众所周知,具有高极性材料柱的SFC显示出与正相色谱相同的保留作用,因此被认为难以分离含水的高极性组分。然而,如果在改性剂溶剂(醇等)中加入少量挥发性酸、碱或盐,则可以改善极性组分峰的形状,并且可以用适当的保留时间洗脱保留时间长的组分。以甲醇中的乙酸铵为改性溶剂,采用2-乙基吡啶柱对各种碱性药物进行了分离。Application Note 2/2Application NoteSeparation of Basic Drugs by Supercritical Fluid Chromatography Separation of Basic Drugs by Supercritical Fluid Chromatography In t rod u c t ion It is well kn o wn t hat SFC with a column of high polarity mater i al shows the same retention action as normal phase chromatography , and t herefore it is bel i eved to be difficult to separate aqueous high polar i ty compo n ents. However, if a li tt le vo l atile acid, base , or sal t is added to m odifier solvent (alcohol or etc.), the shape of polar component ’s peak can be improved, and components with a long retention t i me can be eluted with an appropri a te retent i on ti me. Various basic drugs were separated using the 2-Ethylpyridine column with ammonium acetate in methan o l as modi f ier solvent . Keywords: SFC, Basic Drugs, achira l , 2-Ethylpyridine column, PDA Detector CO2 Del i very PU-2080-CO2Column:2-Ethylpyridine 60A (4.6 mmID P um p:x 250 mmL , 5 pm) (Prin c eton Modifier Pump:PU-2080Chromatography Inc .)MCixer:MX-2080-32O2 Flow rate:3.0mL/min Autosampler :AS-2059-SF Modifier:20 mM Ammonium acetate inM Cethanololumn Oven:CO-2060PDA Detector:MD-2018Modif i er gradient :0 mi n (0.2 mL /mi n ), 6 m in (0.2 mL/[H igh pressure cell]m i n), 13 min (1.0 mL/min), 18 mi n Back Pressure BP-2080(1.0 mL /mi n ), 18.05 m i n (0.2mL /min),Regulator:1 cycle: 30 min Column temp.:40°C Back Pressure:15 MPa Wavelength:200-400nm I njection volume:5uL Sta n dard sample:Mixture 0.1 mg/mL each Results C h r o m a t o gr a m a n d c o nt o u r p l o t o f s t an d ard mix tu r e o f b a s i c dru g s (220n m ) ar e sh o wn i n f igu re 1.As s h own , pola r comp o n e n ts su ch a s B e r be r i n e a nd M a l e i c w e r e a l s o el u t e d . Fi g ure 1. Chroma t ogram of st a ndard m i xt u re of b as ic dru g s1: Ca ffe i n e , 2: Hexo b a r b i ta l , 3:Amitrip t yli n e, 4:Ch l orp h e n irami n e, 5: I mipra m ine 6: Q u i n i n e, 7:A t ro p i n e, 8:Acetamin o p hen , 9:Berberin e , 10: Male i c acid
关闭产品配置单
佳士科商贸有限公司为您提供《超临界流体色谱法分离碱性药物》,该方案主要用于生物药品药物研发中分离、药物、碱性、基础药物检测,参考标准《暂无》,《超临界流体色谱法分离碱性药物》用到的仪器有JASCO SFC4000超临界流体色谱仪、JASCO高效色谱仪LC-4000。
