KGMKYOTO ELECTRONICSMANUFACTURING CO.,LTD.KVX-01304enL-KcM KYOTO ELECTRONICSMANUFACTURING CO.,LTD. Application MemoWater Content in Ketone (3) IndustryOrganic chemical industryInstrumentKarl Fischer moisture titratorMeasurement methodVolumetric titration (Direct Method)StandardsJIS K 0113,ASTM E 203, ISO 760 1. Overview Moisture titration with Karl Fischer reagent is the most reliable moisture measurement method inthe world. The procedure is adopted in many official standards as test method specified in ISO,ASTM, DIN, BS and JIS. Here in this application, we measure water content of ketone by direct method of KF titrationaccording to JIS K 0113. The ketones induce side reaction of generating water with alcohol likemethanol. R2CO+2ROH→R2C(OR)2+H2O However, the side reaction can be avoided by titration with commercially sold solvent forketone. 2. Apparatus Main unit Karl Fischer moisture titration volumetric system Electrode Twin platinum electrode Solvent KEMAQUA solvent KET for ketone 4. Example -Measurement results- Sample name volume Maxvolume Water content (mg) (%) acetone Pyruvic acid 1mL 2.39 1.07 2-ketobutyric acid lg 3.30 0.95 Levulinic acid 10mL 4.05 0.22 3-benzoyl-propionicacid 5g 0.46 0.020 1,2-cyclohexoicacid lg 3.00 0.90 Please feel free to contact us for any further information.
产品配置单
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《酮类样品中含水量检测方案(卡氏水分测定)》,该方案主要用于其他中含量分析检测,参考标准《暂无》,《酮类样品中含水量检测方案(卡氏水分测定)》用到的仪器有MKV-710S豪华型容量法卡尔费休水分仪、MKV-710B卡尔费休容量法水分测定仪。
