现代食品科技2021,Vol.37,No.5Modern Food Science and Technology 现代食品科技Modern Food Science and Technology2021, Vol.37,No.5 基于电子舌快速检测冷藏双斑东方鈍的新鲜度 贾哲,陈晓婷,潘南,蔡水淋,张怡',刘智禹” (1.福建农林大学食品科学学院,福建福州350000)(2.福建省水产研究所国家海水鱼类加工技术研发分中心(厦门)福建省海洋生物增养殖与高值化利用重点实验室,福建厦门361000) 摘要:为研究双斑东方鈍在冷藏过程中滋味物质的变化规律,并建立一种快速检测冷藏双斑东方方的鲜度的方法,本文通过对不同冷藏期(0℃和4℃)双斑东方的滋味物质进行测定分析,并以菌落总数(TVC)的测定结果为鱼肉新鲜度的判别标准,电子舌传感器响应值为因变量,运用偏最小二乘法(PLSR)和多元线性回归(MLR)法建立能够用于区分不同冷藏期双斑东方新鲜度的 TVC预测模型,并对模型进行验证。结果表明 PLSR 和MLR模型都能对不同冷藏时期鱼肉的新鲜度进行预测,其中 MLR 模型的拟合度较高,0℃和4℃组TVC预测模型的训练集(Rc²)分别为0.98和0.99,预测集的决定系数(Rv²)为0.97和0.99,训练集的均方根误差(RMSEV)为0.40和0.08,预测及的均方根误差(RMSEP)为 0.44和0.08;外部验证结果显示,该模型测试集的正确率为100%,具有较好的预测能力。以上结果表明电子舌技术可做为双斑东方方在冷藏过程中新鲜度的快速检测方法。 关键词:双斑东方鈍;游离氨基酸; ATP及其关联物;电子舌;新鲜度;快速检测 文章篇号:1673-9078(2021)05-220-229 DOI: 10.13982/j.mfst.1673-9078.2021.5.0994 The Freshness of Frozen Fugu bimaculatus Detected by Electronic Tongue JIA Zhe , CHEN Xiao-ting, PAN Nan , CAI Shui-lin, ZHANG Yi, LIU Zhi-yu² (1.College of Food Science and Technology, Fujian Agriculture and Forestry University, Fuzhou 350000, China) (2.Fisheries Research Institute of Fujian, National Research and Development Center for Marine Fish Processing (Xiamen),Key Laboratory of Cultivation and High-value Utilization of Marine Organisms in Fujian Province, Xiamen 361000, China) Abstract: In order to study the changes of taste substances of Fugu bimaculatus during cold storage, a rapid method to detect thefreshness of Fugu bimaculatus during cold storage (0℃ and 4℃) was established. The results of total bacterial count (TVC) were used as thecriterion of fish freshness, and the response value of electronic tongue sensor was used as the dependent variable. The partial least squares(PLSR) and multiple linear regression (MLR) methods were used to establish the TVC prediction model, which can be used to distinguish thefreshness of Fugu bimaculatus in different cold storage periods, and the model was verified. The results showed that both PLSR and MLRmodels can predict the freshness of fish at different refrigeration periods, but the MLR model had a better fit. The training sets (Rc)of the TVCprediction models for the 0℃ and 4℃ groups were 0.98 and 0.99, respectively, The coefficient of determination (Rv) of the prediction setwas 0.97 and 0.99, the root means square error (RMSEV) of the training set was 0.40 and 0.08, and the root mean square error (RMSEP) of theprediction is 0.44 and 0.08. External verification results showed that the accuracy of the model test set was 100%, and it had a good predictiveability. The above results showed that the electronic tongue technology could be used as a rapid detection method for the freshness of the Fugubimaculatus in the cold storage process. Taken together, these results suggest that electronic tongue technology can be used as a rapid detectionmethod for the freshness of the Fugu bimaculatus in the cold storage process. 引文格式: 贾哲,陈晓婷,潘南,等.基于电子舌快速检测冷藏双斑东方的新鲜度[].