电镀溶液中氨基磺酸含量的测定 应用资料在样品中加入浓盐酸和水后,用0.1mol/L亚硝酸钠在低于15℃的温度下滴定,测定镀液中的氨基磺酸含量。终点是滴定曲线上的最大拐点。氨基磺酸的浓度是根据亚硝酸钠的滴定体积计算得出的。KGMKYOTO ELECTRONICSMANUFACTURING CO.,LTD.TIO-93008enL Application Memo Sulfamic Acid in Plating Solution 1.Overview Sulfamic acid in plating solution is measured by titration with 0.1mol/L sodium nitrite at temperature less than 15°℃ after adding concentrated hydrochloric acid and water to the sample. The endpoint is the maximum inflexion on t he t i t ration curve. The sulfamic acid concentration is calculated from the titration volume of sodium nitrite. 2. Apparatus Main unit Automatic potentiometric titrator (preamplifier STD) Electrode Platinum electrode Ceramic reference electrode 3. Reagents Titrant 0.1mo1/L sodium nitrite (f=1.006)Solvent Pure water r ,,C Concentrated hydrochloric acid 4. Example Sample Titer Sulfamic acid (mL) (mL) (g/L) 1 20.0 3.8610 1.886 n4-1 1.00m —Titration curve- Please feel free to contact us for any further i nformation.
产品配置单
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《电镀溶液中氨基磺酸含量的测定 应用资料》,该方案主要用于其他中化学性质检测,参考标准《暂无》,《电镀溶液中氨基磺酸含量的测定 应用资料》用到的仪器有AT-710S豪华型自动电位滴定仪、AT-710M四通道旗舰型自动电位滴定仪、京都电子KEM 自动电位滴定仪控制操作软件 AT-Win。
