18 PAHs在NanoChrom BP-5MS上的分离与检测 Column: NanoChrom BP-5MS Dimension: 30mx0.25mmx0.25um Carrier: Hydrogen, column flow 1.2ml/min Inlet: Split, 275℃, Split flow 50ml/min Oven: 100℃(hold 1min) to 280℃ at 15℃/min to 340℃ (hold 10min) at 5℃/min Inject volume: 1ul Detector: FID 350℃ Peak# Compound Retention time Resolution (min) 1 Naphthalene (萘) 4.357 2 1-Methylnaphthalene(1-甲基萘) 5.293 3 2-Methylnaphthalene(2-甲基萘) 5.448 4 Acenaphthylene(乙酰萘) 6.621 5 Acenaphthene (范) 6.904 6 Fluorene (芴) 7.673 7 Phenanthrene (菲) 9.144 8 Anthracene(蒽) 9.213 3.97 9 Fluoranthene(荧蒽) 10.406 10 Pyrene (芘) 10.877 11 Benzo[a]anthracene(苯并[a]) 13.243 12 Chrysene(苯并菲) 13.308 3.32 13 Benzo[b]fluoranthene(苯并[b]荧蒽) 15.167 14 Benzo[k]fluoranthene(苯并[k]荧蒽) 15.216 1.90 15 Benzo[a]pyrene(苯并[a]芘) 15.790 16 Dibenzo[a,h]anthracene(二苯并[a, h]蒽) 18.161 17 Indeno[1,2,3-cd]pyrene(茚并[1,2,3-cd]芘) 18.217 1.76 18 Benzo[ghi]perylene(苯并[ghi]花) 18.698 Peak#CompoundRetention time (min)Resolution1Naphthalene(萘)4.35721-Methylnaphthalene(1-甲基萘)5.29332-Methylnaphthalene(2-甲基萘)5.4484Acenaphthylene(乙酰萘)6.6215Acenaphthene(苊)6.9046Fluorene(芴)7.6737Phenanthrene(菲)9.1448Anthracene(蒽)9.2133.979Fluoranthene(荧蒽)10.40610Pyrene(芘)10.87711Benzo[a]anthracene(苯并[a]蒽)13.24312Chrysene(苯并菲)13.3083.3213Benzo[b]fluoranthene(苯并[b]荧蒽)15.16714Benzo[k]fluoranthene(苯并[k]荧蒽)15.2161.9015Benzo[a]pyrene(苯并[a]芘)15.79016Dibenzo[a,h]anthracene(二苯并[a,h]蒽)18.16117Indeno[1,2,3-cd]pyrene(茚并[1,2,3-cd]芘)18.2171.7618Benzo[ghi]perylene(苯并[ghi]苝)18.698
关闭产品配置单
纳谱分析技术(苏州)有限公司为您提供《土壤、空气、水中18PAHs检测方案 》,该方案主要用于土壤中有机污染物检测,参考标准《暂无》,《土壤、空气、水中18PAHs检测方案 》用到的仪器有纳谱分析 BP-5MS气相柱 弱极性毛细管柱。