现代食品科技,2021,37(5):220-229 JIA Zhe, CHEN Xiao-ting, PAN Nan, et al. The freshness of frozen Fugu bimaculatus was detected by electronic tongue []. Modern FoodScience and Technology, 2021,37(5):220-229 ( 收稿日期:2020-10-28 ) ( 基金项目:福建省种业创新与产业化工程项目(2017FJSCZY03);福建省海洋渔业结构调整专项(2017HTJG07) ) ( 作者简介:贾哲(1995-),女,硕士研究生,研究方向:食品加工与安全 ) ( 通讯作者:张怡(1975-),女,博 士 ,教授,研究方向:食品科学与工程;共同通讯作者:刘智禹(1972-),男,博 士 ,教授级高工,研究方向:水产品加工与 综合利用 ) 双斑东方 (Fugu bimaculatus),是我国福建省东方鲀的养殖种类之一,新鲜的养殖双斑东方渔滋味鲜美、风味独特,但因其含有丰富的水分、蛋白质和不饱和脂肪酸,在贮藏加工过程中极易氧化变质,从而导致其特有的滋味逐渐变差。目前,鱼类鲜度检验的方法主要有感官评价、菌落总数、理化指标检测(如K值、总挥发性盐基氮等)等,其中感官评价较为快速、简便,但易受主观因素的影响,具有一定的局限性,理化指标能准确反映鱼体的鲜度但对检测人员专业要求高,且操作繁琐、耗时较长,难以实现实时检测11-4],因此,探究一种快速又准确的冷藏双斑东方鲀新鲜度评价体系具有重要意义。 电子舌 (Electronic Tongue, ET) 是一种利用多传感阵列测量未知样品的特征响应信号,通过信号模式识别及专家系统学习识别,对样品进行定性或定量分析的新型现代化分析检测仪器5.61。电子舌因其具有快速准确、操作简单等优点而被广泛应用;韩剑众等人发现电子舌不仅可以有效区分淡水鱼(鲈鱼、鳙鱼、鲫鱼)和海水鱼(马鲇鱼、小黄鱼、鲳鱼)还能较准确地表征其新鲜度的变化;韩方凯》等利用电子舌技术对4℃下不同冷藏天数的鲳鱼进行检测,并构建了K最近邻判别模型和BP人工神经网络模型来评价鲳鱼新鲜度。以上研究结果表明利用电子舌技术判别鱼类新鲜度具有可行性,但将电子舌技术应用于不同冷藏期双斑东方鲀新鲜度的评价,并构建预测模型的研究鲜见报道。 因此,本文以新鲜双斑东方鲀为研究对象,通过研究其在冷藏过程中的 TVC、游离氨基酸、ATP及其关联物、以及鱼肉滋味轮廓的变化规律,建立双斑东方鲀新鲜度鉴别模型,并探讨电子舌技术用于快速评定不同冷藏期的双斑东方鲀新鲜度的可能性。以期为电子舌技术在水产品鲜度评价中的应用提供参考。 1 材料与方法 1.1 材料与仪器 1.1.1 材料与试剂 鲜活双斑东方鲜购于福建省漳州市漳浦县佛昙镇,重约200±50g。 ATP标准品,美国Sigma 公司;氨基酸,混标和光纯药工业株式会社;:甲醇, ASC; 盐酸,莱阳市康德化工有限公司;菌落总数测试片,绿洲生化;其他试剂均为国产AR 级。 1.1.22主要仪器设备 电子天平赛多利斯科学仪器北京有限公司;HWS-28型电热恒温水浴锅,一恒科学仪器有限公司;5804R 离心机,艾本德中国有限公司;J; Waters e2695高效液相色谱仪,美国 WatersACQUITYH-CLASS/TUV; TS-5000Z型电子舌系统,日本Insent公司; LA8080氨基酸自动分析仪,日本株式会社日立高新技术科学。 1.2 试验方法 1.2.1 原料处理 双斑东方处理方法参考 SC/T 3033-2016《养殖暗纹东方鲜、冻品加工操作规范》9并略作修改。鲜活双斑东方鲀,剖腹、去腮、去内脏后,清洗沥干后装入自封袋后,于4℃和0℃冰箱保存,隔天进行各项指标的测定分析。 1.2.2 菌落总数的测定 参考 GB 4789.2-2016《食品安全国家标准食品微生物学检验菌落总数测定》110进行测定,称取鱼肉25g,用无菌剪刀剪碎,加入225 mL生理盐水中,均质1 min 后制成 1:10的悬浊液,选择合适的稀释梯度,涂布于菌落总数测试片,于30±2℃培养箱中培养48h. 1.2.3 游离氨基酸的测定 将整条鱼鱼肉搅碎后称取 20g样品于离心管中,加入0.02 mol/L 盐酸定容。净化:分别加入5 mL甲醇,5mL水, 对 C18前处理小柱进行活化,加入2.5mL样品,再加1.5 mL 0.02 mol/L盐酸,过柱后的样品用 0.02 mol/L 盐酸定容到5 mL, 过0.45 um滤膜后上机。 色谱柱:磺酸型阳离子树脂分离柱,波长:570nm和440 nm, 进样量:20uL,反应温度:135±5℃。 1.2.4 ATP 及其关联物的测定 将整条鱼鱼肉搅碎后称取 5.00 g碎鱼肉加入20mL 10%的高氯酸,涡旋振荡1 min, 4℃、8000 r/min离心10 min, 取上清液,加5mL5%高氯酸溶液提取沉淀物中的待测物,合并上清液,用氢氧化钠溶液调pH至4.0~4.2,4℃超纯水定容至 50 mL, 0.22 um 微孔滤膜过滤,4℃下保存待测。 1.2.5 电子舌测定 将整条鱼鱼肉搅碎后取25 g碎鱼肉加50 mL去离子水,涡旋振荡30s,煮沸30 min, 冷却后过滤,滤液于4℃下8000 r/min 离心 10 min, 取适量上清液进 1.6 数据分析与模型构建 应用 SPSS 22.0、Unscrambler 10.4 和 Origin 9.5对电子舌传感器响应值和 TVC 进行分析、绘图,并建立偏最小二乘法 (PLSR)和多元线性回归(MLR)预测模型,以训练集和预测集的相关系数(Rc和Rp)、均方根误差(RMSEP)作为评价模型优劣的指标,然后将测试集代入模型,预测样本的TVC, 并根据双斑东方鲜度等级的评价结果来判断该的准确性。 1.7 数据分析 理化和电子舌信息数据均使用 SPSS 22.0 进行差异性显著分析(t检验)统计分析和 Pearson 相关性分析, PCA 和相关性分析均由 SPSS 22.0完成, PLS和MLR分析均由 Unscrambler version 10.4 软件完成,并由 Origin 9.5 和 TBtools 0.665 软件进行绘图, Excel绘制表格。 2结果与讨论 2.1 菌落总数的测定 图1双斑东方渔冷藏过程中菌落总数的变化 Fig.1 Changes in the TVC value of Fugu bimaculatusas duringchilled storage 冷藏过程中河鱼肉菌落总数(TVC)的变化如图1所示,在0℃和4℃贮藏1d后河鱼皮的 TVC值分别为1.05、1.13 lg(CFU/g), 随着贮藏时间的增曾,两组的TVC 值均逐渐上升,其中4℃冷藏条件下菌落总数的增加速率显著(p<0.05)大于0℃贮藏组。