水中低含量的残留溶剂在耐水气相柱上的分离与检测 Column: NanoChrom BP-Wax-AQ Dimension: 30m x0.32mm x0.25um Carrier: Hydrogen, 1.1ml/min Inlet: Split, 240 ℃, split flow 40ml/min Oven: 40℃ (hold4min) to 200℃ (hold 1min) at 10℃/min Inject volume:1ul Samples: residual solvent mixture (ethanol, methanol, acetone, acetic acid) in water,theconcentrations of these solvents are around 20-100ppm Detector: FID 260℃ Peak# Compound Retention time (min) Symmetry 1 Acetone(丙酮) 4.180 0.946 2 Methanol(甲醇) 5.680 0.895 3 Ethanol (乙醇) 8.524 0.940 4 Acetic acid (乙酸) 15.789 0.887 Peak#CompoundRetention time (min)Symmetry1Acetone(丙酮)4.1800.9462Methanol(甲醇)5.6800.8953Ethanol(乙醇)8.5240.9404Acetic acid(乙酸)15.7890.887
关闭产品配置单
纳谱分析技术(苏州)有限公司为您提供《水溶液中残留溶剂检测方案 》,该方案主要用于环境水(除海水)中有机污染物检测,参考标准《暂无》,《水溶液中残留溶剂检测方案 》用到的仪器有纳谱分析NanoChrom BP-Wax-AQ气相柱 强极性毛细管柱。
