用圆二色谱检测器对Flurbiprofen的手性分析
检测样品 生物药品药物研发
检测项目 CD检测器、手性分析、对映体
关联设备 共2种 下载方案
方案详情
关键词:氟比洛芬,对映体,CD检测器,CHIRALPAK AD-RH
氟比洛芬是一种非甾体抗炎药,用作局部医用贴片或内科药物。氟比洛芬的S对映异构体,占药理活性的大部分。圆二色性检测器以其在手性中心附近具有发色团的化合物的手性分析中的高精度和选择性而闻名。同时测量CD和UV信号,并且可以使用光谱扫描来优化感兴趣的波长,这在手性化合物的测量中是重要的。CD检测器不仅可以帮助区分两种对映体,还可以区分非手性杂质和感兴趣的对映体。Application Note Chiral Analysis of Flurbiprofen using aCircular Dichroism Detector2/2 一 Chiral Analysis of Flurbiprofen using a Circular Dichroism Detector I ntroduction Fl u rbiprofen is a non-steroidal anti -i nflammatory drug and used as a topical medical patch or an internal medicine. The S enantiomer of f lurbiprofen, accounts for the major i ty of the pharmacological act i vity. The Circular Dichroism detector is wel l known for its high accuracy and selectivity for chiral analysis of compounds that have chromophores close to the chiral center. Both CD and UV signal a r e measured simultaneous l y and spectral scanning can be used to opt i mize the wavelength of interest, which is i mportant in the measurement of chi r al compounds. Not only can the CD detector help differentiate between two enantiomers, but it can also distinguish between achiral impurities and e n antiomers of interest. Keyword: F l urbiprofen, enantiomer , CD detector, CHIRALPAK AD-RH Experimental [Equipmen t ][Condi t ions]Pump: PU-4185Column:Pump option: Degasser unit Eluent A:0.1% phosphoric acid aqueous solution Autosampler: AS-4050Eluent B:Acetonitri l e Column oven: CO-4060Composition:Eluent A/B (50/50)Detector: CD-4095Flow rate:0.5 mL/min Column temp.:25°℃H C H Wave length:250 nm F. O H Response:1.5 sec Scan speed:10nm/sec Injection volume:10 pL Standard sample: CHIRALPAK AD-RH (4.6 mml .D.x 150 mmL , 5 um) 100 ug/mL racemic f lurbiprofen in el u ent A/B (50/50) Results Fi g . 1 shows the chromatograms of the racemic flurbiprofen standard. Fig. 2 CD and UV spectra (measured using stopped-f low). Figure 1. Chromatogram o f F lu rbi p rofen sta n dard Iop: CD detection, Bottom : UV detecti o n Figure 2. Spectral measureme n t T o p: CD, Bott o m: UV P/N Description 7003-J014A PU-4185 RHPLC Semi-micro Pump (Base Unit) 7006-H003A DG-4000-04 4-channel Degasser Unit, for Analytical 7017-J002A AS-4050 HPLC Autosampler 7021-J002A CO-4060 Column Oven 7029-J002A CD-4095 Circular Dichroism Chiral Detector 7058-J011A BS-4000-1 Bottle stand 6688-H564A LC-Net CG cable 7059-J012A ChromNAV Ver.2 Chromatography Data System 7001-H401A HPLC Start Up Kit for LC-4000 7001-H405A Maintenance tool kit 19724 CHIRALPAK AD-RH manufactured by Daicel
关闭
  • 1/2
  • 2/2
产品配置单
佳士科商贸有限公司为您提供《用圆二色谱检测器对Flurbiprofen的手性分析》,该方案主要用于生物药品药物研发中CD检测器、手性分析、对映体检测,参考标准《暂无》,《用圆二色谱检测器对Flurbiprofen的手性分析》用到的仪器有JASCO高效色谱仪LC-4000、JASCO圆二色光谱仪CD J-1500。
我要纠错
推荐专场
相关方案