参考无公害水产品TVC 值可接受上限要求6lg(CFU/g), 将双斑东方新新鲜度划分为新鲜0~2lg(CFU/g)、较新鲜 2~6lg(CFU/g)、和腐败26lg(CFU/g)三类,在0℃条件下,双斑东方鲀鱼肉1d为新鲜状态; 2~5d为较新鲜,仍可食用;7d开始进入腐败阶段。4℃冷藏组于5d开始进入腐败阶段,由此判断双 斑东方鲜鱼肉在0℃和4℃条件下的货架期分别为5d和7d。刘欣荣2发现4℃冷藏过程中红鳍东方鲀的最佳食用期为1~5d, 其中TVC 呈上升趋势,于第5d高出水产品国家标准规定的可食用界限5.0lg(CFU/g), 与本文的研究结果相似。 2.2 游离氨基酸含量的变化 图2双斑东方鈍冷藏过程中游离氨基酸含量变化热图 Fig.2 Heat map of changes in the free amino acids contents ofFugu bimaculatus during chilled storage 图3双斑东方渔冷藏过程中游离氨基酸含量变化 Fig.3 Changes in the free amino acids contents of Fugubimaculatus during chilled storage 游离氨基酸 (FAA) 是鱼肉中非蛋白氮、滋味物质和风味前体物质的重要组成部分3.14,其含量、种类及各种氨基酸之间的相对平衡与鱼肉的滋味密切相关5,具有酸、甜、苦、鲜等味道,但因鲜活水产品的肌肉组织呈微碱性,无法察觉到酸味,故一般分为鲜、甜和苦3类1161。由图2和图3可知,新鲜双斑东方渔肌肉中游离氨基酸不仅含量高,种类也较多,共有17种氨基酸,总游离氨基酸含量(TAA)约为14.88mg/kg,必需氨基酸(EAA) 约为 6.86 mg/kg;其中甜味氨基酸含量(SAA)较高,约为 9.47 mg/kg,其次为苦味氨基酸 (BAA)>鲜味氨基酸(FAA),有研究表明甜味是水产食品的一个主要特征味道,不仅 能产生令人愉快的风味还可以减轻苦味[17.18]。鱼肉中赖氨酸(Lys)、丙氨酸 (Ala )、精氨酸(Arg)和甘氨酸(Gly)的含量较高,分别占总游离氨基酸的26.56%、17.93%、12.10%和7.20%, Gly、Ala 属于鲜味氨基酸(DAA), Gly 和 Ala 是甜味的特征氨基酸19, Arg 具有增加呈味复杂性和提高鲜度的作用20), Lys可以提高人体对其他营养物质的吸收利21,郭芮等发现红鳍东方渔鱼肉中也含有丰富的 Lys221,0℃和4℃条件下冷藏5d后, TAA、FAA、SAA、EAA 含量下降, BAA上升, Ala 和 Arg 含量增加, Lys 和 Gly 含量减少,其中4℃组的变化幅度略大于0℃组;随着冷藏时间的延长, Ala 和Lys 含量增加, Arg 和 Gly 含量逐渐下降,冷藏 1ld 后, FAA 含量下降,约占 TAA 的 2.32%和0.91%, BAA 含量持续上升,说明FAA 含量的减少和BAA 的增加可能是贮藏后期鱼肉口感风味下降的重要原因之一,且0℃组贮藏有利于减缓鱼肉中氨基酸的变化,较好的保持鱼肉滋味和品质,与陈燕婷2等研究结果相似。 2.3 呈味氨基酸分析 图4双斑东方鈍冷藏过程中游离氨基酸含量变化 Fig.4 Changes in the free flavor amino acidcontents of Fugubimaculatus during 鱼肉滋味的鲜美程度与游离氨基酸的含量和组成密切相关241,由于其含量在冷藏过程中发生较大变化,且不同氨基酸的阈值存在差异,故仅凭游离氨基酸含量的变化并不能准确分析鱼肉在冷藏过程中氨基酸的变化与其滋味之间的关系,因此使用 TAV 值对其进行分析。TAV 值指游离氨基酸对滋味的贡献度,当其大于1时,表示该氨基酸对样品滋味有贡献,小于1则没有贡献[25-27。由图4可知,鲜鱼整体滋味的贡献较大的氨基酸为: Lys>Ala>Arg>Val>Glu>Met, Glu是鲜味氨基酸, Lys 是既有苦味,又有甜味的氨基酸,Ala 为甜味氨基酸, Val、Met和 Arg 是苦味氨基酸,其中 Arg 只在浓高度时呈苦味,在较低浓度时其本身 的苦味可被其他成分掩盖并转变成风味增强剂28。冷 藏中期,0℃组和4℃组鱼肉滋味的主要贡献物质分别是 Lys>Ala>Arg>Glu>Val 和 Lys>Ala>Arg>Val;随着冷藏时间的延长,两组样品中Glu 的含量逐渐下降且小于其其值; Val 和 Arg 含量虽然较小但仍大于其阈值, Ala、Lys 和 Met逐渐增加,且4℃组显著大于0℃组(p<0.05);冷藏末期, Lys>Ala>Arg>Val>Met和Lys=Ala>Arg>Val>His(苦味)>Met分别为0℃组和4℃组鱼肉主要呈味物质,说明鱼肉在冷藏过程中鲜甜味逐渐下降,苦味逐渐增加,鱼肉风味逐渐变差。 2.4 双斑东方鈍冷藏过程中 ATP 及其关联物 图5双斑东方冷藏过程中 ATP 关联化合物的变化 Fig.5 Changes in levels of ATP and related compounds in Fugubimaculatus during refrigerated storage 三磷酸腺苷(ATP)及其关联物是核苷酸的重要组成部分2,也是影响鱼类风味的重要的物质之一。鱼类死后其体内的ATP 依次降解为 ADP、AMP、IMP、HxR、Hx, 其中 IMP是重要鲜鲜味物质30,与谷氨酸共存时具有鲜味增效的作用,同时 IMP 对咸味、酸味、苦味及腥味有抑制作用,即有味觉缓冲作用31.32], 当IMP发生降解时,会生成具有苦味、涩味的Hx 和HxR。有研究认为GMP 具有鲜味,其味道强度约是 IMP 的2.3倍33], Fuke 等人发现 AMP 与 IMP 也具有协同增鲜作用34. 样品中 IMP含量最高,分别为79.37 umol/g 和92.88umol/g,约占总量的63.91%和55.42%。在冷藏过程中,两组鱼肉中IMP 先增加后减少,与Zhan等研究结果一致; HxR 和Hx含量不断增加; AMP 先增加后减少,这一结果与付奥36等人对冷藏草鱼 AMP 含量变化规律的研究结果一致; ATP 含量与贮藏时间呈负相关性,始终呈下降趋势,其中,4℃组ATP及其关联物含量的变化幅度较0℃组大。以上结果说明,鱼肉在冷藏过程中 ATP 发生了降解,虽然 ATP 在降解同时也存在 Adr 途径,但HxR 和Hx含量逐渐增加,表明双斑东方鲍的鲜度开始下降. 鱼肉中 ATP 含量不断降低,可能与 ATP 的合成速率以及ATP 酶的活性有关。IMP含量和AMP在3d上升至最大值,随后不断降低,这说明在贮藏的前3d,ATP通过 ADP、AMP 降解为 IMP 的速率大于 IMP降解为 HxR的速率,随着贮藏时间的增加, IMP 磷酸水解酶活性和微生物数量逐渐增加, IMP 降解速率逐渐大于 ATP 降解速率,从而导致 IMP 含量降低, HxR和Hx含量不断增加38。