OBF-832光纤接口用于连接用于荧光材料远程采样的光纤与FP-8000系列荧光分光光度计。通过使用光纤,可以通过将探针靠近样品进行测量。光纤可用于各种测量,例如当样品大于样品室时,以跟踪原位反应,或用于在危险环境中进行测量,例如高温/低温和高压。Application NoteFP-0018 System Evaluation of SpectrofluorometerFP-8500 with Optical Fiber2/3Application Note System Evaluation of Spectrofluorometer FP-8500with Optical Fibe r The OBF-832 optical fiber i nterface is u sed to co n nect an optical f i be r for remote sampling of fluorescence materia l s wit h an FP-8000Series f lu o r escence spect r ophotometer. By using an opt i cal fibe r, measu r ement can be made by holdi n g the probe close to t h e sample. Optical fibers can b e used for a variety of measu r ements, such as when t h e sample is larger t h an the sam p le chamber , to f ollow an in-sit u react i on, or fo r measurement i n ha z ardous env ir onmen t s, such as h igh/low temperatu r e and h igh pressure . Sp e c t rof l uorometer In t h is application note, a comparison was made by measur i ng samples usi n g an FP-8500 f luorescence spectrophotometer with bot h a FLH-809 f il m holder and an opt i cal fiber with the OBF-832 optical f i ber i n ter f ace. To check for spectral accu r acy the f iber probe was corrected for q u ant u m eff i c i ency using a calibrated l i gh t source wit h a validated spectral emission. Keywords Spectrofluorometer, Optical fiber, F l uorescence spectrum, f l uorescence spectrophotometer Mea s ur e m e nt S ystem and Con di tion measurement for Ex correction data. Figure 1. Measurement system Measurement Condition Measurement Mode Fluorescence Excitation Bandwidth 10nm Emission Bandwidth 10nm Excitation Wavelength 310nm Measurement Range 400-800nm Scan Speed 100 nm/min Data Interval 0.5nm Response 1sec PMT Voltage 350 V (yellow card), 550 V (red card) 28600 Mary's Cour t , E a s to n , M D 21601US A M easu r emen t Results Figures 2 and 3 show th e measu r ement r esults. The profiles of t he spect r a of each colored sample measured u sing both the optica l fiber and FLH-809 film holder were consistent wit h each other . These results demonstrate that the spectra l accuracy obtained using bot h the fiber probe and film holder yie l d comparable data. Figure 2. Nor m al i zed f luorescence s p ec t ra of th e yellow card Figure 3. Nor m alized fluoresce n ce spectra of the r ed ca r d JASCO INC. 28600 Mary's Cour t , E a s to n , M D 21601US A
关闭还剩1页未读,是否继续阅读?
佳士科商贸有限公司为您提供《FP-8500型光纤荧光计的远程测量》,该方案主要用于光学材料中光谱、校准、光纤检测,参考标准《暂无》,《FP-8500型光纤荧光计的远程测量》用到的仪器有JASCOFP-8000系列荧光光谱仪。
