiscriminant analysis(LDA) and loading analysis (LA) could be used to distinguish cherry under differenttemperature treatment easily.More alcohols and aldehydes from Summit cherry were detected by SPME-GC-MS.Benzyl alcohol,(E)-2-hexenol,hexanal,benzaldehyde,(E)-2-hexenal were detected and determined as 5 kindsof main aromatic substances.It was found that the percentage of(E)-2-hexenal approaching stable around 42%when cherry was placed at 13℃ in 1~4d.And it rose to 52% when cherry placed for 6d.The percentage of(E)-2-hexenal approached the maximum value around 53% when cheery were placed under 20℃,1~4d.However, itdecreased to 43% for the sixth day. This might be caused by low temperature environment which could inhibitegenerating(E) -2-hexenal. Key words: electronic nose;headspace solid phase micro extraction; gas chromatography mass spectrometry;shelf life;cherry 中图分类号:TS255.3 文献标识码:A 文章编号:1002-0306(2015)13-0347-05 樱桃,属蔷薇科李亚科李属,又称甜樱桃、大樱桃,味美可口,并具有益气、健脾、祛风湿的功效,是具有较高营养价值和保健功效的水果,被誉为“果中珍品”-2。由于樱桃果皮薄、果肉软、果汁多,且樱 桃在盛夏(6~7月)时节采收上市,导致樱桃在贮运过程中很容易造成品质下降(果肉变软、表皮破损、风味变劣等)B3-4。 芳香性物质常被作为食品品质评价的重要手 ( 作者简介:罗枫(1 98 8-),女,在读硕士,研究方向:农 产 品加工与贮藏。 ) ( *通讯作者:鲁晓翔(1 962 -) , 女,硕士,教授,研究方 向 :天然产物研究与开发。 ) ( 基金项目 :“ 十 二 五 ”国家科技支撑计划 项目 (2012 BAD38B01); 天津市创新团队项目(TD12- 5049)。 ) 段,其风味直接影响到消费者的购买情况影-6。由于不同果蔬有其独特的芳香性成分,导致果蔬具有特殊的芳香气味。目前较为普遍的芳香性物质的检测,主要采用气相色谱-质谱联用(gaschromatography mass spectrometry,GC-MS)检测和电子鼻系统检测技术17-8。单独独用 GC-MS 技术对芳香性物质进行检测,需要将样品气味先分离,再将结果重新组合才能进行对比分析,缺乏对样品整体性的体现,很难与人类嗅觉进行科学、系统化的对比19-10。电子鼻技术可以用来做粗略的定性分析实验,内部的传感器阵列系统可以科学、可靠的对芳香气味及样品品质进行检测-12。因而将电子鼻与GC-MS联用可以弥补两者的不足之处,将优点最大化呈现。基于上述优点,近年来电子鼻与GC-MS 联用技术相结合的方式对食品中芳香性物质进行检测分析,越来越受到研究人员们的青睐。 目前,已有一些关于电子鼻与 SPME-GC-MS 对芳香性物质检测方面的报道。近两年的报道主要是关于鱼类013-14、浒苔L1S-16、乳酪工、巧克力、腊肉、苹果120等的气味物质的检测。丁媛2等应用电子鼻和 SPME-GC-MS技术,研究毛中中芳香性物质受温度变化的影响,研究表明电子鼻可以高效快速的区分不同温度处理下的毛的,GC-MS 可以鉴定出毛蚶中的特征性芳香性气味物质。