有研究表明 HxR 降解所需的核苷酸磷酸化酶主要来自细菌,随着贮藏时间的延长,鱼肉中微生物不断增加,该酶的积累量逐渐上升,从而加快了 Hx 的上升速率39.40]。在贮藏过程中,0℃组Hx 含量较4℃组低, HxR 含量高于4℃组,这可能与0℃的温度更低,对微生物的抑制力更强有关。 2.5 电子舌响应值分析 双斑东方鲀在4℃和0℃贮藏期间电子舌对鱼肉味觉响应值测定结果如图6所示。由图可知,在整个冷藏过程中,0℃组和4℃组8个传感器的响应轮廓大致相似,但响应值存在较大差异,说明不同传感器对不同贮藏时期的鱼肉的敏感度不同。贮藏1d,两组鱼肉鲜味的响应信号值最高且高于无味点(无味点即参比溶液的味觉值,一般设为零点),这表明贮藏初期双斑东方主要呈鲜味,随着冷藏时间的增加,鱼肉的鲜味下降,苦味和酸味增加,鱼肉滋味逐渐变差。 如图7所示,4℃和0℃组贮藏过程中鲜味的信号强度总体呈下降趋势,贮藏11d后,分别下降了61.98%和 48.53%,酸味的信号强度显著性增加,由贮藏初期的-2.73和-3.15增加至18.43和15.52,苦味呈现微弱的上升趋势,由-1.99、-1.48上升至2.16和1.18,这表明双斑东方贮藏后期主要呈酸味和苦味,且鲜味、苦味信号强度的变化这与鲜味氨基酸和苦味氨基 酸的变化趋势一致。有研究表明,水产品中的鲜味物质主要包括谷氨酸单钠、天冬氨酸单钠、5'-单磷酸鸟苷二钠(GMP)和5'-单磷酸腺苷二钠(AMP)和某些小肽等物质1411,双斑东方鈍在冷藏过程中,天冬氨酸、谷氨酸和AMP均显著性降低(p<0.05),这说明鱼肉贮藏过程中鲜味受氨基酸和呈味核苷酸含量变化的影响。新鲜的水产品通常没有苦味1,贮藏后期鱼肉苦味的上升可能与亮氨酸、组氨酸、丙氨酸等苦味氨基酸以及具有苦味的 Hx 的增加有关,酸味的增加可能与组氨酸等的增加有关。 图6双斑东方渔冷藏过程中的电子舌响应雷达图 Fig.6 Electronic tongue response radar maps duringh coldstorage of Fugu bimaculatus 图7双斑东方鈍冷藏期间滋味指标单因素方差分析 Fig.7 ANOVA for taste indicators of Fugu bimaculatus duringrefrigerated storage 2.6 基于电子舌响应值的 PCA 分析 图8双斑东方鈍在冷藏过程中味觉传感器的主成分分析图 Fig.8 PCA results of taste sensors of different coldstorage ofFugu bimaculatus PCA 分析是一种利用降维的方式将样本数据转换成成少数几个不相关的综合指标的多元统计分析方法,易宇文421等通过对电子舌检测结果进行 PCA 分析,发现不同储藏期鲢鱼的鲜度都能被其有效识别,且前两个主主分的累计贡献率为95.19%。因此,本文利用 spss 22.0对不同冷藏时间双斑东方鱼肉的电子舌响应值进行 PCA 分析, 以 PC1为横坐标、PC2为纵坐标绘制PCA分析结果图(图8)。由图可知,4℃和0℃组前两个主成分总贡献率分别为98.30%和98.90%,且不同冷藏时期鱼肉的滋味特征都得到了很 好区分,冷藏1d位于左下角且与其他冷藏时期相隔较远,3d和5d分布于PC1负半轴区域,7d、9d和11d分布于PC1正半轴,其中,冷藏3d和5d的鱼肉在PCA分布上较接近,7d、9d和11d较接近,说明冷藏3d与5d滋味特征较相似, 7d~11d滋味特征差异较小。 结合因子载荷图(图9)可知,两组鱼肉在冷藏初期(1d)主要呈鲜味,0℃组冷藏3 d~5d主要滋味特征为鲜味、涩味,冷藏7d~11d鲜味逐渐变弱,苦味和酸味逐渐增强;4℃组冷藏前3d鱼肉的滋味主要呈鲜味,5 d~11d鱼肉的鲜味较弱,苦味和酸味增强,鱼肉滋味品质逐渐变差,以上结果说明0℃和4℃的冷藏7d和5d时双斑东方鲀的滋味品质发生了较大变化。TVC 测定结果显示双斑东方屯鱼肉在0℃和4℃条件下的货架期分别是7d和5d,与电子舌的检测结果相互印证,说明电子舌技术可用于双斑东方鲀在冷藏过程中的鲜度等级的检测鉴定。 图9双斑东方渔在冷藏过程中的主成分分析图 Fig.9 PCA results of different coldstorage of Fugu bimaculatus 2.7 TVC、ATP及其关联物和电子舌传感器响 应值的相关性分析 对TVC、ATP及其关联物和电子舌传感器响应值进行相关分析,结果显示(图10),除咸味和丰富性2根传感器外,其他6根传感器的响应值和TVC、ATP及其关联物均具有不同程度的相关性 (p<0.05),说明可使 用电子舌检测双斑东方渔在冷藏过程中的鲜度变化。 图10双斑东方鈍冷藏期间电子舌和 TVC、ATP及其关联物的相关性分析 Fig.10 The correlation among electronic tongue and TVC、ATPand related compounds of Fugu bimaculatusas during chilledstorage 2.8 电子舌传感器响应信号与 TVC 建模分析 为进一步利用电子舌技术检测双斑东方鲀的新鲜度,本研究采用 kennard-stone 法将139个有效样本划分为训练集(90个)与预测集(49个),并以8个传感器响应值作为自变量,通过预测残差总和(PRESS)确定最佳主因子数后,分别建立 TVC 的偏最小二乘回归(PLSR)和多元线性回归(MLR) 的TVC定量预测模型,结果见表1。 有表可知,0℃和4℃组MLR 预测模型的训练集和预测集的决定系数(R和R²)均大于 PLSR 预测模型,均方根误差(RMSEP) 小于 PLSR 预测模型,说明MLR 预测模型的稳定性高于 PLSR模型。因此,本文选择 MLR 法构建双斑东方在冷藏过程中过程中的TVC预测模型,结果如图11所示。 实测值/[lg/(CFU/g)] 2.8.1 预测模型的建立 Fig.11 Scatter plots of TVC predicted value and true value 表1基于 PLSR 和 MLR 的预模型效果比较 Table 1 Comparison of PLSR and MLR model performance 组 建模方法 最佳因子个数 训练集 预测集 R2 RMSECV R RMSEP 0℃ 4℃ PLSR 8 0.96 0.50 0.95 0.55 MLR 7 0.98 0.40 0.97 0.44 PLSR 7 0.97 0.14 0.96 0.17 MLR 7 0.99 0.08 0.99 0.08 2.8.2 定性判别不同冷藏时间双斑东方鲀的新鲜度 为验证双斑东方方TVC 定量预测模型的准确性, 随机选驱13.个未参与建模的样品,比较预测 TYS lishin说明该模型准确度较高 与真实测定 TVC 值的双斑东方鲀新鲜度评价介果,结果见图12。