醇醚类物质在NanoChrom BP-1701上的分离与检测 Norm. 500- 400- 300- 200- 11 100- 0· Column: NanoChrom BP-1701 Carrier: Hydrogen,2.5mL/min Inlet: Split, 240 ℃, Split flow 80ml/min Oven: 40℃ (hold 5.5min) to 60℃ (hold 1min) at 3℃/min to 150℃ (hold 1min) at 15℃/minInject volume: 1 pL Detector: FID 260℃ Peak# Compound Retentiontime (min) Resolution 1 methanol(甲醇) 3.541 2 ethyl ether (乙醚) 4.013 3 dimethoxymethane(二甲氧基甲烷) 4.436 4 ethanol(乙醇) 4.524 2.70 5 iso-propanol (异丙醇) 5.207 6 methyl tert-butyl ether (MTBE)(甲基叔丁基醚) 5.306 2.27 7 t-Butanol(叔丁醇) 5.841 8 iso-propyl ether (异丙醚) 5.949 2.19 19 methylcyclopentane(甲基环戊烷) 6.449 10 tert-butyl ethyl ether(ETBE)(叔丁基乙醚) 6.638 3.65 11 1-propanol(正丙醇) 7.516 12 sec-butanol(仲丁醇) 8.902 13 iso-butanol(异丁醇) 9.251 14 1,2-dimethoxyethane (1,2-二甲氧基乙烷) 9.524 4.88 15 benzene(苯) 9.952 16 tert-pentanol (tert-amyl alcohol)(叔戊醇) 10.482 17 tert-amyl methyl ether(TAME)(甲基叔戊基醚) 10.610 2.23 18 1-butanol(1-丁醇) 12.622 Peak#CompoundRetention time (min)Resolution1methanol(甲醇)3.5412ethyl ether(乙醚)4.0133dimethoxymethane(二甲氧基甲烷)4.4364ethanol(乙醇)4.5242.705iso-propanol(异丙醇)5.2076methyl tert-butyl ether (MTBE)(甲基叔丁基醚)5.3062.277t-Butanol(叔丁醇)5.8418iso-propyl ether(异丙醚)5.9492.199methylcyclopentane(甲基环戊烷)6.44910tert-butyl ethyl ether(ETBE)(叔丁基乙醚)6.6383.65111-propanol(正丙醇)7.51612sec-butanol(仲丁醇)8.90213iso-butanol(异丁醇)9.251141,2-dimethoxyethane(1,2-二甲氧基乙烷)9.5244.8815benzene(苯)9.95216tert-pentanol (tert-amyl alcohol)(叔戊醇)10.482
关闭产品配置单
纳谱分析技术(苏州)有限公司为您提供《醇醚类物质中甲醇,乙醚,丙醚,丁醇检测方案 》,该方案主要用于酯中组成分析检测,参考标准《暂无》,《醇醚类物质中甲醇,乙醚,丙醚,丁醇检测方案 》用到的仪器有纳谱分析 BP-1701气相柱 中极性毛细管柱。
