醇酯类物质在NanoChrom BP-1MS上的分离与检测 Column: NanoChrom BP-1MS Dimension: 30mx0.25mmx1.0um Carrier: Hydrogen,Head Pressure,7psi Inlet: Split, 250℃, Split flow 90ml/min Oven: 65℃ (hold 5min) to 220℃ (hold 4min) at 10℃/min Inject volume: 1 pL Detector: FID 300℃ Peak# Compound Retention time (min) 1 Methnol(甲醇) 1.322 2 Ethnol(乙醇) 1.465 3 1-Propanol(正丙醇) 1.891 4 Ethyl Acetate (仲丁醇) 2.204 5 2-Butanol(乙酸乙酯) 2.305 6 Isobutanol(异丁醇) 2.447 7 1-Butanol(正丁醇) 2.858 8 3-Methyl-1-Butanol(异戊醇) 3.103 9 Active Amyl Alcohol(活性戊醇) 3.821 10 n-Butyl Acetate(丁酸乙酯) 3.877 11 3-Pentanol(乙酸正丁酯) 4.602 12 Ethyl Lactate(乳酸乙酯) 4.721 13 Ethyl Hexanoate(己酸乙酯) 6.351 Peak#CompoundRetention time (min)1Methnol(甲醇)1.3222Ethnol(乙醇)1.46531-Propanol(正丙醇)1.8914Ethyl Acetate(仲丁醇)2.20452-Butanol(乙酸乙酯)2.3056Isobutanol(异丁醇)2.44771-Butanol(正丁醇)2.85883-Methyl-1-Butanol(异戊醇)3.1039Active Amyl Alcohol(活性戊醇)3.82110n-Butyl Acetate(丁酸乙酯)3.877113-Pentanol(乙酸正丁酯)4.60212Ethyl Lactate(乳酸乙酯)4.72113Ethyl Hexanoate(己酸乙酯)6.351
关闭产品配置单
纳谱分析技术(苏州)有限公司为您提供《醇酯类中甲醇,乙醇,丁醇,乙酸乙酯,丙醇,戊醇检测方案 》,该方案主要用于酯中组成分析检测,参考标准《暂无》,《醇酯类中甲醇,乙醇,丁醇,乙酸乙酯,丙醇,戊醇检测方案 》用到的仪器有纳谱分析 BP-1MS气相柱 非极性毛细管柱。