由图可知,预测 TVC 值对双斑东方鲜度等级的评价结果与实测 TVC 值的评价结果一致,说明该模型准确度较高,能够用于双斑东方冷藏过 程中新鲜度的检测。 贮藏时间/d 图12 基于 TVC预测值和实测值双斑东方鈍新鲜度分级 Fig.12 Grading the salmon based on predicated/measured TVCcontent of Fugu bimaculatusas 3 结论 本研究通过使用电子舌、氨基酸自动分析仪和高效液相色谱仪对不同冷藏(0℃和4℃)时期的双斑东方鈍的滋味成分进行分析,并对电子舌传感器响应值与 TVC、ATP 及其关联物进行相关性分析。结果表明,不同冷藏期双斑东方渔的滋味均主要由鲜味、苦味、涩味、咸味、酸味组成,随着冷藏时间的延长,其滋味逐渐变差,品质不断下降。在冷藏过程中,两组(0℃和4℃)鱼肉的 TVC随着冷藏时间的增加呈上升趋势,并于7d和5d达到检出上限6.15 lg(CFU/g)和6.23lg(CFU/g); 新鲜鱼肉主要呈鲜甜略带苦味,随着时间的增加,鲜味物质含量逐渐下降(如 Glu、IMP等),苦味物质增加(如His、Hx等),其中,贮藏末期(11d)时两组(0℃和4℃)鱼肉 FAA 含量较初期(1d)分别减少了0.37 mg/100 g 和0.58 mg/100 g,IMP 下降了 47.95%和 41.58%, His 增加了 28.37mg/100 g 和 86.67 mg/100 g, Hx 增加了 32.08 mg/100g、41.44 mg/100 g;电子舌能够对不同鲜度等级的鱼肉进行有效区分,且分析结果与 TVC 检测结果一致;PCA分析发现,双斑东方屯鱼肉的味觉差异主要体现在鲜味、苦味和酸味,其中鲜味减弱和苦味和酸味的增强是导致鱼肉在冷藏过程中口感滋味下降的重要原 因;利用 PLSR 和MLR 构建了双斑东方屯冷藏(0℃和4℃)过程中 TVC定量预则模型,其中MLR模型的稳定性较好,其预测集的R和RMSEP分别为0.97、0.99和0.44、0.08。以上研究结果表明,电子舌技术可用于冷藏双斑东方渔新鲜度的快速检测。 ( 参考文献 ) ( ] 周明珠,熊光权,乔宇,等.鱼鱼冷藏过程中气味和新鲜度的 变 化及相关性[ ] . 肉 类研究,2020,34(3):68-74 ZHOU M i ng-zhu, XIONG Gu a ng-quan, QIAO Yu, et al.Changes and c o rrelation of odor and f reshness of channelcatfish during cold storage []. Meat Research, 2020, 3 4 (3):68-74 ) ( [21 Rathod Nikhil, Pagarkar Asif, Phadke Girija, et al. Ch e mical,microbial a nd s e nsory quality changes of fis h cutlets, madefrom p angasius f ish (Pangasianodon hypophthalmus), duringstorage in refrigerated displ a y un i t (-15 to - 1 8 ℃ ) [ ].Ecology E nvironment a nd Conservation, . 2 2 014, 2 2 0(3): 967-972 ) ( [3] K atrien B eullens Peter M eszaros, S t even Vermeir, Dmitriy Kirsanov, et a l. Analysis o f tomato t a ste using two types of electronic tongues []. Sensors & Actuators: B . Chemical, 2008,131(1):10-17 ) ( [4] Berna A malia Z , L a mmertyn Jer o en, Saevels Sti j n, et a l .Electronic nose s y stems to study shelf life and cultivar effecton t omato a roma profile []. Sensors & A c tuators: B. C h emical, 2003,97(2):324-333 ) ( [5] Jiang Hongyao, Zhang M in, Bhandari ] B hesh, et ta a l. Application o f e lectronic t ongue f o r f r esh f o ods qu a lityevaluation: a r eview [ J ]. F ood R e views Int e rnational, 20 1 8, 34(8):746-769 ) ( [6] 韩慧, 王 志强,李彩虹, 等 .基于电子舌的掺假羊奶快速定 量 预测模型[J].食品与机械 , 20 1 8,34(12):53-56 HAN H u i, W A NG Zhi- q iang, LI C ai - hong, et al . R a pidquantitative prediction model of adulterated goat milk basedon e lectronic tongue [ J]. Food & M a chinery, 2018, 34(12):53-56 ) ( [7] 韩 剑 众,黄丽娟,顾振 宇,等. 基于 电 子舌的鱼肉品质及新鲜 度 评价[].农业工程学报,20 08 ,24(12):141-144 HAN J i an-zhong, H UANG Li- j u an, G U Zh e n-yu, et al . E v aluation of f ish q uality and freshness b ased o n t h eelectronic tongue []. Transactions of the C h inese Society ofAgricultural Engineering, 2008,24(1 2 ):141-144 ) ( [8] 韩 方 凯,黄 星 奕,穆丽 君 ,等 . 基于 电子 舌技术的 鱼 新鲜度 定 性、定 量 分 析[ ].