在不同温度条件下贮藏,食品内部的芳香性物质含量会有所不同。目前,尚未发现电子鼻结合 SPME-GC-MS技术对不同货架温度下樱桃内部芳香性物质的研究报道。本文研究目的在于分析不同货架期温度下沙蜜豆樱桃主要气味物质及其变化,为今后果蔬货架期温度的选择等问题提供了科学的理论依据。 1 材料与方法 1.1 材料及仪器 沙蜜豆樱桃 于2014年6月10日采自河北省山海关区石河镇毛家沟村实验基地,采收成熟度约八成熟的果实,采摘当天运至国家农产品保鲜工程技术研究中心实验室(20±1.5)℃,立即进行如下处理:将樱桃按1.75kg/袋装入衬有 0.05mm PE 保鲜膜的塑料框中,膜敞口(0±0.5)℃冷库中预冷24h后,扎口在此温度下贮藏20d。将在冷库中冷藏 20d的樱桃样品取出6袋,分别在13、20℃恒温恒湿培养箱(湿度均为90%)放置3袋,每个温度处理下按照1、4、6d进行测定。 SPX-250-C智能型恒温恒湿培养箱 上海琅轩实验设备有限公司;PEN3电子鼻 德国 Airsense公司;高度交联,灰色平头/SPME萃取头 美国Supleco 公司;Trace-DSQ-MS气相色谱-质谱联用仪美国 Finnigan 公司。 1.2 电子鼻技术对樱桃内部风味物质的检测 1.2.1 电子鼻测定方法 取出的樱桃样品称取 30g左右分别放入250mL烧杯中用保鲜膜封口,在常温下放置30min,待样品挥发性物质挥发达到平衡后,用电子鼻对其进行测量,每个处理组平行测定10次,即做10次重复实验。 1.2.2 电子鼻测定参数 样品测定间隔时间:1s;样品准备时间:5s;样品测试时间:50s;清洗时间:220s;自动调零时间:10s;内部流量:100mL/min;进样流量:100mL/min。 1.2.3 电子鼻信号处理 通过电子鼻自带的WinMuster 软件对采集到的数据进行分析。 1.3 SPME-GC-MS 技术对樱桃内部风味物质的检测本文 GC-MS 的实验条件是在参考秦玲和王家喜等对樱桃挥发性成分研究报道中的方法基础上,稍加调整得出的。每个处理每次实验进行2次平行重复测定。 1.3.1 气相色谱条件 前处理方法:称取250g樱桃,去核打浆一4℃,8000r/min,15min→4层纱布过滤→8mL置于带有磁力搅拌子的15mL顶空瓶中,54℃水浴 15min,加入2.5gNaCl,加盖封口后将萃取头插入样品顶空瓶,于50℃吸附30min,磁力搅拌子转速为600r/min。吸附后将萃取头取出插入气相色谱进样口,于250℃解吸10min,同时启动仪器采集数据。 程序条件:HP-INNOWAX色谱谱(30m×250pm×0.25um);程序升温:40℃下保留3min,然后以4℃/min 升至120℃,再以5℃ /min 升至210℃,保留5min。传输线温度为250℃。载气为 He,流速1mL/min,不分流。 1.3.2 质谱条件 连接杆温度280℃,电离方式为EI,离子源温度200℃,扫描范围45~600u。 1.3.3 SPME-GC-MS数据处理 通过 WILEY /NIST谱库进行定性分析比对,采用峰面积归一化法计算各芳香性物质相对含量。 2 结果与分析 2.1 不同货架温度处理对樱桃芳香性物质的影响 图1、图2、图3分别是对沙蜜豆樱桃样品进行电子鼻 PCA、LDA、LA分析的示意图。 图1 不同货架温度下樱桃挥发性成分PCA 分析图 Fig.1 PCA analysis of volatile componentsof cherry at different shelf temperatures 图1是通过 PCA 的散点分析图上显示的二维散点图得到的,图中每个趋于椭圆形的区域代表各自的货架天数及温度的樱桃芳香性物质的信息采集点。PC1、PC2 的贡献率分别是81.63%和17.28%,方差贡献率总和是98.91%,其贡献率较高,说明反映樱桃中的信息全面,干扰小。