现代食 品 科 技 ,2014,30(7):247-251,267 ) ( HAN F a ng-kai, HUANG Xi n g-yi, MU Li-jun, et a l .Quantitative and q u alitative analysis of fish fr e shness basedon electronic tongue technique []. Modern Food Science and T echnology, 2014, 30(7):247-251,267 ) ( 91 SC/T 3033-2016,养殖暗纹东方鲜、冻品加工操作规范 [S SC/T 3033-2016, Aquatic I n dustry Standard - ManufacturingPractice for Processing of F resh and Frozen Cultured Obsure Puffer [S] ) ( [10] GB 4789.2-2016,食品微生物学检验菌落总数测定食[S] GB 4789.2-2016, N ational Food S afety S tandard -FoodMicrobiological E xamination:Aerobic Plate Count [S] ) ( [11] GB 18406.4-2001,农产品安全质量无公害水产品安全要 求[S] GB 18 4 06.4-2001, Safety Qu a lification fo r Agr i culturalProduct - Safety Requirements for Non-EnvironmentalPollution Aquatic Products [S] ) ( [1 2 ]刘欣荣.不同贮藏方式对红鳍东方品质的影响研究[D].保定:河北农业大学,2020 LIU Xi n-rong. Study o n th e eff e ct of different storagemethods on t h e q u ality o f Takifugu rubripes [D ] . B a o ding:Hebei Agricultural University, 2 020 ) ( [13 ] K K ato H, Rhue M R , Ni s himura T. Role of free amino-acidsand peptides i n food taste []. Acs Symposium Se r ies, 1989,388:158-174 ) ( [14 ] 吴倩蓉,潘晓倩,朱宁,等.不同杀菌温度对羊蝎子风味物质 的影响[J].食品科学,2 0 20,41(20):184-190 WU Q i an-rong, P A N Xi a o-qian, ZHU Nin g , et al. Effect ofsterilizatio n temperature on flavor compounds in spiced lambspine []. Food S cience, 2020, 41(20): 184-190 ) ( [15] 范霞. 中国 对虾冷藏期间的品质变化研究[].食品研究与开 发,2020,41(8):32-37 FAN X i a. Research on quality changes of Penaeus c h inensis during refrigeratedstorage [].h Food Research and Development, 2020,41(8): 32-37 ) ( [16] 3 王 晓燕,潘晓炀,焦阳,等.通电加热过程中凡纳滨对虾虾肉糜的游离氨基酸和核苷酸含量变 化 研究[].食品工 业 科技, 2019,40(20):71-75,87 WANG X i ao-yan, P AN X i ao-yang, JIAO Yang, et a l.Changes of free amino acid and nucleotide in m inced s h rimp(Litopenaeus v annamei) during O h mic heating [] . Sc i enceand Technology of Food Industry, 2019,40(20):71-75,87 ) ( [1 7 ]杨欣怡, 宋 军,赵艳,等. 网箱 海养卵 形鲳 肌肌肉 中呈 味物质 分 析评价[ J ].食 品 科学,2016,37(8):131-135 ) ( YANG Xin-yi, SONG Jun, ZHAO Yan, et al. Analysis and ) ( evaluation of flavor components in m e at of sea cage-culturedTrachinotus ovatus [J]. Food Science, 2016,37(8): 131-135 ) ( [18] 彳 徐云强,孙卫青,熊光权,等.低盐鲫鱼鱼露发酵过程中的氨 基酸分析[J].中国调味 品 ,2018,43(10):85-90 XU Yun-qiang, S UN W e i-qing, XIONG Guang-quan, et al.Analysis o f a mino acid i n fermentation process of lo w -saltcrucian carp soy sauce []. China C ondiment, 2 0 18,43(10):85-90 ) ( [19] Kong Yan, Zh a ng Li- l i, Sun Ying, et al. Determination of the free amino a cid, o rganic a cid, and nucleotide in commercial vinegars [. Journal of Food Science, 2017,82(5): 1116-1123 ) ( [20] Wang Y, Hui T, Zhang YW, et al. Effects of firying conditionson the formation of heterocyclic amines and tr a ns fatty a c idsin grass c arp (Ctenopharyngodon i de llus) J. Food C h emistry,2015, 1 67:251-257 ) ( [21 ] B rautaset T , Ellingsen T E . L ysine: i ndustria l uses and production[ ] . C omprehensive B i otechnology ( S econdEdition), 2011,3:541-554 ) ( [22 ] 郭芮,王小瑞,苏 红 ,等.红东东方鱼肉、肝脏、鱼皮中营养物质的比较与分析[J].河北农业大学学报,2017,40(6):77-82 GUO Rui, W A NG Xiao-rui, SU Hon g , et al. An a lysis and comparison o f nutritional c ompositions i n muscle, liver andskin of Takifugu rubripes [ ]. J ournal o f H ebei AgriculturalUniversity,2017,40(6): 7 7-82 ) ( [23] 陈燕婷,李高尚,宣仕芬,等.贮藏温度 对 三疣梭子蟹蟹肉风 味的 影 响[J].核农学报,2019,33(7):1362-1370 CHEN Yan-ting, LI Gao-shang, XUAN Shi-fen, et al. Effects of s torage t emperature on n t t e he e fl flavo r of P ortunus trituberculatus meat []. Journal of N uclear A gricultural Sciences,2019,33(7):1362-1370 ) ( [24] D I ashdorj D ashmaa, Amna Touseef, Hwang Inho1. Influence of s pecific taste-active components on me a t fla v or as affected by intrinsic and e xtrinsic factors: an overview [ ] . E u ropeanFood Research and Technology, 2015, 241(2): 157-171 ) ( [25] M engchen You, Y a ng Pi n g, Song Hu a nlu, et a l . E ffects ofthree types o f bone m a rrow ext r acts treated wi t h differenttreatment m ethods on the taste of chicken soup []. Journal ofFood Science and Technology, 2 020,57(2):638-649 ) ( [26] S ato T aku, O hgami Shin-ichi, Kaneniwa Ma s aki. S e a sonalvariations i n free amino acids, n ucleotide-related compounds,and f atty acids and meat y ield o f the c oconut crab Birguslatro [J] . Fisherie s Science, 2015, 81(5) : 959-970 ) ( [27] C h e n D W, Zhang M. Non-volatile taste active compounds inthe meat of Chinese mitten crab (Eriocheir sinensis) []. FoodChemistry, 2008, 1 04(3): 1 200-1205 ) ( [2 8 ] 张玲,罗嘉滨,海金萍,等.海蜇皮酶解液美拉德反应 产 物的 风味鉴定与分析[].食品科学,2012,33(20):257-261 ZHANG Ling, LUO Jia- b in, HAI Jin- p ing, et al. An a lysisand e valuation o f f lavor compounds i n M a illard r e actionproducts o f jellyfish p rotein p eptic h ydrolysate [ ] . Fo o d Science,2012,33(20):257-261 ) ( [29] 邱霞琴,岳都盛.HPLC 法分析加热对草鱼红肉中滋味物质 的影响[J].安徽农业科学,2016,44(2):90-93 QIU Xia-qin, YUE Du-sheng. Stu d y on the effects of heatingon t he f lavor substances i n the red meat o f grass c arp b yHPLC [ ] . J o urnal o f A n hui Agricultural S ciences, 2 016, 44(2):90-93 ) ( [30] Roichi Itoh , Kayoko Kimura. Occurrence of IMP-GMP5'-nucleotidase in three fish species: a comparative study onTrachurus japonicus, Oncorhynchus m asou a n d Triakisscyllium []. Comparative B iochemistry and Physiology. P artB, B iochemistry & Molecular Bi o logy, 2 0 0 2, 132 ( 2):401-408 ) ( [31] G oulas Antonios E, Kontominas Michael G. Effect o f saltingand s moking-method o n t he keeping quality of chubmackerel ( Scomber japonicus): b iochemical and s e nsoryattribute s [. Food Chemistry, 2004,93(3):511-520 ) ( [3 2 ]边昊,陈柏宇,杜金晶,等.罗非鱼加工副产物速酿鱼露发酵过程中呈味 物 质分析[].食品与发酵工业,202 0 ,46(13):255- 261 BIAN Hao, CHEN Bo-yu, DU Jin-jing, et al. An al ysis of t heflavor compounds in fast-fermented fi s h sauce fr o m tilapiaby-products during f ermentation []. Food a nd F ermentationIndustries,2020,46(13):255-261 ) ( [33] S oldo T.