从图1可以看出不同处理下的樱桃芳香性物质成分椭圆区域之间没有重叠交叉,说明采用 PCA 分析法可以将不同处理下的樱 表2 不同处理对樱桃挥发性物质含量 Table 2 Different treatments of cherry volatile matter content 类别 相对百分含量/种类(%/种) 贮后货架第1d 贮后货架第4d 贮后货架第6d 20℃ 13C 20℃ 13℃ 20℃ 13℃ 醇类 16.94/6 23.55/4 21.76/7 19.29/4 22.01/3 17.55/5 酯类 0.97/2 0.47/2 0.46/2 0.22/1 0.23/1 0.4/1 醛类 69.26/4 57.88/4 67.73/4 60.28/5 58.92/5 65.79/4 酮类 0.38/1 0.71/2 0.23/1 0.49/2 0.24/1 0.32/1 酸类 0.43/1 0/0 0.33/1 0.32/1 0/0 0.31/2 烃类 1.21/1 1.2/2 1.72/1 1.24/1 0.65/2 1.07/2 其他 1.86/3 2.52/3 0.47/2 5.85/6 2.71/3 2.39/3 图2 不同处理樱桃 LD分析图 Fig.1 LD analysis of cherry at different processing0.6 W2S~wis 图3 樱桃在不同货架温度下电子鼻10条传感器贡献率 Fig.3 The contribution rate of cherry at different shelf temperature sensor electronic nose 10桃芳香性物质完全分开。 由图2可知,LD1、LD2贡献率分别是57.95%、33.68%。判别累计贡献率总和是91.63%。可以看出,13℃时,随着天数的增加,LD2 逐渐升高;20℃时,随着天数的增加,LD2呈现先升高后下降的趋势。两种不同温度货架期内芳香性物质变化趋势相近。20℃处理下1、4、6d椭圆形区域之间跨距比13℃要大,说明13℃下樱桃后熟过程受到了一定的抑制。 从图3可知,W1W传感器器 PC1贡献率最大,W2S、W1S传感器对PC2的贡献率最大。这表明W1W、W2S、W1S传感器相应值的改变较明显,比起其余7条传感器起到了更大的作用。 2.2 不同货架温度下樱桃挥发性物质变化 表2是樱桃样品经过 SPME-GC-MS分析得到的数据。 从表2可知,主要鉴别出来17、20、18、18、18、18 种含量较高挥发性芳香物质(剔除了杂质、未知物质以及百分含量小于0.01%的物质),主要含有醇类、酯类、醛类、酮类、酸类、烃类等物质,其中醇类和醛类含量最高。 13℃-1、4、6d检测出樱桃中醇类物质分别为23.55%、19.29%、17.55%,醇类物质百分含量依次降低,该处理组中酮类含量呈现降低的趋势,由0.71%下降至0.32%。20℃-1、4、6d检测出樱桃中醇类物质依次为16.94%21.76%、22.01%,呈现含量上升的趋势,该处理组中发现随着天数增加醛类、酯类含量降低,其中酯类含量由0.97%显著下降至0.23%,分析这一情况可能是酯类成分水解转化成了醇类,也可能是由于醇类在某些脂肪酸的作用下,经过脂氧合酶氧化,造成醇类物质含量增加。在贮藏的过程中,由于某些醛类在醇脱氧酶的作用下转变成醇类,导致醛类含量下降,醇类含量升高。随着货架时间的延长,13℃和20℃处理组中的烃类含量呈现先升高后降低的趋势。 2.3 樱桃特征芳香性物质分析 果蔬中的芳香气味主要来自于挥发性的物质,每种果蔬中会包含多种挥发性物质,仅当其含量多于味感阈值的一小部分挥发物质才会对果蔬的风味起到决定性的作用。本文沙蜜豆樱桃实验的2个处理组得到的总挥发性物质的分析如表3. 从表3可知,13℃和20℃处理组共检测出37种主要的挥发性香气物质。从13℃处理组中共检测出29种,20℃处理组共检测出23种。13℃-1d、13℃-4d、13℃-6d检测出的主要成分是醇类和醛类,醇类所占的总峰面积分别为27.43%、21.97%、20.47%,醛类占相总峰面积依次为66.61%、68.28%、74.13%。含量较高的成分是苯甲醇、(E)-2-己烯醇、己醛、苯甲醛、(E)-2-希烯醛。醇类共6种,包括1-己醇、苯甲醇、(E)-2-己烯醇、(S)-α,α,4-三甲基-3-环己烯-1-甲醇、2,4-二甲基-3-环己烯-1-甲醇、a,a-4-三甲基-3-环己烯-1-甲醇。醛类共5种,包括己醛、α,4-二甲基-3-环己烯-1-乙醛、苯甲醛、壬醛、(E)-2-己烯醛。 20℃-1d、20℃-4d、20℃-6d检测出的主要成分也是醇类和醛类,醇类所占的总峰面积依次是19.54%、23.58%、26.43%,醛类总峰面积分别为75.20%、 表3 贮后货架不同温度处理下樱桃挥发性物质相对含量(%) Table 3 Different temperature cherry relative content of volatile substances after storage shelves(%) 注:以上表中均为两个处理,挥发性成分表中录入时去除了百分含量小于0.1%以下的物质和未知物质以及杂质,“-”代表未检出。 72.81%、6.38%。该处理下成分含量较高的物质同13℃处理组。醇类共8种,包括1-己醇、苯甲醇、苯乙醇、(E)-2-己烯醇、(S)-α,,4-三甲基-3-环己烯-1-甲醇、α,α-二甲基苯甲醇、2-戊醇、松油醇。醛类共5种,包括种类同13℃处理组。 13、20℃处理组中均发现随着贮藏时间的增加苯甲醇含量降低,苯甲醛含量升高,这是由于苯甲醇经氧化或脱氢反应转化成了苯甲醛。13℃处理组中随着贮藏天数增加发现(E)-3-己烯醛以及(Z)-3- 己烯醛含量减少,(E)-2-烯烯醛含量增加。这可能是由于(E)-3-己烯醛以及(Z)-3-希烯醛异构化转化成(E)-2-已烯醛的结果。 沙蜜豆樱桃主要芳香性物质有苯甲醇(芳香味)、(E)-2-己烯醇(青草香味)、己醛(油脂和青草及苹果香味)、苯甲醛(特殊的杏仁气味)、(E)-2-己烯醛(新鲜水果型清香),且5种特征芳香性物质都有其各自的典型气味呈现,综合构成了沙蜜豆樱桃的特有芳香气味。该结论在前人实验中也有证明, 张序124-28等在多篇文章中对“红灯”、“先锋”、“斯坦拉、“拉宾斯”等几种甜樱桃进行气相色谱质谱联用仪进行芳香性物质检测,均发现乙酸乙酯、己酸乙酯、苯甲醇、(E)-2-己烯醇、己醛、苯甲醛、(E)-2-己烯醛属甜樱桃的特征芳香性物质,且本文沙蜜豆樱桃实验均已检出。相较20℃处理组,13℃处理组中樱桃主要芳香物质(E)-2-己烯醛在1、4d时含量处在抑制状态,待到6d时其含量显著增加,从一开始的42.43%跃至52.14%。而20℃处理组(E)-2-己烯醛在1、4d时都处在含量较高的状态,到6d时由54.40%降至43.04%。其原因可能是由于樱桃处于13℃时温度较20℃低,(E)-2-希烯醛含量受到抑制。(E)-2-己烯醇与(E)-2-己烯醛之间存在相互转化的关系,导致当(E)-2-己烯醇含量下降时(E)-2-烯烯醛含量升高。 3 结论 电子鼻分析技术可以高效的将不同货架温度下的樱桃成功区分开,粗略的得到气味随着不同处理发生改变的趋势,在在基础上结合 SPME-GC-MS技术对樱桃内部挥发性的物质继续进行鉴别。13℃-1、4、6d,20℃-1、4、6d中分别主要鉴别出来17、21、18、17、17、14种含量较高的挥发性的物质。其中苯甲醇、(E)-2-己烯醇、己醛、苯甲醛、(E)-2-己烯醛含量较高,这5种含量较高的芳香物质即沙蜜豆樱桃的主要香气成分,它们各自的特殊香气综合构成了沙蜜豆樱桃的独特气味。实验发现13℃下(E)-2-己烯醛在1、4d时含量趋于平稳状态,随着货架期的延长到达6d时抑制受到缓和使得(E)-2-己烯醛含量突增。在20℃下(E)-2-己烯醛在1、4d时处于最高含量状态,当6d时其含量急剧下降。可能是由于(E)-2-己烯醛会受到低温影响,抑制其含量的增加。芳香物质中的醇类和醛类出现了相互转化的作用,当醇类含量下降时,醛类含量升高,当醇类含量升高时,醛类含量呈下降趋势。 综上所述,对货架期樱桃不同温度处理下芳香性物质的研究,为今后樱桃货架期温度的选择等提供了科学的理论依据。 ( 参考 文献 ) ( [ ]李 晓青 ,韩燕 丽 . 大 樱 桃 贮藏 保 鲜技术 [].保 鲜与加工, 2006,6(5) : 25. ) ( [ 2 ] 张宗坤,张超 杰,刘 万 好.浅述 大樱桃冷 藏 保鲜 技术. 烟 台 果树 , 2 0 06(1) : 17- 1 9. ) ( [ 3]兰鑫哲,姜 爱丽 ,胡 文 忠.甜 桃 桃采后生理 及 冷 藏保 鲜 技 术 进 展.食 品工 业科技,201 1(11) : 535-538. ) ( [ 4] 生兆 江,生吉萍 . 几种 樱 桃的营养 成分 测定[ ]. 