(+ )- (S)-Alapyridaine-A general t a ste enhancer? [J].Chemical Senses, 2003,2 8 (5): 371-379 ) ( [34] F uke S, Ueda Y. I n teractions between umami and ot h er flavorcharacteristics []. Trends in Food S cience and T e chnology, 1996,12(7): 407-411 ) ( [35 ] Huang Zhan, Liu X iaochang,, Jia S hiliang, et al. Antimicrobial effects of cinnamon b ark o il on m icrobial composition and q uality of grass carp (Ctenopharyngodonidellus) fillets during chilled storage []. Food Control, 2017, ) ( [36]付奥,张云云,高燕,等.冷藏草鱼K 值测定方法的优化及其 含量变化[].食品科技,2017,42(12):142-146 FU A o, Z HANG Yun-yun, GA O Yan, et a l. O p timizationmethod of K - value and di s cussion its change about grass carpunder c old storage c ondition J ]. Food d Science and Technology,2017, 42(12): 1 42-146 ) ( [37]陈舜胜,陈媛媛,邱伟强,等.冻结和冻藏对中华绒螯蟹蟹肉 品质的影响[].水产学报,2014,38(10):1793-1799 CHEN Shun-sheng, CHEN Yuan-yuan, QIU Wei-qiang, et al. Effects of f reeze a nd f r ozen storage on ch a nges of quality of Eriocheir sinensis [J]. Journal o f Fisheries of China, 2014, 38(10): 1793-1799 ) ( [38] A / lasalvar C., Taylor K D A, Oksuz A, et al. Comparison of freshness qualit y y o f cultured and wild sea bass (Dicentrarchus l abrax) [ ]. J ournal o f Food Science, 2 0 02, 67(9):3220-3226 ) ( [39] S $ urette Marc E, Gill Thomas A, Leblanc Phil J. Biochemical basis of postmortem n ucleotide c atabolism in cod ( Gadusmorhua) a n d i t s r e lationship t o s poilage [ ]. J ournal o fAgricultural and Food Chemistry, 2002, 36(1) : 1 9 -22 ) ( [40] 刘晓畅, 蒋 妍,申松,等.4℃冷藏 条 件下长丰 鲢 尸僵过程中的品质变化规律[].肉类研究,2016,30(5):20-24 LIU X iao-chang,JIANG Ya n , SHEN S o ng, et al . P o stmortemChanges of Changfeng silver carp during storage at 4 ℃ [ ].Meat Research, 2016,30(5):20-24 ) ( [41 ] 4 韩千慧 , 蔡宏 宇 ,潘婷 ,等. 草鱼和鲢鱼制作 腊 鱼滋味品质的 比较研究[J].食品研究与开发,2016,37(24):25-29 HAN Q i an-hui, CAI Hong-yu, PANTing, et al. A comparative s tudy o n t h e t a ste p r ofile c haracterization ofcured f ish samples produced by common carp and silver carp[]. Food R esearch and D evelopment, 2016,37(24):25 - 29 ) ( [42 ] 易宇文,范文教,贾洪峰 , 等.基于 电子 舌的微冻鲢鱼新鲜度识别研究[].食品与机械,2014,30(2):142-145 YI Yu-wen, F A N Wen-jiao, JIA Hong-feng, et al. Applicationof electronic tongue on d iscrimination of silver carp duringfrozen storage []. Food & Machinery, 2014, 30(2): 142-145 ) (C)China Academic Journal Electronic Publishing House. All rights reserved. http://www.cnki.net 本文以新鲜双斑东方鲀为研究对象,通过研究其在冷藏过程中的 TVC、游离氨基酸、ATP 及其关联物、以及鱼肉滋味轮廓的变化规律,建立双斑东方鲀新鲜度鉴别模型,并探讨电子舌技术用于快速评定不同冷藏期的双斑东方鲀新鲜度的可能性。以期为电子舌技术在水产品鲜度评价中的应用提供参考。检测样品:鲜活双斑东方鲀购于福建省漳州市漳浦县佛昙镇主要仪器:TS-5000Z 型电子舌系统, 日本 Insent公司检测结果:结果表明 PLSR 和 MLR 模型都能对不同冷藏时期鱼肉的新鲜度进行预测,其中MLR 模型的拟合度较高,0 ℃和 4 ℃组 TVC 预测模型的训练集( Rc 2 )分别为 0.98 和 0.99, 预测集的决定系数( Rv 2 ) 为 0.97 和 0.99, 训练集的均方根误差( RMSEV)为 0.40 和 0.08,预测及的均方根误差( RMSEP) 为 0.44 和 0.08;外部验证结果显示,该模型测试集的正确率为 100% 鲀,具有较好的预测能力。不同冷藏期双斑东方鲀的滋味均主要由鲜味、苦味、涩味、咸味、酸味组成,随着冷藏时间的延长,其滋味逐渐变差,品质不断下降。以上结果表明电子舌技术可做为双斑东方 在冷藏过程中新鲜度的快速检测方法。文献来源:福建农林大学食品科学学院
关闭还剩8页未读,是否继续阅读?
北京盈盛恒泰科技有限责任公司为您提供《冷藏双斑东方鲀中新鲜度检测方案(感官智能分析)》,该方案主要用于蔬菜中理化分析检测,参考标准《暂无》,《冷藏双斑东方鲀中新鲜度检测方案(感官智能分析)》用到的仪器有日本INSENT味觉分析系统(电子舌)、电子舌。