莱 阳农 学院学报, 1989,6(4 ) : 2 8- 3 2. ) ( [ 5]张晓 华 , 张 东星 , 刘远方,等.电子 鼻 对 苹 果货架 期 质量的 评价[] .食 品与发酵工业, 2 0 07,33(6):2 0 -23. ) ( [6 ]惠 国 华 , 厉鹏,吴玉玲, 等 . 基于 电子鼻 系 统 的水果 腐败过程表 征方 法 方 .农 业工 程 学 报,2 0 1 2 , 28(6):26 4 -26 8 . ) ( [] 王金美 . 电子鼻及其在食品 行 业中的应用 . 山 东 食 品 发 酵, 2009( 1 ) : 37-41. ) ( [8] Garc i a M , Fernandez M J, Fo n t echa J L , e t al . Di f ferentiation ) ( of red wines u sing a n e lec t ronic nose b ased o n s u rface a cousticwave devices [ ] .Talanta,2006,68 ( 4 ) : 1 162-1165. ) ( [ ] W ik l und S, Jo h ans s on E, S j o strom L, e t a l. V i sua l ization ofGC/TOF-MS-based metabolomics dat a for id e nt i fication ofbiochemic a lly interesti n g compound s using OPL S c lass m odels [ . A n a lyt i ca l c h e m istry,2008 , 80( 1 ) :1 15 - 122. ) ( [ 10] R izzolo A , B i anchi G , V a n o l i M, e t a l. El e ctronic n o s e todetec t vol a til e c o mpound profile a n d q u al i ty changes in Spring Belle’ pe ac h (P r unus pe r sica L. ) du ring cold storage i n r e lation to fruit opti c a l prop e rtie s measured by time- r e s o lved r e flectance s pectroscopy [J] . Journal of A gri c ultura l and Food C hemistry, 2 012,61(8) : 1671-1685. ) ( [ 11] Baietto M, Wilson A D . E lectronic - Nose A pplications for F ruit Identificati o n, Ripe n ess a nd Q u ali t y G r a ding [J]. S e n s ors ,2 015,15( 1 ) : 899- 9 31. ) ( [ 12] Spinelli F , N oferini M , Vanneste J L , e t al. P otential of th e electroni c - nose f o r t he d i agnosis o f b acteri a l a nd f ungaldiseases i n fruit t rees [].EPPO bul l etin,2010,40 ( 1 ) : 59- 6 7. ) ( [1 3 ]徐 永霞 , 刘滢,姜程程,等 .电 子鼻结合气质联 用 法分 析 大菱鲆冷藏过 程 中挥发 性成分 变化 [ ] .食品 与发 酵 工业, 2014,40(1 ) :193- 1 97. ) ( [1 4] 江 津津,陈 丽 花,黎海彬,等.基于电子鼻 的 鱼露香气品 质识 别 [ ] . 农业工程 学报,201 2,27(12):3 7 4-3 7 7. ) ( [1 5]缪芳芳,丁媛, 蔺佳 良,等.应 用电 子 鼻 和气质联用仪研究 不 同 采收季 节 浒苔 的挥 发性 物 质 [ ] . 现代食 品 科 技, 2 0 14, 30(8):258-263. ) ( [1 6] 裘 迪红, 宋 绍华, 苏 秀榕,等.浒 苔 加 热 过程 中 军 发性 风 味 成分的变化 [ ]. 中 国食 品学报 , 2 0 1 3(5): 2 4 6 -253. ) ( [17 ]巨玉佳, 梁 琪 , 张炎,等 . 电 子 鼻联合 G C -M S分析 不同牦 牛乳干酪中 特征 挥发 性 成分[ ] .食 品与机 械 , 201 4(4 ) : 1 4-1 7. ) ( [18 ] 房 一明,谭乐和 , 初众 , 等. 巧 克力 香 气成分 的 G C-M S 与 电子 感 官分析[ ].热带 作 物 学报 , 2 0 1 3 , 34(8):1576-1582. ) ( [1 9 ]黄 业传, 李 凤,黄甜, 等 . 利 用 电 子 鼻 和气质联用研究腊 肉挥 发性风味 物 质的形 成 规律 [].食品 工业科技 ,2 0 1 4 ,35 ( 6) : 73- 7 7. ) ( [20 ]张鹏 , 李江 阔 ,陈 绍 慧.气质联用 和 电 子鼻 对1 -M C P 不 同 处理 时 期苹果 检 测分 析[] .食品 与发 酵 工业,20 1 4 (9):28. [2 1 ] 丁 媛 ,周君,郑平安 , 等.基 于 SPEM-G C -MS 和电子鼻研究温度对毛毛挥 发 性 物 质的影响 [ ].核 农 学 报 ,20 13,27 ( 12) : 1873-1880. ) ( [2 2] 秦 玲,蔡爱 军 ,张志雯, 等 . 两 种甜樱 桃 果 实 挥 发 性 成分 的 HS - SPM E- GC/MS 分析 [J].质 谱学报,2 010,31( 4): 2 28- 2 34. ) ( [2 3]王家喜,王 江 勇,高 华 君,等.两种 砧木 对布鲁克斯大樱 桃果实芳香 成 分的 影响[] . 中 国 农学通 报 ,2009 ,25(1 0 ) : 187- 1 90. ) ( [24 ]张序,姜 远 茂,彭福 田 ,等.‘红灯'甜 樱 桃果实 发育 进程 中 香气 成分 的 组成 及 其 变化[. 中国 农业 科学,2 0 0 7 ,40(6) : 1222- 1 228. ) ( [25 ]张序,姜 远 茂, 彭福 田,等.顶空 固 相 微 萃取-气 相色 谱质谱联用 技术分 析 甜 斤 桃 芳香成分[ ] . 分析试验 室 , 200 6,24 ( 11 ) :51 - 53. ) ( [ 26 ]张序.甜 樱 桃 芳 香物质的 组 成 及其 影响因素研究 [D ]. 泰安 : 山东 农业大 学,20 06. ) 第 不同温度对货架期樱桃挥发性物质变化的影响《食品工业科技》 罗枫 鲁晓翔 张鹏 陈绍慧 李江阔 天津商业大学生物技术与食品科学学院,天津市食品生物技术重点实验室,天津300134国家农产品保鲜工程技术研究中心,天津市农产品采后生理与贮藏保鲜重点实验室,天津300384 摘要:以“沙蜜豆”樱桃为试材,利用电子鼻检测系统和顶空固相微萃取-气相色谱质谱联用仪2种检测技术,对冷藏20d后不同货架温度(13、20℃)不同时间(1、4、6d)樱桃芳香性物质变化进行分析。研究结果表明,应用主成分分析法、线性判别分析法、负荷加载分析法三种方法进行综合分析,电子鼻技术可以较好的区分不同货架温度下的樱桃。经SPME-GC-MS技术检测,得到樱桃果实中含量较高的成分是醇类和醛类,其中5种主要芳香性物质分别是苯甲醇、(E)-2-己烯醇、己醛、苯甲醛、(E)-2-己烯醛,发现13℃下1、4d时(E)-2-己烯醛含量趋于平稳状态,约在42%左右,6d时抑制受到缓和,(E)-2-己烯醛含量增至52%,20℃下1、4d时(E)-2-己烯醛已处于最高含量状态,约为53%左右,6d时其含量降至43%,这可能是由于低温环境下抑制了樱桃中的(E)-2-己烯醛芳香性物质的生成。关键词:电子鼻 顶空固相微萃取 气相质谱联用 货架期 樱桃
关闭还剩3页未读,是否继续阅读?
北京盈盛恒泰科技有限责任公司为您提供《樱桃中挥发性物质检测方案(感官智能分析)》,该方案主要用于其他水果制品中理化分析检测,参考标准《暂无》,《樱桃中挥发性物质检测方案(感官智能分析)》用到的仪器有德国AIRSENSE品牌PEN3电子鼻。
